Best Shore power cable - Fiberglass RV
Old 04-20-2015, 07:27 AM   #1
Trailer: Amerigo
Indiana
Need some advise on what shore power cable to use. I have an Progressive dynamics 4045 fuse panel. Are there different types and or style i need to look at or is that a go to cable. Any help would be awesome THANKS!!!
hotrodaj31 is offline   Reply With Quote
Old 04-20-2015, 08:14 AM   #2
Some of your decision depends on your power needs. You need to have a cable rated at or above your maximum current needs, typically 20 or 30 amps. There is a special cable type listed as an "RV Power Cable" that is more robust than common cable.
All that said, as my maximum power consumption (with a PD-4045 main breaker of 15 amps) is fairly low, I use a common 12/3 x 25' outdoor extension cable on the rare occasion when I connect to power.
Old 04-20-2015, 08:48 AM   #3
Trailer: Amerigo
Indiana
Bob I am taking your reply as to connect/wire in a 12/3 HD extension cord directly into the PD-4045 is that correct.
Old 04-20-2015, 09:25 AM   #4
Not exactly... I have a 15/20 amp 3 pin disconnect on the trailers outside wall that's connected to the PD-4045 and then I plug the extension cord into that input.
Here is a typical model at Amazon, less expensive ones are available through RV supply sources.
Leviton 5278-CWP 15 Amp, 125 Volt, Power Inlet Receptacle.
If you have ever driven off with your power cable wrapped around a wheel you will understand the advantage of not having the power cord hard wired to the power chassis LOLOLOL
Old 04-22-2015, 06:10 PM   #5
Trailer: 1999 Casita 17' SD
Ohio
What provisions are already on your trailer for a power cord? Casita uses a standard 30 amp RV cord hard wired to the converter. There's a hatch on the side of the trailer with a cutout just large enough for the cord. The cord is stored into the area behind the converter.
Wal-Mart has 30 amp RV extension cords and you could cut the female end off to hard wire it. Or you could mount a hatch cover that has a male 30 connector that would allow you to disconnect the cord and store it somewhere else. Or forget it.
Walmart 30 amp 30 foot RV cord for $45.
Road Power 09570-75-08 10/3-Gauge 30-Amp RV Extension Cord, 30-Feet - Walmart.com
Shore-power connector replaces pull-out cord peterh Modifications, Alterations and Updates 72 12-18-2016 12:43 PM
Shore Cable Connector peatle Modifications, Alterations and Updates 11 02-18-2013 01:11 PM
76' Surfside - Does the battey charge when shore power is plugged in? dannis Problem Solving | Owners Helping Owners 2 05-26-2012 07:36 AM
A Question About Shore Power Red-Dwarf Problem Solving | Owners Helping Owners 10 03-21-2012 04:20 PM
Converter makes noise when in shore power Tezha Problem Solving | Owners Helping Owners 9 10-13-2010 02:52 PM
