Carbon Foam Batteries - Fiberglass RV
Old 05-15-2014, 02:46 PM   #1
Night Sailor's Avatar
Connecticut
These batteries have lots of good characteristics, work well in high heat environments, heavy and deep cycling, work well when not fully recharged--they tend to operate best between 80% an 20% State of Charge (SOC). They are also lighter for the amount of power they provide. Disadvantage--need a special charger--can be damaged by over charging.
I am particularly impressed by the thermal conductivity of the materials, which account for their performance in high heat environments, and in faster charging scenarios.
Info Follows:
Invented in the R&D Labs of Caterpillar, by the brilliant founder and CTO of Firefly Energy - Kurtis Kelley.
A sample of Firefly's battery benefits include:
Novel Carbon Foam Technology, yields more uniform heat distribution resulting
in significant inhibition of grid corrosion, producing much longer battery life.
Furthermore, Carbon Foam significantly delays typical destructive and irreversible sulfation, which is common to lead acid batteries. ( we sulfate in particles mostly, common lead acid sulfates in hard to reverse Films of sulfation )
Firefly's Carbon Foam is notably more Electrically and Thermally Conductive than conventional lead plates,
and is completely immune to acid attack.
5C discharge thermal image signature of Firefly is compared to a conventional battery ( conventional battery w hot spots - Firefly is cool as a cumber ) in attached "Slide 1" versus a std lead acid's lead plate.
Substantially higher cycle life - J2185 tests (SAE Soc. Auto Engineers), run hot, at 50C/122F, show that we have 2X - 5X better charge cycling lifetime than any other sealed lead acid battery.
See the 1 page J2185 summary [2 charts], and pages 2 & 3 of the 8 page Cycle Life versus Depth of Discharge report.
If your customers pound on marine batteries, for primary power, extended cycling from electrical accessories, hybrid propulsion and dc microgrid, we take a beating and come back for more.
No marketing hype, no exaggeration, engineering data backing up historic lead acid breakthrough claims.
All from the brilliant expertise of Firefly's CTO Kurtis Kelley starting back in the R&D labs of Caterpillar.
You thought no one would ever make a lead acid service life breakthrough that was compelling?
Here we are shipping, restarted in production since a year ago !
Strongly resistant to heat damage - Firefly OASIS 3D operates easily in extremely high temperatures, far exceeding desert heat life performance of any lead acid battery. The Oasis battery is currently used by two Department of Defense subcontractors. One of which ordered 450 batteries this past year to avoid common quality lead acid short
desert life issues, which were solved by the Firefly OASIS 3D battery. Plus submitted to a new DoD RFP.
In lab tests, after 1200 cycles of 80% deep cycling, Firefly's charge capacity was almost unchanged from the start of test (except for a very gentle slope of tiny capacity loss at 1200 cycles).
The engineering destructive teardown showed the interior had no latent damage.
See last page of 20 page "Intro To Firefly Kurtis and Mat "report
for the capacity versus 1200 cycle deep cycling chart. Very little fade @1200 !!
Low self-discharge characteristics (2.5% /mo) and unprecedented ability to recover after a long period of inactivity/non-use. More specifically, the Oasis 3D battery is nearly immune to significant permanent damage from 6 month extended fully discharged storage in most instances avoiding very high heat.
When storing for 6 months @ zero charge, the battery can be started up upon first charge,
regains 90% of full capacity after approximately five cycles, increasing slightly in capacity recovery thereafter.
Extended Zero state of charge storage Capacity Recovery, impossible in any conventional lead acid,
and a notable distinction of Firefly.
Engineering calculations show operation at 50% depth of partial discharge gains 3600 cycles on its lifetime based on the 1200 cycle data at 80% DoD. ( see attached Cycle Life versus Depth of Discharge report )
Absorbent Glass Mat separators prevent spilling of acid and resist damage from vibration.
The unique stable Glassy Carbon Foam negative electrode, provides a 2000X increase of base electrode surface area, with 60-80% increase in active lead oxide electrochemical surface area, versus common weak flat plate conventional lead negative base electrodes.
Lower lifetime cost due to superior 2x-5x gains in battery service life
60% of room temperature charge capacity sustained at -20c
Lowest voltage droop versus SoC State of Charge. Common Standard Lead Acid at
50% SoC, at times will exhibit 10.5 volts, even lower voltage droop, at yet smaller remaining SoC.
Firefly out to low residual 20% SoC (80% empty) typically outputs 11.4volts,
again extraordinary, unusual for lead acid.
Capable of Ac Welding Fast Charging / huge charge acceptance. between 20% SoC and 80% SoC, if properly configured, single batteries can reliably sustain 250 amp charging to 80% SoC. ( final test at factory charges at 250 amps all of our batteries - ALL ) Past 80% SoC - slow down ....
