Hey there,
I got a question in regards to my
Trillium camper 12v
battery. Its a deep cycle that can do 65amp/hour for 20 hours.
I did some research and from what I understand, this would mean I could use 3.25amp for 20 hours, is that correct?
So here is my question. I just installed a 12v outlet:
https://www.amazon.ca/gp/product/B07...?ie=UTF8&psc=1
Specifications:
Car Power Socket:
LED Display: Blue LED
Light
Car Power Socket Input Voltage: 12-24V
Car Power Socket Output Voltage: 12V 15A 24V 10A
Attention: Can not
light cigarettes
2 In 1 Double USB with Voltage Display:
Input Voltage: 12-24v
Output: 5V 4.2A DC(Total)
USB Port: 2 pcs
Detecting Voltage Range: 6-28V
Voltage Display: LED Blue
Light
Small Switch:
Current: 15A
Material: PA66 environmental protection material
Shell Color: Black
Is there an easy way to calculate how many hours I could charge my phone on the USB port before the
battery runs out? I think the 2 usb port are 2.1amp each. Does that mean that if I charge 1 phone in the 2.1amp socket I could charge for 30.8hours before the
battery runs out?
What is the difference between the current (15amp) and the output of the device (4.2amp)? Do I need to use a 15amp fuse in my fusebox?
Thanks alot for your answers, much appreciated.
