So, I'm going over the new trailer and making a to do list. First order of business is determine all of the problems.
It appears the centurion 3000 converter/power center for this trailer has a problem on the 12V side.
There is a fairly large silver heatsink looking piece that is not at 90 degrees with the circuit board. At first I couldn't get any 12V things to work/battery is hosed. But after taking the screw driver and moving that heat sink around all of the 12V pieces fired right up. Messed with it a bit more and the power fluctuated.
So I assume this is hosed and I need to pull and replace with something else. I found this:
WFCO 8735P Power Center
and read elsewhere is was a drop in replacement for the converter in the
Scamp, is that the case?
