Battery installation - Fiberglass RV
Old 07-07-2013, 05:34 PM   #1
Name: Susan & Jamie
Hi All,
This is my first question post, I know someone will have the answer. We have just sold a trillium 1300 that had been rebuilt and rewired and got back the 1300 that was my spouses previous trailer (it had lots of emotional value).
The one we sold had had a battery added to trailer, in line with the wiring from the truck. The current one has no trailer battery.
Can someone explain the process for wiring a battery into the system? The previous trailer had the harness connector coming off the battery so that it was plugged between the truck and the trailer.
Thanks for any help.
Jamie and Susan
Blue Beacon is offline   Reply With Quote
Old 07-07-2013, 06:02 PM   #2
Trailer: 2008 Casita 17' SD
Hi Jamie and Susan,
Welcome to the forum. Here's a link to a Trillium wiring guide located in this site's Document Center, (second from the bottom on the left side menu.) Hope it helps. It shows the battery mounted on the tongue, but I'm sure it can be installed anywhere you can pick up the appropriate + and - leads.
Fiberglass RV - Document Center - trillium 1300 wiring diagram Then click on the Download button on the right.
Old 07-14-2013, 06:54 PM   #3
Doug2000's Avatar
Make sure to mount the battery outside the trailer, deep cycle batteries let off gases that can be hazardous to your health. The tounge is the obvious location because of weight.
Doug2000 is offline   Reply With Quote
Old 07-14-2013, 07:09 PM   #4
Brian B-P's Avatar
Outside... or inside but in a sealed battery box with a vent to the outside.
battery, trillium
Battery Charger on Truck or House Battery? dartz Electrical | Charging, Systems, Solar and Generators 13 06-24-2014 07:59 AM
ParkLiner Battery Monitor and Battery Strap deryk Modifications, Alterations and Updates 23 05-12-2013 12:57 PM
Advice please - how to wire a battery charger battery Steve_N_Janna Electrical | Charging, Systems, Solar and Generators 6 06-17-2012 04:53 PM
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
Hooking up boler battery to Tug battery Andy H Problem Solving | Owners Helping Owners 3 08-02-2007 12:59 PM
