Battery bonair oxygen - Fiberglass RV
Old 09-29-2018, 03:37 PM   #1
Trailer: Bonair oxygen
Quebec
Hi! did you install a battery on your oxygen? Does the battery charge when the caravan is connected to the 110 volt? Thé battery must be installed on the pole of the trailer? Thanks
sylviedulac is offline   Reply With Quote
Old 09-30-2018, 11:04 AM   #2
Trailer: Bigfoot B 17 deluxe
battery
Hello .... The 6 volt deep cycle battery is mounted on the tongue of the trailer directly in front of the propane tanks . The inverter converts the 110 shore power to 12 volt which charges the battery when shore power is in use ...... If the tow vehicle is properly wired the battery is charged when the trailer is plugged into the vehicle .... need to be careful to disconnect the trailer from the vehicle when boondocking AND remember to set the switches located in the access panel(port side , forward) to the correct position( 12 volt or 110) ......... Enjoy !! Hope this helps ... jp
Corbett Road is offline   Reply With Quote
Old 09-30-2018, 03:48 PM   #3
Quebec
Should the battery be connected with the 7-way cable? the same cable used to connect to the car? Thanks
Old 09-30-2018, 05:55 PM   #4
Steve Hammel's Avatar
Trailer: Trillium 4500
This might help. I believe the left side is the vehicle the right side is the trailer.
Old 09-30-2018, 06:00 PM   #5
I have to back up to the first sentence here. Are you talking about a single 6 volt battery or a pair? Not going to get 12V out of one 6V battery.
Old 09-30-2018, 06:02 PM   #6
battery
Great Diagram ....... The charging wire is run directly from the car battery , through a fuse and wired into the plug-in as shown on the diagram ........... have fun !! jp
Old 09-30-2018, 06:03 PM   #7
I was wondering the same thing. I just assumed you meant two.
battery, oxygen
Shower for Bonair Oxygen Legacy Posts Plumbing | Systems and Fixtures 22 08-02-2018 05:15 PM
Just purchased '02 Bonair Oxygen Trevor and Tracy General Chat 47 07-19-2007 08:55 AM
Has anyone installed a furnace in a Bonair Oxygen?? josh Problem Solving | Owners Helping Owners 2 01-05-2007 01:38 PM
oxygen by bonair Legacy Posts Care and Feeding of Molded Fiberglass Trailers 29 12-26-2002 11:44 AM
