Battery Maintenance - Fiberglass RV
Old 06-23-2014, 05:10 PM   #1
DaMScampers's Avatar
Battery Maintenance
Any thoughts on this maintenance charger?
Black & Decker BM3B 6V and 12V Battery Charger / Maintainer by Black & Decker Amazon.com: Black & Decker BM3B 6V and 12V Battery Charger / Maintainer: Automotive
Any other recommendations?
DaMScampers is offline   Reply With Quote
Old 06-23-2014, 05:21 PM   #2
A 5 watt solar panel - no power required thus no power usage/expense.
Old 06-23-2014, 05:30 PM   #3
Interesting thought in the solar panel. Do I need an inverter then?
Old 06-23-2014, 07:07 PM   #4
Nope because the panel would be connected directly to the battery. You should have a solar charge controller on the panel though but if you are going for a small 5 watt panel just to keep the battery maintained when parked then you would only need a small cheap controller (under $25) to go with it.
But to be honest if you are going to use a solar battery to keep your battery pumped out while parked at home you may as well get at least a 35 watt or a bit more so its of some use to you when you go out camping without power.
battery
Battery maintenance jwcolby54 Modifications, Alterations and Updates 42 10-02-2013 01:43 PM
Deep cycle battery maintenance? jlbails Electrical | Charging, Systems, Solar and Generators 33 08-29-2013 08:28 AM
Vancouver BC - good boler maintenance spot? Dawn S Problem Solving | Owners Helping Owners 5 07-09-2009 12:48 PM
Honda Generator Maintenance Patrick M. Care and Feeding of Molded Fiberglass Trailers 4 06-26-2009 08:10 AM
Are there maintenance places for eggs? Dawn S Care and Feeding of Molded Fiberglass Trailers 8 06-22-2009 10:18 PM
