Can Casita 110v outlet power a 120v ceramic heater? - Fiberglass RV
Old 11-14-2015, 10:13 PM   #1
Trailer: Casita SD17
New Jersey
I got a little Lasko #754200 Ceramic Heater. The instruction book says it is a 1500w heater and it needs a 120v power source. My Casita is on shorepower (30amp), and I think the outlets are only 110v. Is it safe to plug the Lasko heater in to the Casita's internal outlet?
I actually got the heater to put underneath the skirted Casita to try and make it through the winter. When it is under the Casita, I plan to plug it in to the outside electrical socket, but I wanted to test it inside first.
whoot is offline   Reply With Quote
Old 11-14-2015, 10:32 PM   #2
The current house current standard is 120 Volt. That said most electrical devices designed for home are designed to operate anywhere between 90 volts and 130 volts 60HZ.
If you have any doubt look at the specifications in the owners manual.
The outlets are at what ever the voltage is where the trailer is connected to electricity.
Old 11-15-2015, 05:34 AM   #3
We ran a 1500W heater all last winter in our Casita with no problem. Regularly used a toaster oven plugged into the outside outlet with no problem there.
Old 11-15-2015, 07:43 AM   #4
honda03842's Avatar
Name: Norm and Ginny
We have run a 1500 watt heater for years, usually in the morning when we first wake up. We make coffee, toast and have the heater on all at the same time. The coffee pot and toaster are on the same breaker. The heater on another breaker. By the time Ginny starts making bacon and eggs, the place is usually so warm, the vent and window are usually open and the heater off.
Byron's comment about the voltage of AC is absolutely correct. I note the time to make toast seems to vary. I attribute this to differences in the AC voltage.
By the way, we rarely find it necessary to run on 1500 watts at least in our little Scamp. We found the point where the heater thermostat cuts off at 70 F and usually set it there and usually on 800 watts.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 11-15-2015, 08:56 AM   #5
William, you may want to look at what you have for breakers in your Casita. Ours only had one double 15 amp breaker.
Old 11-15-2015, 09:06 AM   #6
Amps times Volts = Watts.
Take the 15 Amps and times it by 120 Volts and you have the wattage of your 15 Amp breaker.
Old 11-15-2015, 10:26 AM   #7
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
I know it's a bit confusing to see some appliances and systems rated at 120v and others at 110v, but it's really all the same. It would be best if everyone would standardize on the same stated voltage. There are not two different standards.
Walt
Old 11-15-2015, 10:28 AM   #8
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
A 1500 watt heater just about max's out the 15 amp circuit so any other draw on the circuit will have to be small . That is - if your fridge or a pump is on the same circuit it would be overloaded.
Bob in Mb is offline   Reply With Quote
Old 11-15-2015, 10:57 AM   #9
J.F.Y.'s Avatar
whoot....
WaltP and Bob in Mb are both right.
And....I have had the same Lasko heater for years and used it without problem. That said, I do not run it on high heat when the AC heatstrips or microwave are in use.
Frank
J.F.Y. is offline   Reply With Quote
Old 11-15-2015, 12:24 PM   #10
New Jersey
Thanks for all the advice, I ran it last night on the "low" setting (900 watts). I don't think I will ever run it at 1500 watts. I think the AC's heat-strip is 1500 watts, so maybe I can save some power by running the Lasko at 900 watts. The heat seemed better distributed inside the Casita, probably because the Lasko is on the floor, instead of in the ceiling. The Lasko is also a lot quieter than the AC unit.
Old 11-15-2015, 02:15 PM   #11
Trailer: Casita 17 ft DLX SD
The NEC has changed the voltage rating of circuits from 110/220 to 115/230 to 120/240.
My Casita (2013) is wired with 12-2 NM which is rated for 20 amps. One problem you may encounter is that Casita uses 15 amp residential grade receptacles . Residential grade receptacles when subject to a continuous load that exceeds 80% of their amp rating have a tendancy to heat and self destruct. A thermostatically controlled heater in many jurisdictions located in colder climates is considered to be a continuous load. An easy solution is to change out the existing receptacle to a commercial grade receptacle . Make sure and connect the wires to the terminal screws of the receptacle. Do not use the pushin terminals on the back of the receptacle !
Old 11-15-2015, 02:42 PM   #12
WaltP's Avatar
SW Virginia
Just a little addition to Steve's comment. The commercial receptacles he refers to are rated at 20 amps instead of 15 and can be recognized by the "lazy T" hole for the hot terminal.
Walt
Old 11-15-2015, 03:39 PM   #13
Walt
They make commercial grade receptacles rated for both 15 & 20 amps
The T slot on 120 volt 20 amp NEMA receptacles is on the left or neutral side
Old 11-15-2015, 03:42 PM   #14
WaltP's Avatar
SW Virginia
Thanks for the corrections Steve. I was not aware of commercial 15 amp receptacles.
casita
Does adding multi-outlet to 12v outlet diminish output? Kudzu Asheville Electrical | Charging, Systems, Solar and Generators 8 05-08-2014 05:05 AM
Source for a 110v exterior outlet FlyboyTJ Modifications, Alterations and Updates 49 10-20-2012 06:38 PM
Ceramic Heater Safety melissab General Chat 24 11-08-2011 08:12 PM
Ceramic heater recommendations? Cam A Care and Feeding of Molded Fiberglass Trailers 16 04-19-2006 03:38 PM
