Battery Charger Needed - Fiberglass RV
Old 05-08-2006, 09:05 AM   #1
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
I'm thinking about getting a new battery charger to keep my trailer battery charged. This would replace my 35-year old Montgomery-Wards (edited, see note below) one which works, but isn't very smart.
Any recommendations ala Wal-mart as the new source?
Note: Ah yes Wards. My company Mobil bought them in the mid-1970s after the first oil crisis as a way to diversify and hopefully divert attention from the fact they were an oil company! Alas, it was the last gasp for Wards and they were sold in the early 1980s and soon after folded their tents.
Patrick M. is offline   Reply With Quote
Old 05-08-2006, 12:40 PM   #2
J.C. Whitney www.jcw.com
I purchased a Vector, one that desulfates and is completely automatic and I can start the truck with it if the battery is dead.
The desulfate feature will greatly extend your battery life.
DR
Old 05-08-2006, 06:28 PM   #3
Brian B-P's Avatar
Pete Dumbleton did a bunch of battery charger research a while ago and can probably provide some good information and his experience with the unit he chose and has used heavily.
Following Pete's lead, I looked in the Vector line and chose their VEC1088-A. I bought mine at Wal-Mart, which may be the only local supplier here. There are nearly equivalent products from Schumacher: their best line are their Speedchargers, such as the SC-1200A. There are carried under a house brand name at Canadian Tire, but apparently are also available (under the Schumacher name) in some Wal-Marts.
I think the important features are fully automatic operation, "three stage" cycle control, and perhaps the "desulphate" or "recondition" function. Fortunately, all of the microprocessor-controlled state-of-the-art units are lighter and more compact than a traditional charger.
When I went shopping, I found that all of the chargers of reasonable capacity are affordable and comparably priced, so it's hard to go far wrong. I don't think it matters where you shop, since you get the same product anyway; while it's unlikely that anyone at Wal-Mart will have a clue about chargers, you don't really need them.
Old 05-08-2006, 09:24 PM   #4
Patrick M.'s Avatar
Thanks for those ideas. I remember reading about the "desulphate" or "recondition" function months ago but had forgotten, so that would be a good thing to get if the price is right.
One WM we went to today had Shumacher and another brand, but were missing some stock so we will check at one of the mega-WM's for a more complete selection.
Old 05-09-2006, 03:42 PM   #5
Trailer: 84 16 ft Scamp
I just have one of the smallest "smart" chargers sort of permanently installed. When travelling the tow vehicle keeps the battery charged. When parked, I keep 110 vac hooked up to the trailer and the battery always stays up.
Old 05-09-2006, 05:27 PM   #6
Brian B-P's Avatar
The battery will only stay charged up if the charger has either an adequate "float" or "maintain" mode, or if the charger will restart a charging cycle when it needs to. My Vector manual says it will not automatically restart after going through a charging cycle - no matter how low the battery voltage gets - but I thought Pete said that his (same model?) did anyway. Any model from any maker could work in this way or not, maybe even depending on when it was made (what revision of the design was in effect).
Old 05-11-2006, 04:55 PM   #7
Patrick M.'s Avatar
I ended up getting a Schumacher model WM-1200A from Wally for about $45. This is a 2A/8A/12Amp charger that has support for deep cycle and AGM/Gel batterys. It also has the recondition/desulfate feature. And all the cables store within the small case so it's ready for the road.
Thanks for all the advice and I suspect this one will last me for the next 35 years!
Old 05-11-2006, 05:50 PM   #8
Did it look like this???
Old 05-11-2006, 06:01 PM   #9
Patrick M.'s Avatar
That's it and what a great price at $29! I can only hope he charges $21 for shipping so I won't feel totally ripped off by Wal-Mart!
Checked and his shipping is $15.63 so I don't feel so bad with the WM return policy in my hip pocket!
Old 05-11-2006, 06:06 PM   #10
Trailer: 78 Scamp 13 ft
All this talk about batteries makes me SUPER relieved to have a hubby around who is in "charge" of this stuff!
He said something about getting a marine battery with a solar charger.............
Deb in MN is offline   Reply With Quote
Old 05-11-2006, 07:43 PM   #11
Gina D.'s Avatar
West Coast USA
Don't get a Marine battery. They are different than Deep Cycle batteries.
Marine batteries are a hybrid of sorts.. intended for the big pull needed to start an engine, and the storage capacity needed for running lights and stuff. So they need compnents of Big Pull, which don't You compomise on the life of the battery when deeply discharging them.
Deep cycle batteries are strictly for powering 12v items (Or 6.. depending on your application) and can stand being "Deeply" discharged many many times. This is what you do in your trailer when boondocking with no charge source. You run it down and bring it back to life.. through many cycles of use.
Old 05-12-2006, 12:20 AM   #12
Pete Dumbleton's Avatar
Whoa! Gina, you're a little bit off the track on this one.
Marine battery generally refers to a battery designed basically for use in a boat -- In addition to the normal post terminals, it also has the wingnut terminals for easy disconnection (to take it out for recharging or storage) -- It also has plates designed to take the pounding that often occurs in boats.
http://www.boatsafe.com/nauticalknow...ne_battery.htm
There are now three basic kinds of marine battery:
1. Marine starting battery
2. Marine deep cycle battery (aka trolling battery)
3. Marine dual-purpose battery (a compromise between a starting and deep cycle battery)
A Marine Deep Cycle battery is a good battery for use in an RV and is commonly available at reasonable prices (The battery from my Scamp 13 was recently stolen from a storage yard; I just bought a marine deep cycle, Group 24 size, from Wally for $43 inc tax).
Old 05-12-2006, 08:29 AM   #13
Gina D.'s Avatar
West Coast USA
Ya learn something new every day! Thanks Pete!
I had only heard of a #3. Battery store guy told me not to get one for the reasons I listed. I got a regular Interstate group 24 Deep Cycle. (I have been happy with it tho).
Of course, I DO #1, 2 AND 3 when I get on a boat..
(No boats!!!!!)
Old 05-12-2006, 04:43 PM   #14
Store Guys. I bet he didn't have any marine batteries.
I'm a store guy and I sell many things, especially the thing that I just had a customer look at a few minutes ago and will be back, that is unless you buy it right now.
battery
Battery Charger/Converter John Jesse Problem Solving | Owners Helping Owners 12 05-24-2010 04:36 AM
Battery charger Pat C Care and Feeding of Molded Fiberglass Trailers 13 09-09-2009 08:00 PM
Battery Charger Lainey Problem Solving | Owners Helping Owners 8 08-15-2008 10:47 PM
Battery Charger question Lainey Problem Solving | Owners Helping Owners 3 08-13-2007 03:39 PM
Battery Charger / Converter Craig D. Thompson Problem Solving | Owners Helping Owners 4 08-06-2007 08:03 PM
