" Battery Test" guage in my CT - Fiberglass RV
Old 01-17-2013, 06:54 AM   #1
Chris Jones's Avatar
Trailer: U-Haul
Of here it is and it does not work properly. I have a metered and have tested it and it is at full charge (12.64) after sitting over night. When it test the switch it is not working and when I bypass it the gauge doesn't work either. Does anyone know where I can get the gauge or a replacement panel for this?
Edit to add pic.
Chris Jones is offline   Reply With Quote
Old 01-17-2013, 07:21 AM   #2
We have an early CT that doesn't have that gauge. I have a voltmeter that plugs into a cigarette lighter outlet, got it from Amazon. Don't know how accurate it really is. I have a load tester for batterys if I need an accurate evaluation. I just saw another CT that has that panel but didn't get a close look at the panel. Can you just use an aftermarket automotive volt meter wired to the battery.
Old 01-17-2013, 07:31 AM   #3
Thomas G.'s Avatar
Chris if you want original, you may need to search here and on eBay. If you are OK with a digital replacement (more accurate), there are plenty on eBay or through instrument suppliers.
Old 01-17-2013, 07:54 AM   #4
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Check and see if the needle is hung on the housing. If some one has tried To reset because it was loose it is very easy to bend the needle. Been there done that.
Michael J.
mmeyer is offline   Reply With Quote
Old 01-17-2013, 09:26 AM   #5
Trailer: U-Haul
Digital would be fine, but I was thinking that there might be a component sales location that might have the size of the original to pop back into that slot.
Old 01-17-2013, 11:05 AM   #6
Trailer: Class A Motorhome
Ferget the 20+ y.o. battery meter. I use and recommend the "VoltMinder" digital battery monitor. It's easy to install and use and has settable alarms to warn of over and under voltage conditions. Less than $30 @ batteryspace.com and others.
Old 01-17-2013, 11:33 AM   #7
I am with Bob, I have a monitor very much like the VoltMinder. Pretty cheap. Alarm goes off *before* the battery gets drained to low.
Battery "Full Charge" or Not? D Davis Electrical | Charging, Systems, Solar and Generators 9 05-16-2012 08:05 PM
Battery venting on "86" Casita npergakis Problem Solving | Owners Helping Owners 9 04-02-2012 09:50 PM
"HOT" Propane Guage Buy at Grocery Outlet Francesca Knowles General Chat 21 05-23-2011 08:27 AM
Didn't "store" battery melissab Care and Feeding of Molded Fiberglass Trailers 7 11-23-2009 05:13 PM
