Boiled Off Battery - Need New One - Fiberglass RV
Old 07-03-2014, 08:40 AM   #1
fusedlight's Avatar
Trailer: 16' 1998 Scamp
Looks like I may have "boiled off" my battery by forgetting to unhook it over the winter months. It's down to a measly 9.65V (I guess that's why the water pump makes a funny noise and the lights are dim, eh?).
What's the *best choice* for a new battery? I await the "no, THIS one!!" discussion.
Thanks, guys.
fusedlight is offline   Reply With Quote
Old 07-03-2014, 09:47 AM   #2
Leaving the battery hooked up without some sort of charger will NOT "boil off" the battery.
Simply charge the battery with a battery charger. Chances it will ok, it's just discharged, which might shorted the life some. A good battery charger will also do minimal battery fault testing.
You can also pop the cover that allow inspection of the liquid levels, refill with distilled water and again charge with a good battery charger.
Good Luck.
Old 07-03-2014, 09:54 AM   #3
David Tilston's Avatar
Costco has the best deal on batteries. In fact, last fall they put their 6V golf cart batteries on for $69. I should have bought four of them.
Old 07-03-2014, 09:58 AM   #4
fusedlight's Avatar
Hmmm... distilled water and a recharge. *should* it recharge when just hooked up to 110V from the house?
Old 07-03-2014, 11:23 AM   #5
Timber Wolf's Avatar
North Florida
If you are talking about plugging the trailer in and the converter charging the battery than yes it should work if everything is working properly. It may take quite some time depending on what converter you have though. You may want to just charge the battery with a modern separate smart charger. They are not that expensive and handy to have around. My lawn mower battery is dead most of the time when I pull it out in the spring (and dry). A little water and a quick charge and it goes all summer.
Old 07-03-2014, 11:38 AM   #6
fusedlight's Avatar
I put a charger on after topping up the battery. We shall see...
Old 07-24-2014, 04:06 AM   #7
Night Sailor's Avatar
Connecticut
If it was that deeply discharged it was damaged. The question is, how badly damaged?
battery
Battery, do I need one if plugged into electricty? Karalyn Electrical | Charging, Systems, Solar and Generators 19 06-22-2012 06:45 AM
Shut off valve no shut off!! Tamid Plumbing | Systems and Fixtures 11 06-06-2012 02:55 AM
Breakaway switch - do I need one? can I even get one? Shelley Towing, Hitching, Axles and Running Gear 1 06-30-2010 04:03 PM
Off Topic 4 Off Roaders General Chat 0 01-01-1970 12:00 AM
Log off or turn off? General Chat 0 01-01-1970 12:00 AM
