Battery condition discrepancy - Fiberglass RV
Old 07-16-2006, 01:25 PM   #1
colin k's Avatar
Trailer: 73 Boler
Hi. So i have a 55 watt solar array with a pathetically CHEEZY charge controller(thank you costco).
My charge controller has 3 led lights. The first light tells you you have 75% + battery charge.
The second light tells you ,you have between 25-75% charge.
The third light tells you you have 25% or less charge.
So after charging my battery to 100%, i run my fantastic fan for about 10 minutes on medium and my charge controller tells me my battery is now at 75% and lower. Hmmm. Brand new battery from wallyworld rv deep cycle 120 amp/hr rating.
Then
I decided to let my fridge(12v fridge) run my battery down to the third led light which is the 25% and less battery charge indicator.
I hook up my fancy digital battery charger which tells you the charge on the battery. The battery charger reads 70% charge.
Hmmm. My cheezy charge controller reads below 25% and my fancy battery charger reads 70%.
Comments,suggestions welcomed.
colin k is offline   Reply With Quote
Old 07-16-2006, 02:11 PM   #2
Paddy Morris's Avatar
Trailer: 1980 Trillium 4500 Deluxe / 2008 Toyota Tacoma 4x2 Access cab 2.7l
Bummer, I think I have the same little charge controller, I used my inverter to tell me the state of the batter as I don't really trust those three little lights. While testing the solar set up at home the controller jumps from one light to another for no apparent reason sometimes. My inverter seemed more accurate. I'm pretty sure that controller is the lower end of the market. At Emily the congtroller behaved though. Pat
Paddy Morris is offline   Reply With Quote
Old 07-17-2006, 08:34 PM   #3
Trailer: 2000 Bigfoot 17 ft (15B17CB)
Then
Most of these led battery charge displays only read the output voltage of the battery, and rely on the fact that a battery at full charge will be 12.6-12.7 volts, half charge at approximately 12.0-12.1 volts and dead at around 11.5. Unfortunately, these voltages only reflect the battery's condition when it is at rest. That is, no current drawn out or put in for several hours at least. If you are charging or drawing current recently or in the last few hours, the battery voltage reading simply will not reflect the actual state of charge.
As you have discovered, this, coupled with the broad range covered by the leds, makes for a somewhat crude indication of battery condition. A more accurate measurement of charge is possible using a temperature compensated battery hydrometer, or a programmable amp-hour meter.
Steve.
Steve C. is offline   Reply With Quote
battery
Easy Air Condition Option (May-be) Eddie Longest Care and Feeding of Molded Fiberglass Trailers 26 09-25-2009 02:00 PM
Using ice to air condition your egg Steven Tonnesen General Chat 7 07-06-2009 11:24 AM
SOLD - 1998 13' Scamp - like new condition Ed & Karen Classified Archives 20 09-07-2008 07:06 PM
Hooking up boler battery to Tug battery Andy H Problem Solving | Owners Helping Owners 3 08-02-2007 12:59 PM
Axle Condition?? Gary Lynch Care and Feeding of Molded Fiberglass Trailers 10 12-11-2005 07:11 AM
