07-27-2015, 02:01 PM
Trailer: 1989 Lil Bigfoot
CA
Biolite Basecamp: generating recharges with scrap wood
I've been busy researching solar for battery re-charging, but my son just pointed out this really interesting unit:
BioLite BaseCamp | Wood Burning Stove and Grill
They offer several different systems, some very small for backpackers, this one is larger for groups. But the little charging system runs from small bits of wood, heats quickly to cook or just to charge, and (depending on the unit) will either completely charge a phone in about 20 minutes, or recharge enough power to run a video. I'm thinking this may mean charging a computer (more research needed).
If I were to invest in an item like this, I'd probably go right up to the "basecamp" which offers more power and a lot of room to cook. The burner offers two settings -- wide to cook on grill, or directed (like to boil a pot of water).
This looks like a very sexy little item. What do you all think?
Best,
EllPea in CA
07-27-2015, 03:11 PM
Trailer: 2010 Scamp 16
Says it produces 5 watts of power, that is not very much.
Amazon.com: Go Power! GP-SF-5 SUNfilm 5 Watt Solar Panel: Automotive
And there are even less expensive units. These are small enough to fit on the dash of a car. For $300 I would think I could do an extremely nice solar including the battery and maybe an inverter even.
Pay the grandkid to ride a bicycle hooked up to a car alternator... Get a lot of work out of him for 3 Benjamin's
07-27-2015, 04:19 PM
Trailer: Class A Motorhome
I can't figure out the market for this $$$$ item,
Can you really charge a smartphone in 30 minutes with a 1 amp source and get 5 hours of use?
Do backpackers really want to add 18 lbs to the carry weight? Even if distributed, the cast iron part and the battery will be heavy
And what's the battery for anyway
And boiling a litre of water with less than 2 oz of wood?
07-27-2015, 06:10 PM
Trailer: Compact II
I believe it is actually marketed here at a mark-up to produce units for the third world. I saw one in use at Maker Faire
07-27-2015, 06:35 PM
Hmmmm. That sounds like the excuse the Pharmaceutical Companies give for why meds in Canada cost less than in the USofA, so to be able to raise more $$$ to be able to develop meds for the less fortunate?
Welcome to the fixed position inclined helical spiral.
And what's the Maker Faire?
07-27-2015, 09:01 PM
CA
Bob, this bigger item is intended for a stationary camp with multiple people. There is a tiny, small unit for backpackers.
Does it seem improbable to boil water with 2 oz of wood?
LP
Best,
EllPea in CA
07-27-2015, 09:16 PM
Trailer: 2015 Scamp 13 Front Washroom, Van Camper
New Brunswick
I'll be interested to see someone do the math but I've looked at these units in stores and it doesn't add up. Yes I'm sure it produces electricity but I believe the output would still take sometime - are you actually taking the charge from the included 2200ma battery and slightly recharging it??? Consider how long it takes to charge your device plugged into the wall.. I believe Apple devices are happiest with 2.1 amp chargers
Sent from my XT1028 using Fiberglass RV mobile app
07-28-2015, 04:54 AM
I have one. They were first designed to allow camera crews to charge equipment in remote locations. They then went on to develop a smaller one for personal use and marketed in the Westernworld. Mine is the size of a Nalgene bottle and it works to charge my smart phone. I use it kayaking mostly and it just takes sticks the size of your fingers. You really have to keep a roaring fire to get it to charge consistently. I don't use it that much as my MSR stove is more convent. It also blackens my pots which isn't a big problem until you want to store them. Good stove to keep in an emergency kit incase you have to leave your house due to evacuation or numerous other situations.
07-28-2015, 01:06 PM
Trailer: Biod X2
Ditto Don Ravinerat, have one and find it very handy. Also kayak, it is small, gets me a quick tea/ coffee and charges the cellphone. It was a mothers day present! Would love the grill/ bbq part for it. Christmas is coming ;-)
07-28-2015, 01:21 PM
Roll up solar panel to produce power in any size you care to purchase and as far as a cook fire goes... dig a hole about the diameter or a soup can and a little deeper than the can is tall. Place sticks in it. Set on fire. Heat pot over "chimney fire". Replace dirt and sod when done.
