Originally Posted by hiker22
Lighter trailers don't have trailer brakes because they are not needed for careful drivers .
I used to tow the
Little Joe without trailer brakes, until I got the Outback. Then to get the higher tow rating, I added trailer brakes. I have often been thankful I did.
Has it occurred to you that trailer brakes are there, not for us 'safe' drivers, but for the nut case that comes ripping around you and once in front stops quickly on a downhill Oregon grade?
You will also save on the cost of replacing the TV brakes. I can buy a pair of loaded brake pans cheaper than disc pads and rotors for 4 wheels, not to mention the labor costs if I pay someone else to do it.
Have you actually had the trailer weighed, or is the 950 lbs the dry
weight listed by the manufacturer. That dry
weight figure usually doesn't include appliances,
propane tanks and such.
Good luck stopping.
