Battery monitor trimetric 2030 VS Victron BMV700 - Fiberglass RV
Old 02-13-2018, 11:01 AM   #1
Trailer: CASITA
I interested in the advantage and disadvantages of these units.
I already have spent a little more than i wanted to on my set up. But am thinking it might be worth having a battery monitor
system so far
200AH agm battery
100 watt panel on roof
100 suitcase panel
30 amp adventure PWM controler
the victron would end up about $60 cheaper
NEWYORKHILLBILLY is offline   Reply With Quote
Old 02-14-2018, 11:26 AM   #2
Name: Bill & Jeanie
Trailer: Building camper in Ram Promaster van
system so far
200AH agm battery
100 suitcase panel
I installed a Victron BMV 700 in my camper van which has a 460 amp battery bank and a 654 watt PV panel array. I generally keep the display on the percentage of full charge setting but it has a number of other useful display modes that I generally haven't taken advantage of. One reason I bought the Victron is that I also have a Victron MPPT 100/50 solar controller. Victron seems to make well designed high quality equipment that sells at a competitive price.
Bill in NC
wbullivant is offline   Reply With Quote
Old 02-14-2018, 11:55 AM   #3
system so far
200AH agm battery
100 suitcase panel
I have the Trimetric with the companion SC-2030 Solar Controller. I don’t know a lick about the other one so I can’t compare.
The Trimetirc is a geeky R/V’ers dream. Read the manual for details. You can even do a serial interface to your computer for all sorts of data analysis. But very few people will ever take advantage of all it can do, and even a geek is likely to only use the basic functionality after getting it set up.
Where the Trimetric really shines and with the companion solar controller. If you you do get the meter, you should give serious consideration to dumping your current controller and getting the SC-2030 with temperature sensor also.
Lastly, the support (Bogart Engineering) is second to none. The R&D and Tech support is part of the price you pay.
Old 02-14-2018, 12:34 PM   #4
Joe & Cherie's Avatar
Trailer: 2013 EggCamper & 2011 Silverado Reg Cab 4x4
Ohio
I also use the Trimetric TM-2030-RV and love it! I think every camper should have a monitor just to keep from drawing down the batteries too far. I also mostly just keep it on the % full setting. It had good reviews, and has solar companion ability (I haven't used that yet).
Don't know anything about the other brand.
2013 EggCamper #120
Joe's EggCamper Journal
Joe & Cherie is offline   Reply With Quote
Old 02-14-2018, 01:39 PM   #5
Raz
Raz's Avatar
Vermont
It is my opinion these were intended for large installations. Look at the size of the shunt. The smallest, the100 amp shunt means most RV applications are using this in the lowest 10%. I question the accuracy. As far as letting you get more out of your battery, how much more? How much longer will your battery last? The cost could pay for a new battery. I wonder after a year how many even bother looking at it. I use a $10 meter and get all the info I need. Raz
Old 02-14-2018, 01:45 PM   #6
Timber Wolf's Avatar
North Florida
I also have the Trimetric, because I also have their controller. I agree that for just monitoring the battery(ies) it is probably over kill. But I hope to take advantage of its' increased capabilities when coupled with the controller.
Old 02-14-2018, 04:46 PM   #7
Rumline's Avatar
Trailer: Oliver
I would choose based on the ecosystem. I'll be going with Victron because I want to use their ColorControl GX control panel to keep from having one monitor/head/display for every device, not to mention its cloud-based monitoring capabilities. All of their products seem to integrate nicely and people who have written about their Victron systems seem happy with them (Technomadia for example).
Rumline is offline   Reply With Quote
Old 02-14-2018, 04:49 PM   #8
charlsara's Avatar
Trailer: 2014 Lil Snoozy
I have the Victron. You wont be unhappy with it
Old 02-26-2018, 02:14 PM   #9
Buggeee's Avatar
Trailer: Playpac
OH
I've got the Victron and also got the Bluetooth dongle, because I'm worth it. I can read it and control it with an app on my android phone. I love it. Nobody else understands but you people might.
Buggeee is offline   Reply With Quote
battery
To Monitor or NOT to Monitor Darral T. Plumbing | Systems and Fixtures 15 10-13-2014 07:22 PM
Trimetric install on Scamp 16' Morganza Modifications, Alterations and Updates 5 11-17-2013 08:39 AM
ParkLiner Battery Monitor and Battery Strap deryk Modifications, Alterations and Updates 23 05-12-2013 12:57 PM
TriMetric 2025-RV-F Battery Monitoring System baron100 Commercial Posts and Products 0 01-13-2013 05:25 PM
Battery Monitor... solar controller monitor? LukeP Modifications, Alterations and Updates 5 05-14-2012 10:54 PM
