Battery box - Fiberglass RV
Old 08-20-2014, 07:29 PM   #1
morgynm's Avatar
Nova Scotia
Battery box
So my Boler is finally in my driveway. I finally have my battery box out to look at it. It definitely has vents in the top that rain could get in.
Should I seal those and maybe drill some holes beneath the handles?
morgynm is offline   Reply With Quote
Old 08-20-2014, 07:30 PM   #2
morgynm's Avatar
Nova Scotia
Oops and here's the handles on the base.
Old 08-20-2014, 07:38 PM   #3
I drilled a couple of holes in the bottom, so if rain (or washing the trailer water) did find a way in... it had a way out.
Old 08-20-2014, 07:51 PM   #4
On our daughters popup with the same battery box on the tongue, I sealed the vents. However there is no onboard charging system (converter) so the cover is off when using a battery charger. You could seal the vents, then put an elbow fitting on the lid with a short hose as a vent. that will keep water out. hose needs to be level or slightly inclined up.
Old 08-20-2014, 07:53 PM   #5
morgynm's Avatar
Nova Scotia
Makes sense! I'll do that tomorrow while the trailer is in for it's safety.
Old 08-20-2014, 09:31 PM   #6
Borrego Dave's Avatar
The vents won't make any difference to the battery. Donna's idea of a few holes in the bottom for drainage is good. Their are millions of batteries on trailers that are not even in a box and are fine. The battery in my dune buggy has been under water many times fording streams...still works. I think it looks better in a box on a TT but the battery doesn't care.
Old 08-20-2014, 11:27 PM   #7
There are vents in the top of battery boxes for a reason. Sealing those vents defects the purpose of the vents.
When a battery is charged it will often out gas hydrogen. Hydrogen is lighter than air and will be trapped inside the battery box if the vents are sealed. Any small spark will ignite hydrogen. Remember the Hindenburg
Old 08-21-2014, 08:27 AM   #8
Timber Wolf's Avatar
North Florida
I have never had a battery box with vents in the top, might as well not have a box if it has holes up there. Perhaps my boxes were all sized and designed to properly vent despite not having holes in the top. And yes bad things sometimes happen to batteries, but it is not often. In all my years of messing with batteries, including a stint at a sho-nuff battery store, I have seen exactly ONE battery blow. And that one was during charging and it was a suspect battery to start with.
Old 08-21-2014, 08:49 AM   #9
morgynm's Avatar
Nova Scotia
This is the Atwood battery box from Canadian tire. It has two sets of over hangs as well. So cables can come out the same side on a long side. Or they can come out on opposite sides on the short sides.
Old 08-21-2014, 09:51 AM   #10
LOL sorry I just went out and look at the one on my trailer and sure enough it also has the two small vents on the top as well. Its not as others have said an issue as the battery can withstand the elements. Vents are a good thing & the reason why its better to put the battery outside rather than inside the trailer
Old 08-21-2014, 10:49 AM   #11
morgynm's Avatar
Nova Scotia
Ok. I'll drill a few holes in the bottom then.
battery
Propane/Battery tongue box Matthew A Problem Solving | Owners Helping Owners 3 04-12-2010 07:58 AM
Do I have to use a battery box? Tony Nowak Problem Solving | Owners Helping Owners 5 08-03-2009 09:54 AM
Battery Box bonnie w Problem Solving | Owners Helping Owners 4 05-14-2007 07:22 PM
Fiber Stream Battery Box Replacement Victor Benz Problem Solving | Owners Helping Owners 3 05-19-2006 10:23 PM
Fiber Stream Battery Box Placement Benita Care and Feeding of Molded Fiberglass Trailers 11 05-12-2006 03:07 PM
