Canadians Who Bought the 54 Watt Solar Panels at Cosco - Fiberglass RV
Old 05-25-2006, 07:03 PM   #1
Paddy Morris's Avatar
Trailer: 1980 Trillium 4500 Deluxe / 2008 Toyota Tacoma 4x2 Access cab 2.7l
So how did we go about hooking up the three panels? Mine will require me to cut wires, splice them, figure out + - any pics of the Canadian wiring?? Arrrrrrrrrgelite
Paddy Morris is offline   Reply With Quote
Old 05-25-2006, 08:35 PM   #2
Trailer: '74 Ventura
Thumbs down
I "PMed" (is that a word ) - I have a PDF install that is VERY DETAILED with Diagrams, etc - TOO LARGE to upload here - let me know - - -
Also "if" the board wants it for the document center let me know how to get it to you
t & t
ttmatson is offline   Reply With Quote
Old 05-26-2006, 04:23 AM   #3
t & t
That would be great, I emailed you as well, tks Paddy.
Old 05-26-2006, 10:00 AM   #4
Doh! more diagrams This isn't quite what I wanted, or needed, I know all that, I need to see what people DID with the COSCO set up. This is a lot of very good information though, thank you, Paddy
Old 05-26-2006, 02:06 PM   #5
Update for Case #12009 - "54 watt coleman solar kit from Cosco"
>Hello Pat,
>Thank you for using our products.
>Please provide us with your full mailing address and phone number and we
>would be more than happy to send the missing harness (available late May)
>at no charge.
>Thank you for your patience.
>Also, if you wish to splice the wires, we recommend splicing before the
>connector's end without removing the connector, in this way the harness may
>still be used once received.
>A system diagram may be found through our website at:
>http://www.icpsolar.com/4105/system_setup.asp
>Simply connect all solar panels together (+) to (+), and (-) to (-) though
>splicing or when the harness is received.
>Also, the kit does not include wiring from the controller to the battery.
>We recommend using 14AWG stranded wire and installing only a few feet from
>the battery.
>Sincerely,
>Anthony @ ICP Technical Support
>Welcome to the ICP Store, Let Our Power Give You Freedom!
>www.solarcharger.com
>In the meantime, have you registered for our newsletter at
>www.icpsolar.com? This online periodical gives you up to date information
>about solar in general, new products, and even helpful suggestions to help
>you maximize the benefits of the solar solution from ICP that you have
>purchased.
>At ICP, we aim to provide our customers with the best possible care in the
>industry. If you feel at any time that you are not getting the best
>possible service, please do not hesitate to let us know and we’ll have
>someone from our Customer Service management contact you directly.
>Click here to update the Case online, or reply to this e-mail
>Message History
Well this seems promising
Old 05-26-2006, 03:14 PM   #6
Very Promising
Update for Case #12069 - "Wiring Harness for CL3600"
Hello Pat,
Thank you the information, and your feedback.
It has been forwarded to our shipping department who will promptly send once available.
Sincerely,
solar
Adding Solar Panels Bigfoot Mike Problem Solving | Owners Helping Owners 50 09-25-2009 08:59 PM
Solar panels on eBay peterh Care and Feeding of Molded Fiberglass Trailers 8 08-07-2008 07:43 PM
Solar Panels Barbara Gardin Electrical | Charging, Systems, Solar and Generators 7 06-02-2007 09:30 PM
10 watt solar flex mat Dan Simon Modifications, Alterations and Updates 4 08-06-2006 09:26 AM
Solar Panels Legacy Posts Electrical | Charging, Systems, Solar and Generators 13 04-24-2003 09:09 AM