We do not recommend blindly charging strings at 250 amps per Group 31 series string, but we assume decently matched Group 31 strings can charge at between 100-200 amps, conservatively, but needing monitoring - possibly an advanced BMS we are looking into sourcing ( early now ). If you can rig up voltage and or temperature monitoring you can catch problems in fast charging, we urge this be done for safety.
If all you need is extraordinary long life, and want fastest charging turnaround, charge to 80% SoC and do this in 30 minutes with highest power 250 amp chargers ( run lower initially and if fastest use sophisticated BMS battery monitoring systems interlocked to charger ). Try that in any other group 31, try that in Lithium Ion and you might
risk a fire !
Above 80% SoC charging, water electrolysis kicks in, monotonically increasing parasitic resistance losses, slowing charging in last 20% of topping off ( which we recommend against if avoidable ) See the 2 graphs in the Sweet Spot PSOC presentation of resistance and losses versus SoC State of Charge. ( around pg 5?)
Old 05-15-2014, 03:10 PM   #2
Carbon Foam Batteries?
That's a lot of sales hype and technical/engineering information without much information about RV applications such as Amp Hours, sizes available, weight, what kind of special charger is needed and prices..... In short, what's the advantages to RV apps. and what will that advantage cost?
Modern 3-4 stage chargers (i.e. PD-4045) offer a desulfating cycle and controlled charge rates. And life expectancies of lead acid batteries is about 5 years with a decent charging system. Something new would have to be a lot less expensive or have huge advantages to gain a foothold hereabouts.
And, whoever Kurtis Kelly is, he must be brilliant to get that much hype.
Old 05-15-2014, 04:27 PM   #3
Battery Information: http://www.trojanbattery.com/tech-su...y-maintenance/
Everything you want or do not want to know about batteries.
Old 05-15-2014, 04:55 PM   #4
That's a great resource for lead acid flooded batteries, but the question was about the touted Carbon Foam batteries in post #1, especially the cost.
Old 05-15-2014, 05:18 PM   #5
reeves99's Avatar
Trailer: Escape 13 /Hyundai Santa Fe
Presumably they'd weigh a lot less than a lead acid battery so might be practical for an RV. Cost??? Probably exorbitant!
It's not the size.....
reeves99 is offline   Reply With Quote
Old 05-15-2014, 05:56 PM   #6
That's the usual situation with miracle improvements, they usually cost way more than they ever return.
Old 05-15-2014, 07:17 PM   #7
That's why I posted the everything U need to know about batteries site. It covers batteries that you can get almost everywhere at great prices and with great warranties. Walmart for example.
Old 05-15-2014, 07:33 PM   #8
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Geeeez Bob!!!
Don't worry, be happy!!!!
Spanke
Trilliums Rock!
Old 05-16-2014, 08:55 AM   #9
Connecticut
http://fireflyenergy.com
Old 05-16-2014, 09:22 AM   #10
Trailer: Helite
So what is the cost??
Art VanDelay is offline   Reply With Quote
Old 05-16-2014, 09:33 AM   #11
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Firefly Oasis 12V Group 31 Deep Cycle Battery for RV'S | eBay
$325.00 for the 12 volt 100 amp
Dave & Paula
Old 05-16-2014, 11:13 AM   #12
Trailer: 77 Scamp 13
Sounds like a premium price of ~$120 for a little less overall capacity than say a Trojan group 31 battery. However since they can handle deeper discharge the usable capacity is pretty close.
If you needed heat durability, lighter weight, or rapid charge ability say to run generator for shorter period of time to charge the battery they might be worth the premium cost.
How well they work with solar and the slower longer charging from that would be my question.
Old 05-16-2014, 11:36 AM   #13
Dave & Paula
Plus $75 shipping = $400, must not be all that light.
Again, at 3x the cost of a conventional battery, why?
Old 05-16-2014, 11:52 AM   #14
A conventional dedicated deep cycle battery such a Trojan (another premium brand) would run $200 +/- and possibly shipping.
Most of us don't get the usage from our camper RV battery to make anything beyond the basic $90 RV battery worth buying. Some might get the use to justify a premium battery such as Trojan at twice the cost. Might be some use cases where even the $325 would make sense.
I'm not one of those that are in the market for premium battery but it is interesting to hear and find out what is out there.
Anyone have experience with NU-FOAM vs Foam for seat cushions? Perseustheegg Modifications, Alterations and Updates 0 08-17-2012 02:20 PM
memory foam vs foam rubber mattress Phillip Problem Solving | Owners Helping Owners 11 06-28-2009 07:52 PM
Low carbon footprint tow vehicle Dana T General Chat 0 05-16-2009 03:57 PM
Reduce your carbon footprint Donna D. General Chat 9 03-16-2009 12:05 AM
Carbon Monoxide Measurements Parker Buckley Problem Solving | Owners Helping Owners 23 03-04-2009 06:36 PM
