Converter replacement - Fiberglass RV
Old 04-11-2017, 08:05 PM   #1
Lorie Q's Avatar
Wisconsin
I'm trying to buy a new converter for my 2004 Scamp 16. I have a few questions that I hope ya'll can help me with so I get the buying right without a bunch of returns or waiting for supplemental ordering.
Can I replace the 30 Amp converter with a 45 Amp or do I need to stay with the original because of wiring requirements or panel match up?
The reason I ask is, I'm replacing the American with Progressive Dynamics and I've read (somewhere in this forum) that the PD is not going to fit neatly into the existing space where the original was.
Am I also going to need a new breaker panel and cover? Or does anyone recommend replacing these while I have the thing all apart anyway?
The PD9130 doesn't come with a charge controller 'wizard' but the 45+ converters do.
Thanks for your input!!
Lorie
Lorie Q is offline   Reply With Quote
Old 04-12-2017, 11:25 AM   #2
Kenny Strong's Avatar
Trailer: Bigfoot 13'
Utah
My convertor does not charge the battery when hooked up to a 120 outlet. It charges only from connection to the tow. I have seen such convertors on the web. (Amazon) Mine now is charged with solar all the time when it can. I was going to buy a battery charging unit, in the past.
Kenny Strong is online now   Reply With Quote
Old 04-12-2017, 11:31 AM   #3
Joe & Cherie's Avatar
Trailer: 2013 EggCamper & 2011 Silverado Reg Cab 4x4
Ohio
PD9130
Hi Lorie,
I have a PD9130 in my egg and although it does not have a built in charge wizard, you can add the remote charge wizard pendant for another $25 or so. It just plugs right in to the back. I agree tho it's crazy that you have to do that to the 9130 when it should just be built in!
I'm not sure on the upgrade or fitment tho. I did have to replace a converter on a Casita a few years back and I did go bigger and it bolted right in.
2013 EggCamper #120
Joe's EggCamper Journal
Joe & Cherie is offline   Reply With Quote
Old 04-12-2017, 11:56 AM   #4
I upgraded my Scamp to a Progressive Dynamics PD-4045. It works very well and my trailer is plugged in 24 -7 and I need to less than a table spoon of water to the battery in a years time.
Whether or not you can use a 45 amp rated controller is based on your power pole supply at the camp site and if the power cord on your trailer will need to upgraded. Your cord has a specific connector and its rating and the cord itself has a specific wire size inside. The wire should be stamped on the outside with the wire size inside. Markings will be like 10-2, 10-3, 12-2, 12-3, or any other combination. these numbers mean allot to an electrician and they can tell how good the cord would be in your application. What you cant do is draw more power than the cord and plug and power pole can supply and your main breaker must be low enough to protect the supply line from over draw.
You really need some one with proper knowledge to do the conversion so you and your trailer are safely protected.
30 amp cord and plug will usually be a 10-3 cord.
50 amp cord and plug will usually be a 6-3 cord
20 amp cord and plug will usually be a 12-3 cord
Old 04-12-2017, 01:11 PM   #5
Trailer: Casita 17 ft DLX SD
The 45 refers to the ampacity the converter can produce at
12V DC to run your 12 V DC loads . 45 amps at 12 V = 540 watts or the converter will draw approx 4.5 amps at 120 VAC.
The main breaker in the converter's load center is sized based on the ampacity of the service cord and the ampacity of the load centers bus
A 10/3 cord has an ampacity of 30 amps so you could protect the cord with a 15 or 20 or 30 amp single pole breaker.
I would buy the PD converter with the built in battery charger , 12 volt DC power supply , DC distribution center and 120 VAC load center.
The service cord to your trailer is required to be 3 wire , with #14 AWG being the minimum conduct size.
Black = Line / hot conductor
White = Grounded / neutral conductor
Green = Equipment grounding conductor.
The neutral conductor is NOT bonded at the load center.
It must be electrically isolated or floating.
The neutral IS a current carrying conductor.
The equipment grounding conductor is bonded at the load center and bonded to the trailer frame
Old 04-12-2017, 01:29 PM   #6
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
The American CS2000XL converter bit the dust on me this winter*, and I had the same dilemma. Upgrade or replace with equivalent?
Considering the cost and the fact that our power consumption is anything but down from what the previous owners used, I looked for the same. No need to upgrade here. Also, the direct replacement has the advantage that it fits, the wires connect the same, etc.
Keith at keithsrvsurplus.com in Plymouth, IN sold me one for $65 plus $14 shipping. That sure beats $150 or $250 or so for an upgrade.
*) At one point I thought it simply was overheating when the airflow may have been restricted. The 12V was pulsing and the fan was not turning but it turned out that the fan is good, the circuitry was dead.