Matches are much less weight than a metal wood burning stove, solar panels would be less weight too. Just saying. Well maybe if I had a cottage... wait no at a cottage I could have a bigger solar panel instead of a bigger wood stove.
I simply can't find a situation where solar and/or wind as source of electric doesn't beat burning wood for it. Hauling something to build a fire in? Maybe fi I was going to burn dung and the managed airflow would help it burn better. Neat idea but... I'm not dropping any money into it.
07-28-2015, 02:13 PM
New Brunswick
Glad to hear it works.. Definitely a niche product but so long as it works for the people who buy it..
07-28-2015, 03:30 PM
Arkansas
Seems to be geared to the 'green/tech' crowd. I would think a small folding or scrolling solar panel would produce more electricity, do it cheaper, and do it without carbon emissions as well.
Sometimes simplicity trumps innovation.
07-28-2015, 04:04 PM
CA
Just a thought for those who don't like pots blackened over a fire. A small sheet of foil folded up weighs next to nothing. wrap it around the bottom of your pots. I'm sure you've thought of this by now!
And I'm fine with the idea of digging a little soup can sized hole for a fire, except when it has been snowing or raining.
Best,
EllPea in CA
07-28-2015, 05:49 PM
Trailer: Biod X2
@RogerDat: I'd love to put flexible solar on my next trailer. I have the tiny Biolite, it is very small and light. After a day of paddling it is easy to find a bits of wood, pinecones etc. Hot water in no time. Not too much to screw a person's carbon footprint. Drive a VW Jetta TDI diesel, so use very little fossil fuel otherwise ;-)
Where can a person buy or order the flexi solar? Have a great evening all!
07-28-2015, 06:14 PM
Flexible one can just start with this https://www.google.com/?gws_rd=ssl#q...le+solar+panel
Follow the side links and what other people bought etc. or post a thread here "Which flexible solar panel?" Lot of members have gone that route since our eggs have curved roofs. Some nice set ups to learn from.
For kayak or canoe Google folding solar panel or search for 7 to 12 watt panels. There are some of these that are intended for charging phones and tablets directly.
I used a one burner fuel stove for cooking in inclement weather when I backpacked but would sometimes do the can sized hole for some tea or instant soup or oatmeal rather than use the stove. I have a knack for finding dry wood and carried heat tabs (fuel tablets). Of course it helps I don't live on the north wet coast ....
07-28-2015, 07:24 PM
Used to carry a solar panel but they were no help on cloudy days when kayaking. I have a solar panel for my Trillium to charge up my 12 volt works fine.
07-28-2015, 09:04 PM
I know a few people with the Bilote CampStove, and have used one a few times. At 2 lb it is not that heavy, and when compared to having to take along a litre or two of white gas, or a few butane canisters, it is very light.
There is usually no problem around here finding fuel for them. One buddy gathers during the day finger sized pieces of dried wood. The little sucker heats up quick, as once it is warm, the generator provides electricity to power an onboard fan, the whips the flames into a furry.
The charging of electronics through its USB port does work, and my friends keep their GPS and music player charger with it.
You can get a grill that fits on top of it too. Works great for meats and veggies.
It is first and foremost a stove with a heat powered fan, the USB charging is just a side benefit.
All-in-all, a very well thought out and designed stove, and for about $120, something I have considered. Would I bring it in my trailer....I doubt it. It would be for backcountry use only.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
07-28-2015, 10:11 PM
Trailer: Biod X2
Thanks for the picture Jim,
This what I'm getting for Christmas, in only 154 or so days.....?
07-29-2015, 07:02 AM
I bought mine for winter camping. I have had every type of stove fail. We bought it when it was a concept stove. You know when they have enough ppl they will go into production. Cheaper then but not by much. Nothing I would use for the Trillium as of yet. We're never off the grid if the roads go there.
