Compact Absorption refrigerators 12V - Fiberglass RV
Old 08-03-2017, 08:39 AM   #1
Does anyone have any experience with these? Do they work better than the peltier ones? How cold do they get?
https://www.amazon.com/SMETA-Compact...dp/B072HNBNZZ/
https://www.amazon.com/dp/B01KRFS58Q..._t3_B072HNBNZZ
jeroen is offline   Reply With Quote
Old 08-03-2017, 08:59 AM   #2
Absorption sounds a lot like the ammonia cycle refrigerator that is standard in a lot of our trailers, except only using electricity instead of the propane option.
Terry G is offline   Reply With Quote
Old 08-03-2017, 09:25 AM   #3
skyking's Avatar
Trailer: Sold 2017 Casita SD
solid state refrigerator
Peltier modules are only around 5% efficient, some as high as 10% and low as 2%. Also they usually only cool about 36 °F below ambient temperature, so don't expect 30deg in the fridge when its 90deg outside.
skyking is offline   Reply With Quote
Old 08-03-2017, 09:47 AM   #4
The Minimalist's Avatar
Louisiana
To clarify; absorption refrigeration is the same as what you are calling the ammonia cycle. They may use AC, DC or propane as a heat source and some can use any of the three; only one at a time of course.
As many of us on this forum have discovered, installation with proper ventilation is as important as having a properly functioning unit. The fridge can only remove heat from the box if the condenser coils can dissipate heat to the ambient air. And of course, ambient air temperature has a direct effect on heat dissipation, regardless of proper air flow.
Good luck in the search.
Clif
Old 08-03-2017, 09:50 AM   #5
Ohio
It is absorbing heat and moving heat from one place to another.
cmartin748 is offline   Reply With Quote
Old 08-03-2017, 11:31 AM   #6
Johnny M's Avatar
Deep South
If only you could have some kind of absorption unit to pre cool the air to then cool the coils on the fridge...
1971 Boler 1300 - "Suite 13"
1987 Play-Mor II - "The Beach House"
Old 08-03-2017, 11:41 AM   #7
Louisiana
Yeah, like a chiller on a large commercial AC or refrigeration unit. I guess you could mount some sort of evaporative cooler panel on the lower intake, which might help in dryer climates.
Clif
Old 08-03-2017, 11:51 AM   #8
Johnny M's Avatar
Deep South
Here is a refrigerator from SunFrost that uses only 12 amp hours per day 12vdc at 90 degrees, and only 8 amp hours at 70...They also have one with an ice tray compartment...might be a viable option...
R4 Energy Efficient Refrigerator
Old 08-03-2017, 12:00 PM   #9
It costs $1,875 and on top of that they charge your a $45 crating fee, for something smaller than a $130 mini fridge at Home Depot.
With solar panels being well under $1/watt I don't think it's worth it at that price.
Old 08-03-2017, 12:08 PM   #10
Trailer: Trails West
The best option for making sure things will stay cold enough to meet food safety standards is to get a unit that is rated for freezing as well as refrigeration above freezing. Do a search on "12 volt fridge freeze".
Yes they cost more but you do need that type if you to have want reliable cold storage temperatures. And you do want to have that
Don't worry about what they call it, just pay attention to the temperature range it is rated for. If it does not cool below the freezing temperatures don't waste your money on it. The ones that don't go below freezing can't be relied upon in hot summer weather to keep your food safe or your drinks refreshingly cold.
Old 08-03-2017, 01:04 PM   #11
Raz
Raz's Avatar
At 65 watts on DC these will use over 5 amps continuous. In one 8 hr night it would drain a group 24 battery to 50%. On AC a dorm fridge would work better at half the cost. Peltier effect is too inefficient to be useful, don't waste your money. Unless you use a generator there are just three off grid options. Ice, propane, or DC compressor like the danfoss. The last one still requires significant recharge capability. Three way fridges show up used on Craigslist from time to time.
Old 08-03-2017, 01:15 PM   #12
Johnny M's Avatar
Deep South
We recently came back from a trip with a cooler full of ice and had our breakfast sausage, deli ham and some hotdogs on top in a plastic zip lock baggie to keep water out and to keep from contaminating our ice for drinks. I put 10 lbs of ice in it when we left FL and when we got home (6 hours or so later) I used a digital thermometer to check the temperature of the meats and the sausage read 60 degrees sitting on top of the ice with the lid kept closed during the trip except for an occasional drink or ice accessed out of it. There was still ice but more than half had melted. None of it was below 40, we threw it all out...
For that reason I am seriously considering our options for on the road refrigeration, either an inverter for our dorm fridge or another type of DC powered unit...
refrigerator
Run 12V TV/monitor off of 12V outlet or via inverter? Rod Scher Problem Solving | Owners Helping Owners 24 06-19-2021 07:58 PM
PSA: Mobicool A40 3-way absorption cooler Roy in TO Modifications, Alterations and Updates 60 05-30-2014 12:10 PM
Performance of 3-way absorption fridge Daniel V. Problem Solving | Owners Helping Owners 26 04-29-2009 03:23 PM
Help with older model refrigerators Phillip Krueger Problem Solving | Owners Helping Owners 3 06-11-2007 09:53 PM
Casita Refrigerators Lisa M. Problem Solving | Owners Helping Owners 6 05-22-2007 12:28 AM
