Battery Disconnect Switch - Fiberglass RV
Closed Thread
Old 07-04-2006, 11:04 PM   #1
Victor Benz's Avatar
I have found a great marine-style key-like battery disconnect switch that I plan to install on the main battery cable. This will ensure no over-charging occurs during long periods on shore power, and facilitate easy electrical work.
Do I install it on the negative (ground) cable or the positive (hot) cable?
Thanks in advance...
Victor
Victor Benz is offline
Old 07-04-2006, 11:12 PM   #2
Gina D.'s Avatar
West Coast USA
Hot. Just like any other switch.
Gina D. is offline
Old 07-04-2006, 11:53 PM   #3
Pete Dumbleton's Avatar
Check with your converter manf to ensure the system will function properly without a battery attached to it -- Some converter designs require the battery to be attached.
Presuming it's OK to disconnect the battery, if you don't want to mess with a switch, most RV wiring has a 30Amp fuse right at the battery (on the positive or hot wire, of course); you can just open the fuse holder...
Pete Dumbleton is offline
Old 07-05-2006, 05:29 AM   #4
Will you tell us where you found the switch, part number, manufacturer, etc.?
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline
Old 07-05-2006, 06:57 AM   #5
Here's five to chose from available from JC Whitney:
JC Whitney Battery Disconnect Switch
Donna D. is offline
Old 07-05-2006, 09:00 AM   #6
I found it at a local auto supplier here in Spruce Grove. It did not have a label left, but it looked just like this one.
http://www.partsformodelafords.com/store/m...77&CFTOKEN=3265
The only difference is that mine has an all-weather boot for the switch and the key.
Victor
Old 07-05-2006, 09:06 AM   #7
I contacted the converter manufacturer (Progressive Dynamics) some time ago, and it was his technician's suggestion to install a switch to use when connected to shore power for long periods.
I do indeed have a 30 amp fuse at the battery, but it is just between the battery and the converter. A number of circuits are wired directly to the battery with their own in-line fuses.
So the concensus is the switch should be install on the positive (hot) cable. That actually makes it easier for me.
Thanks everyone!
Victor
Old 07-05-2006, 09:18 AM   #8
You need to check this out because connecting to the negative is the terminal to connect to.
Darwin Maring is offline
Old 07-05-2006, 09:38 AM   #9
This battery disconnect switch from the Eastwood company says you can put it on either negative or positive...now I'm really confused
Eastwood Battery Shutoff Switch w/Instructions
Donna D. is offline
Old 07-05-2006, 09:41 AM   #10
Thanks everyone!
Victor
If you put the switch right at the battery, it doesn't matter which side.
If you have several wires going to the positive side of the battery that run stuff you want to be able to run while on shore power and battery disconnected, put the switch in the negative side.
Byron Kinnaman is offline
Old 07-05-2006, 10:47 AM   #11
This may help clear the confusion. Here is a simple wiring schematic of my trailer.
I have 6 gauge cables going from the battery to the two terminal blocks. Everything is now connected to those terminal blocks. The future installation of a solar package purchased at Costco is also shown for completeness. It will be wired directly to the battery, since it comes with a battery controller.
The two options for installation of the disconnect are indicated by the green circles with numbers. Location 1 is on the positive (hot) cable. Location 2 is on the negative (ground) cable. I initially leaned to location 2, because any accidental shorting to ground would only potentially compromise the switch.
Any comments?
Victor
Old 07-05-2006, 11:30 AM   #12
Attachment 3813
Any comments?
Victor
Either side will work just fine.
Old 07-05-2006, 11:50 AM   #13
The reason that it is recommended to connect to the negative terminal is because the neg terminal goes to the vehicle frame. Once it is disconnected from the frame there is no way it can short out if something were to contact the + side. This follows the rules of connecting / disconnecting batteries. This is recommended how to connect one of these switches in antique cars. Here is what JC Whitney has to say about it.
http://www.jcwhitney.com/autoparts/Product...=battery+switch
BATTERY DISCONNECT SWITCHES
JC Whitney Price: $7.99 - $17.99
Be the first to review this product
o Easy to install on negative battery post
o Battery is disconnected by unscrewing the knob a few turns and reconnected by tightening the knob
o Knob can be removed completely to deter theft
Compact size fits most battery compartments. 12-volt rating: 500 amps surge, 125 amps continuous. Great for cars, boats, RVs or any vehicle used occasionally or stored for long periods of time. Limited one-year warranty.
Old 07-05-2006, 12:33 PM   #14
If I disconnect a battery at the battery it's out of the electrical system, period.... Any battery in anything. It doesn't matter which side of the battery is disconnected it's still no longer in the system. There is NOT anyplace in the system that it can draw current when one side of the source (battery) is disconnected.
The above recommendation only makes sense when the switch has a fuse to keep the automobile computer running. Then any current draw, such as the starter, will blow the fuse and then everything is out of the system.
Closed Thread
battery
Wuz there a switch somewhere?? Doug Mager Ft. Langley B.C. Rallies 4 05-15-2009 11:14 PM
Low-Voltage Disconnect - Anyone Using One? dkdavies Electrical | Charging, Systems, Solar and Generators 6 10-06-2007 05:36 PM
Is it ok to mount a battery isolation (cut off) switch inside the trai Curtis F. Problem Solving | Owners Helping Owners 8 07-05-2007 06:46 PM
battery switch Ron Davis Problem Solving | Owners Helping Owners 3 06-26-2007 08:50 PM
battery switch Ron Davis General Chat 0 12-31-1969 07:00 PM
