CPAP on battery power issues? - Page 4 - Fiberglass RV
Old 08-16-2014, 07:23 AM   #43
Roy in TO's Avatar
Originally Posted by warezdog View Post
find your local interstate battery warehouse distributor, not a retailer, and walk in and ask for a blem.
I remember my dad doing this with GM in Oshawa that has or had a battery plant (Delco). Any autoworkers here that might know if this type of thing still exists?
I've seen "blemished" Optima's listed for sale on kijiji here in Southern Ontario. I think it is a battery distributor somewhere around Ajax.
Old 08-18-2014, 12:06 PM   #44
Trailer: In the Market
Maryland
Just called my local interstate warehouse again this morning for the heck of it, they had 3 group 31's one was a deep cycle $35/$55 and a hand full of 27's for $25 all 90 day free swap warranty.
warezdog is offline   Reply With Quote
Old 08-22-2014, 07:45 AM   #45
Trailer: Aliner folding & Weekend Warrior toy hauler
Ohio
Originally Posted by Paul Braun View Post
For used batteries try local home medical suppliers. The places that rent or sell mobility chairs....
Good advice. My son is a wheelchair/scooter tech. On the high end units they swap out the batteries every 18 months.
He keeps me supplied with MK Battery 12v group 24 gel batteries. I can get years of service out of the used batteries. The downside is they are heavy and only 73 ah @ 20 hr.
Shopping for a fiberglass TT
Currently own;
2009 Pontiac Vibe pulling a 2009 Aliner Sport = 22 MPG
1998 Ford E150 pulling a 2006 Weekend Warrior toy hauler = 8 MPG
beemerphile1 is offline   Reply With Quote
Old 08-22-2014, 08:36 AM   #46
Trailer: Escape 19 ft (sold) Escape 21 May 2014
Wisconsin
I have had the best luck calling locally owned places that sell or rent durable medical equipment. The big chains and hospital owned shops do not want or can not deal with a request for old batteries. I always ask for the technician who works on the units.
Your results may vary across the country as to what you find. Locally, they seem to be using dual flooded 12 volt deep cycle marine batteries in a 24 volt array. They also have smaller batteries from chair lifts. My guess a lot depends on what brand the local store sells.
It seems all their old batteries go for recycling so the friendly stores are more than willing to part with old units.
Paul Braun is offline   Reply With Quote
Old 08-27-2014, 12:12 AM   #47
DougOlson's Avatar
I don't have my Scamp yet, but do use a Respironics System One CPAP w/o humidifier in my tent trailer. I use a 30W solar panel to recharge an 18AH AGM battery every day and it works fine. Typically the battery voltage will go from 12.9 to 12.2 overnight and will recharge fully with 3 - 4 hours of good sun.
Sent from my SM-T310 using Fiberglass RV mobile app
DougOlson is offline   Reply With Quote
Old 08-27-2014, 07:13 AM   #48
Welcome to the forums Doug,
That is a good solution. I have a similar battery to yours that I use to extend my stay another day when using the CPAP. I have not field charged it, I just wait until back home to re-charge. My solar is set up to charge the Scamp battery, so wouldn't work for the small AGM without some selector switches and setting changes on the controller. I use a small CTEK charger for the AGM when at home.
Russ
Old 08-27-2014, 08:06 AM   #49
Timber Wolf's Avatar
North Florida
Russ
I have seen some small wattage panels advertised as no controller required. I wonder if one of those tossed on top of the tug or trailer might not at least give you a trickle charge on an AGM without hurting it. Maybe use that battery first on your trip for a night and then charge it over the next few days and squeeze out another night or two? I have a full solar setup but bought a cheap little panel just for the kid and I to play with for a fan and stuff.
Old 08-27-2014, 09:47 AM   #50
DougOlson's Avatar
I have a 5W panel that does not require a contoller that I used initially (before using a CPAP) but it was not enough to keep the battery charged up, even using it for led nights and charging cell phone.
Old 08-27-2014, 07:12 PM   #51
The small panels that can be safely used without a controller wouldn't provide the correct properties to charge a 20ah battery to max. I have a small panel that runs a refrigerator coil cooling fan directly with no battery, and it could probably trickle charge a very small battery, but not optimally.
Russ
Old 09-04-2014, 10:36 AM   #52
Ok, here's an update.
We went on another 4-night trip. Having charged the battery for two weeks on the converter.
Night #1= Nothing-won't even power up the CPAP, even with inverter. BAD NIGHT!
