armchair obsession on wire size - Page 2 - Fiberglass RV
Old 04-09-2014, 05:15 AM   #15
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
In simple terms, basically (let's not get really picky) any size wire will charge a battery completely, if it's not under load.
The wire gauge controls the time of charge, and the allowed draw while charging.
Old 04-09-2014, 05:32 AM   #16
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
In my simplistic view of the world, a battery is recharged when the resting voltage (and the rest period is at least an hour, more is more accurate) is back to the proper voltage for the battery. http://www.pbase.com/mainecruising/b...tate_of_charge
Since waiting so long is problematic, I fall back to my second position which is that the battery is recharged after I've returned a matching number of amp hours to that which was consumed between the charging cycles.
For example, checking the battery after only 10-15 minutes will mislead you as to battery charge state.
Having no spouse that I can confine to the trailer(), I built a box with a volt and ammeter which I can insert between the tow and trailer so I get a pretty good sense of what the tow is passing to the trailer.
Between the test box and my Linkpro meter (in the trailer), I've learned that for at least my combination (Ford Flex w/tow package) I don't count on travel-time recharging for much.
The picture shows the conditions with the reefer on DC which is about a 10amp load. It explains why my trailer battery is so deeply discharged even after a 5 hour trip if the reefer is on DC.
Old 04-09-2014, 05:38 AM   #17
Raz
Raz's Avatar
Vermont
Old 04-09-2014, 03:36 PM   #18
IllAnnoy
To support your point....
I was once helping a friend move, he was playing his radio in his van all day and ran the battery down. Having no jumper cables available, I simply McGyvered a cheap household extension cord, cut the ends off and jumpered the batteries. I let his truck charge for 15 minutes from my truck and it started right up. Notice that we charged his battery with the cord not trying to start his van with it.
Old 05-04-2014, 11:12 AM   #19
Trailer: 2004 trillium outback
Alaska
Seems to me the key question is how FAST do you want to charge your batteries. I don't want my gel cells to charge over about 8-10 amps so I'm ok with my #14 wire. As long as I drive a certain amount between stops I can replace the previous stops drain. If I had wet cells and didn't drive much I'd go for big wire.
Ak Ron is offline   Reply With Quote
yellow wire/brown wire deryk Electrical | Charging, Systems, Solar and Generators 24 01-01-2013 05:34 PM
wire rack ronsmith100 General Chat 16 05-10-2009 02:05 PM
another fiberglass obsession... April Wilcox General Chat 0 03-30-2009 01:31 PM
Pairing 14gage AC wire - What gage is the outcome Darwin Maring Problem Solving | Owners Helping Owners 9 07-07-2008 07:37 PM
Blue wire on 7 pin connector shows 12v all the time ? Mikeny Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
