Casita Battery Charger mods for adding a AGM battery? - Fiberglass RV
Old 02-13-2019, 02:57 PM   #1
Trailer: Casita SD 17'
I am looking at adding a AGM style battery to replace the standard Lead Acid battery. What changes will I have to do to my 2005 Casita Spirit Deluxe battery charging circuit to maintain the AGM battery?
Doctoruv
doctoruv is offline   Reply With Quote
Old 02-14-2019, 08:07 AM   #2
South Carolina
my casita has an upgrade progressive dynamics 12v portion of the converter. no modification needed to work with 2 6v agm golf cart batteries. i did have to modify the 2 morningstar solar controllers as per morningstar's suggestion. i used the provided bridge gizmos (technical term) to eliminate the float stage (i think). in case you can't tell, i'm certainly no electrician but all seems to work well.
p@
patrick crawford is offline   Reply With Quote
Old 02-14-2019, 01:51 PM   #3
For a simple fix, no changes are needed. For a comprehensive one, remanufacturing the inadequate electrical system is needed.
Stephen_Albers is offline   Reply With Quote
battery, casita
Charging AGM battery NEWYORKHILLBILLY Modifications, Alterations and Updates 56 02-06-2018 06:17 PM
Parkliner Electrical System & AGM Battery Charging-Maintaining accrete Electrical | Charging, Systems, Solar and Generators 15 05-16-2013 06:03 PM
AGM Battery ? jck Care and Feeding of Molded Fiberglass Trailers 29 12-28-2012 04:46 PM
Got a 2nd battery, AGM, 2 questions?! dylanear Modifications, Alterations and Updates 13 07-28-2012 02:47 PM