Day #2= take out the battery on the passenger side of the TV (Dodge 2500 with 2 Batteries). Replaced it with Casita Battery. Drove around for a couple hours. Scouted out new camp sites, checked on huckleberry fields, etc... Then swapped the batteries back.
Nights 2-4= ran steady on 12v supply, no need to get out the inverter.
Day #5= swap Batteries again to charge on way home. Swap back again, when home and put Casita Battery on float charger.
It would appear my converter is not charging my battery. I've looked it up, it is supposed to charge my battery. Yet another thing the PO lied about.
At least I can now make sense of why my big Marine Battery provided less capacity than a tiny starting Battery.
I don't know that I'll replace the cconverter? I don't store the battery in the trailer. I may just get a quality 3-stage or two to keep in the garage.
I've also decided to go with two Battery systems.
2x 6v DEEP CYCLE on the tongue. To be used exclusively for my CPAP. Also to be powered by TV, while in transit.
Current group 27 (to be replaced by true deep cycle 12v when necessary) in factory location. This will be for lights and fans. That way I don't have stress about the family stealing my "so I don't die in my sleep" power. It would be nice to run the MaxxFan at night, too.
"Never confuse motion, for action."
-Ernest Hemingway
hariph creek is offline   Reply With Quote
Old 09-04-2014, 11:57 AM   #53
Alabama
Jorah, Bummer! I'm not sure I followed everything you did and then tried to do to remedy the problem, but I think each separate component of your whole battery charging system could be checked pretty quickly with a multifunction volt meter. I'm not an electrician by any stretch of the imagination, but I have one and feel pretty comfortable using it. If things get too complicated, we have a local alternator/generator shop where the proprietor, Eddie, loves to solve mysteries like that without charging an arm or a leg or trying to sell you something unless you need it. It could be something as simple as a frayed wire in the power supply cord for your charger. On one 7-pin receiver that wasn't charging the camper batteries while in tow, we found out the 12v power wire (the black wire on most models) hadn't even been connected to a power source from the tow vehicle, so no wonder the battery wasn't charging. Sometimes the problem is so simple you don't even think to look there. Best of luck....
Old 09-04-2014, 12:04 PM   #54
North Florida
Sorry for your trouble but glad you have a plan for getting it solved. As a CPAP user myself I understand the importance of the unit to a good nights sleep. I am currently modifying the tougue of my Scamp to take two 6V batteries and one propane bottle. The original configuration was one battery and two propane. I need to weigh a full propane bottle (40 poundish?) and the dual tank mount I removed but figure I am close to breaking even on tongue weight with the additional battery (62 pounds).
Old 09-04-2014, 02:48 PM   #55
I need more weight up front anyway. My Casita is a standard, so no bathroom. I suspect these were configured with a bathroom in mind. Unless I put a couple hundred pounds, of gear, up front. It rocks back and forth, constantly. And I'm not even running the spare on the back (up in the TV).
ETA: I have a drop hitch, so I'm slightly nose down.
Some PO converted this from a 7-pin to a 4-pin. That'll be something I start to fix when I put batteries up front and finish when I put in a new axle, with brakes.
I'll see if I can find the fault in the converter? If it costs more than a couple bucks to fix? I'll work around it, as mentioned earlier.
-Ernest Hemingway
Old 09-20-2014, 07:04 AM   #56
Trailer: 13 ft Boler 1986
I also use a CPAP and now the hubby has to use one as well. With just one, I plugged it into my 400 PowerPak and got about 1 1/2 nights from that. I have two folding 12 solar panels that run concurrent giving me close to 24 but they won't charge the power pak back up to full. So I took the power pak to the office and had them charge it over the day for me. Now with two machines, I am afraid this isn't going to work at all.
Generators are not allowed where we boondock, and the weight of an extra deep cycle battery isn't something we want to add to our boler either. What I need to know now is how much solar panel do I need to charge the powerpak or do I need a bigger powerpak, or do I plug the CPAP's into an inverter/converter and run them off the deep cycle marine battery. Then I could charge it with a solar panel?
Vivian L is offline   Reply With Quote
battery
CPAP machine & Boondocking/Dry Camping Adrian W General Chat 10 05-02-2016 11:57 AM
CPAP users!!!! kirkman General Chat 4 05-18-2014 07:25 AM
Battery Issues and Generator Cover Toni M T Care and Feeding of Molded Fiberglass Trailers 10 04-21-2011 05:35 AM
Cpap and Oxygen Lee Gould Care and Feeding of Molded Fiberglass Trailers 7 12-04-2009 07:21 AM
Power Converter Issues Gail Shook Electrical | Charging, Systems, Solar and Generators 27 07-06-2007 01:35 PM
