centurion 3000 in 16' scamp - Fiberglass RV
Old 09-23-2015, 05:51 PM   #1
Illinois
So, I'm going over the new trailer and making a to do list. First order of business is determine all of the problems.
It appears the centurion 3000 converter/power center for this trailer has a problem on the 12V side.
There is a fairly large silver heatsink looking piece that is not at 90 degrees with the circuit board. At first I couldn't get any 12V things to work/battery is hosed. But after taking the screw driver and moving that heat sink around all of the 12V pieces fired right up. Messed with it a bit more and the power fluctuated.
So I assume this is hosed and I need to pull and replace with something else. I found this:
WFCO 8735P Power Center
and read elsewhere is was a drop in replacement for the converter in the Scamp, is that the case?
jcassady is offline   Reply With Quote
Old 09-23-2015, 08:10 PM   #2
This kind of topic makes my head hurt. Do you have a question we can help with? What are you trying to accomplish.. exactly?
Old 09-23-2015, 08:49 PM   #3
Illinois
Sorry that was rambling and not clear.
Just wanted to know if anyone has had issues with the converter in a 16 foot scamp, and what if anything they replaced it with.
Old 09-23-2015, 08:51 PM   #4
WFCO is the Yugo of power converters and, while inexpensive, are known for a high board failure rate. Scamp used to use them and has since dropped them.
My weapon of choice is the Progressive Dynamics PD-4045, I have installed about 7 of them, including in my own Scamp, They are available on line for about $160 and will upgrade your electrical system/converter/charger to 2015 standards.
Old 09-24-2015, 07:25 AM   #5
Illinois
Thanks for the information.
Do you know if the Progressive Dynamics PD-4045 is a drop in replacement for the current one in my trailer, or will I have to modify the cabinet to get it to fit?
Old 09-24-2015, 10:28 AM   #6
"Drop-In" No, easy to install? Yes if you have basic mechanical & electrical skills and a few tools. It was in the left dinette seat wall.
In replacing an American brand converter in out Scamp I had to enlarge the cut out slightly and re-do a few wires.
Old 09-25-2015, 09:03 PM   #7
Trailer: Scamp 16 ft
Remove the centurion 3000 converter and take it to an electronics repair person. The problem is broken solder joints on the pc board. If you have a hobbyist friend, you may get it fixed for free. All that bouncing on the road is hard on converter parts. Mine had problems also until I pulled it out and re-soldered the broken joints. Use hot glue to stabilize the large parts on the circuit board when you are done.
Richard S. is offline   Reply With Quote
For Sale: Ultra-Fab Odyssey 3000 Electric Tongue Jack Black 3000 LB - Bellingham, WA lonnyda Parts: Buy | Sell | Trade 0 10-27-2014 09:17 AM
Centurion 3000 Converter issue: flickering lights on DC power Shannon Thompson Care and Feeding of Molded Fiberglass Trailers 1 01-27-2013 06:45 AM
1982 Scamp 13ft $3000 Robin G Classified Archives 0 05-26-2009 01:18 PM
13ft Scamp $3000 Robin G Classified Archives 0 04-17-2009 03:57 PM
SOLD - 1973 13' ECO egg for sale~ $3000 (Scamp Clone) Pat Johnston Classified Archives 7 08-11-2008 06:47 PM