Old 04-13-2017, 06:11 AM   #7
or you could just....
get rid of the converter altogether....
instead of having a converter convert AC to DC when plugged in (through a relay to most of your DC circuits).....have ALL DC circuits fed from the battery all the time...all you need is a "smart" charger...one rated to deliver/charge at more amps that what you think your maximum demand/use will be
just one more option to consider...a bit more "involved" than just buying/installing another converter however...if one is not comfortable working on/understanding things electrical then a new converter is simpler/quicker
Franswa is online now   Reply With Quote
Old 04-13-2017, 06:57 AM   #8
Lorie Q's Avatar
Wisconsin
I first started researching the switch to a 100W solar panel. I think my energy needs are low. I might need a laptop or small tv, but not for hours and days. The one thing I do love is that fan over the bed and that could be running on DC for 8 hours straight.
I resolved to simply replace the converter based on the logic that my kids are only 11, 15 and our camping excursions will be simple & straightforward for the next few years. (At a campground on weekends, with shore power available almost all the time)
My Scamp is my retirement house, though, and I will eventually want to be as close to zero $ cost as possible. So the solar is definitely going to be in my future.
The original American converter that I thought was dead - I never considered the idea that the only charge for my Scamp battery be the tow connection. I have a Sienna van with a 4 pin, not a 7 pin. So I've only been trying to recharge from shore power to my house.
Adding a new question- do I have to upgrade to a 7 pin tow?? That's another couple hundred bucks I hoped not to add to my leased vehicle.
Thanks all!!!!
Old 04-13-2017, 07:18 AM   #9
Lorie Q's Avatar
Wisconsin
Franswa- Thanks for the photo of the smart charger. I do want the smart charger. Is that not what the "charge controller" does? That wasn't clear when I was researching the different replacement converters.
Old 04-13-2017, 07:26 AM   #10
Thanks all!!!!
We have a functioning converter , solar panel and a 7 pin trailer plug for the reasons that we don't always camp with hookups and the sun doesn't always shine.
If you have , need or want trailer brakes and want to charge your trailer battery from your tow vehicle then the 7 pin is a necessity .
Whether you want to spend the money on a rental car is another question only you can answer.
We have 5 children , ages 45 to 32 , so a word of warning !!
If your children are only 11 and 15 don't count on them being gone in a "FEW " years.
Old 04-13-2017, 11:24 AM   #11
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Steve, do your children use the camper? Our oldest has started occasionally using ours.
John in Michigan is online now   Reply With Quote
Old 04-13-2017, 11:36 AM   #12
Our 2 youngest children still live at our home so we moved to our lake house.
Our older children have their own trailers and go camping with us in the summer.
When I was younger you were shown the door when you turned 18.
I got married when I was 20. It seems now days kids stay at home with their parents forever.
Old 04-13-2017, 12:13 PM   #13
PD power converters vs. PD power centers
Lorie
Lorie Q, looking at the PD website, it appears that even the 45+ converters require purchasing the charge wizard as an add-on.
Instead consider whether a PD power center such as the PD4045 would fit. As others mentioned, a PD power center such as the PD4045 includes a charge wizard AND its a total package including the AC circuit breaker panel (so AC circuits can be added), DC power supply, DC fuse panel, and charge wizard (a smart charge controller).
Old 04-13-2017, 01:30 PM   #14
Ohio
quote from Trojan's website
Most deep-cycle applications have some sort of charging system already installed for battery charging (e.g. solar panels, inverter, golf car charger, alternator, etc.). However, there are still systems with deep-cycle batteries where an individual charger must be selected. The following will help in making a proper selection.
There are many types of chargers available today. They are usually rated by their start rate, the rate in amperes that the charger will supply at the beginning of the charge cycle. When selecting a charger, the charge rate should be between 10% and 13% of the battery’s 20-hour AH capacity. For example, a battery with a 20-hour capacity rating of 225 AH will use a charger rated between approximately 23 and 30 amps (for multiple battery charging use the AH rating of the entire bank). Chargers with lower ratings can be used but the charging time will be increased.
Trojan recommends using a 3-stage charger. Also called “automatic”, “smart” or “IEI” chargers, which prolong battery life with their programmed charging profile. These chargers usually have three distinct charging stages: bulk, acceptance, and float.
If this is true - wouldn't one opt for no bigger than a 30A replacement for any battery setup under 225AH?
2013 EggCamper #120
What size replacement converter? Timber Wolf Electrical | Charging, Systems, Solar and Generators 20 08-08-2015 09:16 AM
Trillium 4500 replacement converter? spotcatbug Modifications, Alterations and Updates 68 07-23-2013 10:58 AM
Battery replacement= Converter clicking on/off iplumb Electrical | Charging, Systems, Solar and Generators 11 03-31-2013 03:52 PM
Hookup for replacement converter rabbit Electrical | Charging, Systems, Solar and Generators 9 08-27-2012 05:51 PM
Replacement converter/charger Davie B Modifications, Alterations and Updates 13 06-30-2011 05:25 PM
