Back to LED lights again, grrr - Page 3 - Fiberglass RV
Old 03-14-2013, 08:34 PM   #29
Trailer: Chez Nous - a 2011 Scamp 16'
My brother in law heads down here (to Texas) from OKC and first stop is a place that sells Shiner -- enough to last a week!
SharonM is offline   Reply With Quote
Old 03-14-2013, 09:07 PM   #30
Originally Posted by SharonM View Post
Dare I ask... but does anybody know what LED bulbs, if any, replace the long light over the kitchen sink? Is that strictly a 120 connection? I ask because it doesn't respond to being turned on and I'm waiting for an extension cord from my brother for shore/house power.
Good night all.
Sharon
I can answer that! The long light in the kitchen will working on nothing but 120. Its a standard florescent tube light and ballasted housing. You can buy Led tube lights now in various sizes (sorry havent look for one for mine as yet) to replace it (not sure if they make them in the right length or not) or you can purchase a new fixture (which is what I am looking to do). I am told that LED tubes can be retrofitting to the existing fixtures but you need to removed the ballast from the light before putting the LED Tube in as it doesnt need it. Suspect its all easier just to buy a new fixture and give it a bit of an updated look to go along with it.
The 921 on the bulbs you took out of the dome lights is the number of the light! Which it sounds like has a T10 base.
SORRY to hear the first ones you ordered didnt work in all your inside lights. But I suspect one might work on your outdoor porch light though but someone did mention here on your original thread re the LED's that they noticed Scamp had changed the dome lights in the newer trailers, but I am surprised they couldn't/didn't tell you that.
Old 03-15-2013, 04:21 AM   #31
Trailer: 2014 livin lite
Virginia
I am ignorant on this subject. Why change to led lights? Is it because they last longer? Or are they brighter? I have been meaning to figure this out for awhile. Do you change exterior and interior bulbs to led? And what is the gain for all the aggravation?
Ruth G is offline   Reply With Quote
Old 03-15-2013, 05:58 AM   #32
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I changed interior lights to LED because I mostly camp where there is no electricity, therefor I must use battery power for lighting needs. Typically 10 LED lights use about the same power as ONE incandescent bulb, and my LED lights are brighter. I changed all my outside lights (stop/turn signal, running & side marker) to LED because they are much brighter and do last much longer.
Old 03-15-2013, 08:58 AM   #33
Trailer: 2005 13 ft Scamp / 2004 Honda Odyssey
I really do not like the white led bulbs. I clicked on a link from Francesca's link and went to solarsaverled.com. they had warm white. Nancy
Nancy is offline   Reply With Quote
Old 03-15-2013, 09:20 AM   #34
Ruth as David suggested the LED lights draw far less power than the old incandescent lights found inside most of our trailers. If you camp without power at all they are a real bonus to have. Most new cars these days have LED lights on the exterior as they are much brighter in bright sun or poor weather nights.
I change out the rear lights on my old Scamp to LED as even in the day time I had on more than one occasion people follow me into parking lots etc and yell at me that my rear lights were not working. They were its just that if the sun was hitting them at a certain angle the people behind me couldn't see they were. I suspect the rear lights on newer Scamps such as yours are probable a lot more visible than the old wedding cake style Scamp used on older models so changing out the exterior lights may not result in as much as a safety improvement as it does on older trailers.
It really is not hard at all to change most of the dome style lights over providing you know the bulb number/style of light you are replacing with LED. Its normally simply a matter or removing the old bulb and popping in the new LED in most situations.
Old 03-17-2013, 08:36 PM   #35
Orlen Wolf's Avatar
I need a pizza and beer. And a hug.
Sharon
PS -- the # on the bulb is 921
Aha! The bulb is a #921 which is a T-10 base. So now to the recommendation:
Go to wiredco dot com online and follow the path to LED Flashlights & Lighting, then LED lighting, low voltage. Find the T-10 side plug wedge base 6 LED unit. They are about $4 each. That's what I replaced all the bulbs with in my unit.
As to the under sink florescent light I would replace it with wiredco's 30 LED surface mount 19" strip. That's what I put under the cabinet over the sink/stove in my unit to replace a two-bulb fixture (a couple of 921s). That complete unit costs about $10 and uses the 12V DC system instead of 120V AC (aka shore power). You will probably have to run a 12V line to power it but I think you will be much happier with the LEDs vs the florescent bulb.
