Cummins Onan 2500w LP - Fix for No Start - Fiberglass RV
Old 08-01-2018, 02:04 PM   #1
Wisconsin
This is a one solution that fixed my Onan 2500w LP gas fueled generator on a 2008 Bigfoot 25B21RB trailer. The generator had run perfectly with quick starts and running under full load last season before storage over 6 months.
This summer the Onan generator engine turned over fine, but with no start and no firing.
Online research suggested a trick to “hand choke” to start by placing fingers over the generator’s intake opening after removing the air filter. The Onan started repeatedly doing this and would run under full load for an hour, but would not start again with engine hot or cold - without using fingers to hand choke to start immediately. This proved to me the problem was exclusively the starting system.
Online research also suggested the “demand LP gas regulator” vent hose, found at the lower left of the Onan door panel, was a likely culprit of NO start problems. The rubber vent hose reportedly is often clogged by insects including wasps and spiders. I initially cleared the first 12 inches of the rubber hose by pushing a 10 gauge electric wire and found no obstructions.
BUT at 20 inches into the hose bug parts were found and cleared using a more flexible 14 gauge electric wire and the Onan generator starts immediately and runs under full load. The rubber vent hose leading to the demand regulator can NOT be easily removed for cleaning as it is buried deep in the engine.
A stainless steel fine mesh filter has been custom made from materials available online and installed on the exposed outlet of the rubber vent hose (connected to the LP gas demand regulator).
DarrylScamp78 is offline   Reply With Quote
2015 Nissan Titan Cummins diesel Jared J Towing, Hitching, Axles and Running Gear 3 08-27-2013 10:10 AM
Time to start waxing those trailers Legacy Posts Care and Feeding of Molded Fiberglass Trailers 19 03-18-2003 09:08 AM
Heres the start of the restoration Legacy Posts Modifications, Alterations and Updates 6 02-21-2003 02:24 PM
IF YOU GOTTA GO, START EARLY Legacy Posts Jokes, Stories & Tall Tales 1 11-25-2002 06:35 AM
