Converter thoughts - Page 2 - Fiberglass RV
Old 09-21-2013, 03:29 PM   #15
peterh's Avatar
Roy, I prefer to have each of those things -- converter, AC distribution & breakers, DC distribution & fuses, solar charge controller -- in different units, because that way I can pick and choose the best unit for my needs and can replace a failed battery charger or solar controller more easily if the need arises or a new technology comes out that I just gotta have. (Unlikely.)
In our Scamp, our 100w of solar panels do the job for us. Don't need a converter . . . we have one, but don't even bother to turn it on, even when it's parked. We'd rather float-charge our battery with a BatteryMinder.
For our Surfside project trailer, I'm buying the parts separately, purchasing a BatteryMinder float charger (instead of a converter), MPPT solar charge controller, 9-circuit 12v fuse board, and a 2 circuit, 30A load center and breakers. I'm figuring the lot will run me around $200, with most of that going to the MPPT charge controller and BatteryMinder.
Old 09-21-2013, 06:52 PM   #16
Trailer: 1980Trillium 1300
Originally Posted by Brandegor View Post
Hey folks. My Scamp is without a converter at the moment, and this guy is for sale for $60. Any thoughts?
You have your own choice, Buddy. Hopefully you have good knowledge ab electrical, then utilizing it(converter) into your needs then everything will be OK. I think I have an identical one with yours and paid 30bucks. Make the story short, how about look into some photos of my modified Trillium with more electrical outputs than the trailer actually needs after modification????? It has total of 4x120VAC outlets, 4x12VDC outlets, rear floodlight, 4x120v interior bulbs, 6x12v interior bulbs, water pump, fan,electric heater/air conditioner. All the bulbs are on at the same time with....NO PROBLEMMO. Main cct breaker is rated at 30Amps....Share with you...No mention ab a POWERFULL SUCKING ceiling fan I recently added and a 5000BTU A/C on the process of modified housing for snap on without photos yet...
Old 09-22-2013, 12:21 AM   #17
Originally Posted by Donna D. View Post
Does this need to be an all or nothing decision? For the cost, I'd get it. No one says you have to use it all the time. I bet even Byron plugs into the electric bush when it's available, even if he doesn't purposely seek it out.
Can't say that I agree. Buying that particular converter is like buying a tire that's already 6 years old. It might work for a couple of years or for a couple of weeks. It's old school and plain old as well.
And a 6 amp capacity isn't going to do much for a battery if anything else is on and, with no control, could fry a battery if left ON for to long with no other loads.
I'd sooner put my $60 on Lottery tickets, at least that way you know what your odds might be.
Old 09-22-2013, 06:50 AM   #18
Bob, I didn't necessary mean that particular converter, just one that works as needed/wanted. In the grand scheme of things, they're pretty cheap. Other posters were saying it was an all or nothing decision and for that I disagree. Some want everything built in, others don't mind hauling totes full of parts and stuff to accomplish the same thing.
Old 09-22-2013, 07:12 AM   #19
Roy in TO's Avatar
That makes a lot of sense peter.
Old 09-22-2013, 07:16 AM   #20
Trailer: 2014 Escape 21
Virginia
Costco's are selling 4 stage battery tenders for $39.95. in the Va. stores. They come with an extra lead that attaches to your battery with a plug on it that makes attachment easy.
Eddie
Battery Tender Plus - Batterytender.com
Old 09-22-2013, 07:22 AM   #21
cpaharley2008's Avatar
Nice set up Thinh...
Jim
Never in doubt, often wrong
Old 09-22-2013, 09:15 AM   #22
Roy in TO's Avatar
While looking up BatteryMinder, I found an interesting video on battery care:
RVEducation 101 RV Video Tips
Peter, do you have any suggestion on which models would serve our purposes?
http://batteryminders.com/store.php?spawner=icon_home&&app=rv
Old 09-24-2013, 10:41 AM   #23
peterh's Avatar
Roy, that depends a bit on how you use your trailer. For us, who have 100w of solar panels, rarely camp during the winter, have a catalytic heater to save electricity, all LED lighting, and a very energy-efficient 12v TV/Radio/DVD player, our solar panels provide all our electricity and and our 1A BatteryMinder trickle is only needed when our trailer's under cover.
The 1.33A BatteryMinder "22117", is a lot like ours and looks like a plug-in "wall-wort" power adapter for an electronics device of some kind. It would be a good choice for most trailer users with moderate power needs. Over the course of a day it'll provide 30 Amp hours of power, enough for people who have LED lights, only use their 12v gas furnace at night, and light use of high-demand 12v power devices like water pumps and inverters.
Their "2012" charger, a 2 Amp unit with a temperature sensor for the battery, would be the choice for people with larger demands on their 12V system and camp with hookups, or people who live in very hot or cold climates. Depending on where your trailer lives during Toronto's winters, that might include you, Roy.
Old 09-24-2013, 11:43 AM   #24
Tim Wood's Avatar
Trailer: Class B for now
NY
I wouldn't buy it. I'd spend the money on a Battery Minder, Battery Tender, etc. instead.
Your 12 Volt system runs off the battery and all you need is a way to keep the battery charged or recharged after a bit of use. A converter is an expensive way to accomplish the goal.
+1, I have done this and would do it again with a Battery Tender.
Your thoughts? Cheri in MN Modifications, Alterations and Updates 24 10-02-2012 09:42 PM
I need your thoughts please Cat futrell Problem Solving | Owners Helping Owners 8 08-04-2012 09:15 AM
What are your thoughts? LiL Snoozy General Chat 70 06-11-2011 02:32 PM
trillium thoughts Stoney General Chat 18 09-12-2010 06:26 PM
Second Thoughts Carl O General Chat 16 02-24-2007 10:36 AM