The really good news is that the 6 LED units draw about 300mA vs the 921 draw of 1.4A. That's an 80% reduction in the load on the battery. The 30 LED surface bar draws about 650mA and, of course, eliminates the need for 120V shore power when you are camping away from a current bush (AC power source).
I bought my LEDs from wiredco's booth at a ham radio flea market but they also sell on the internet. And they are in the USA (Scottsdale AZ) so you don't have to wait for that slow boat from China. The parts are still from China but the vendor is local.
Hope this information helps.
As far as the pizza and beer, you're on your own there. Neither pizza or beer have a long shelf life in this house.
73
Orlen Wolf is offline   Reply With Quote
Old 03-17-2013, 09:01 PM   #36
Thanks so much Orlen -- I am so relieved to have the info I need. The replacement tube sounds like a GREAT idea. I need to get myself to an RV shop soon. There are NO (as in ZERO) 12v outlets in my Scamp. I was shocked by this, and I told the guy I bought it from that. I thought one 12v outlet was always standard. Anyway, here I'm trying to move as far away as possible from using/needing shore power, and I've got a trailer that thrives on it. It's a great little trailer tho. Just needs a bit of tweaking.
Sharon
Old 03-17-2013, 09:52 PM   #37
I don't think it is unusual to have no 12 volt outlets. We added one and the only thing I use it for is to stick my volt meter in to check battery drain. Oh, we have also use it for the little 12 volt air compressor to top off the trailer tires. So two things.
What we use more often is an inverter that we plug into the 12 volt car outlet while driving. This charges our cameras, phones, computers while we drive.
Nancy
Old 03-17-2013, 11:07 PM   #38
I've got a 12v hand vac for the trailer, 12v crockpot, 12v TV, 12v electric blanket, and a 12v fan. I'll be off the grid as much as possible. So I desperately need to get some 12v sockets installed in several places in the Scamp. I'll be full-timing.
Sharon
Old 03-18-2013, 03:02 AM   #39
Trailer: In the market
Virginia
OK, my four 1141 LED (bayonet )bulbs came today.
The little spotlight/swivel bulb in the back, driver's side, was simple -- pop out old bulb put in LED bulb. It worked fine.
However, the side-of-wall mounted dome lights are a different story. When you pop out the little plastic square piece that the (non-bayonet) bulb sits in, you see 2 white cords attached to the bottom of that plastic piece. I have no idea what LED lights to buy for this type of fixture. Please help!!!
Also, my adapter for plugging the Scamp into the house came and is fine, but I need an extension cord to reach the garage. Is there a particular "super" extension cord I need to buy? (I don't want to move trailer closer to garage.)
All help appreciated because I'm very grumpy and keep yelling at my adorable dog, as if my stupidity is all his fault.
Sharon
Have you installed those led lights? I have just purchased new set of led lights and looking for some information about installation process.
Geraldmartinez is offline   Reply With Quote
Old 03-18-2013, 08:05 AM   #40
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Orlen Wolf View Post
I bought my LEDs from wiredco's booth at a ham radio flea market but they also sell on the internet. And they are in the USA (Scottsdale AZ) so you don't have to wait for that slow boat from China. The parts are still from China but the vendor is local..........
Another trick is to find what you want on eBay, then check the North America only box in the left column. It will find US and Canadian sources for the same item, usually a little more $, but with faster shipping.
Old 03-18-2013, 08:21 AM   #41
Trailer: '96 Scamp 5th Wheel
Hi Sharon - what part of Texas are you in? I'm in Dallas. Also a newbie to trailers and planning to fulltime for the next year or so. The learning curve on all of this is pretty steep but this sight is full of good people always willing to help. Learning is good - it will keep us young! Good luck to you.
JanB
The Gypsy Wagon
Janb313 is offline   Reply With Quote
Old 03-18-2013, 11:02 AM   #42
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Sharon
Sorta off-topic but I'm curious to know:
What's your plan for an energy source while off-grid?
That 12v appliance lineup looks pretty hungry....especially heat producers like crockpot/electric blanket.
Francesca
lights
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 11:05 AM
LED lights Francine P Problem Solving | Owners Helping Owners 12 04-03-2009 09:29 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 10:54 PM
led lights Pat C Problem Solving | Owners Helping Owners 2 07-16-2008 11:22 AM
NEW LED LIGHTS!! Christi V. Modifications, Alterations and Updates 12 05-10-2007 09:10 PM
