Dual battery wire gauge? - Page 2 - Fiberglass RV
Old 01-03-2015, 08:47 AM   #15
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Originally Posted by Darwin Maring View Post
Doesnt the battery connect the negative lead to the frame?
I'm personally against wiring a trailer negative to its frame for any reason other than a ground to earth.
Old 01-03-2015, 09:03 AM   #16
Jared J's Avatar
Kansas
Name:	ImageUploadedByFiberglass RV1420300225.243073.jpg
Name:	ImageUploadedByFiberglass RV1420300863.044487.jpg
Name:	ImageUploadedByFiberglass RV1420300916.235051.jpg
I put attach studs in for the positive and negative sides with 18" or so long leads from the converter. It makes it easy to disconnect the converter when needed, and easy to wire the grounds.
Old 01-03-2015, 09:14 AM   #17
From what I see when looking at factory schmetacs is that the negative wire goes to the frame just like automobile wiring.
Old 01-04-2015, 01:23 PM   #18
Trailer: 2004 Casita FD
I've since found out my charger will do about 20-30 amps for charging. Since it seems to be a big issue remoting the battery, I will just install it next to the existing one with a circuit breaker of course. I was trying to get my tongue weight adjusted. I will do it another way.
dslaggie is offline   Reply With Quote
battery
Ground Wire Gauge DaMScampers Modifications, Alterations and Updates 8 04-24-2014 10:39 AM
Advice please - how to wire a battery charger battery Steve_N_Janna Electrical | Charging, Systems, Solar and Generators 6 06-17-2012 04:53 PM
Wire Gauge For Interior use? francene Problem Solving | Owners Helping Owners 21 08-18-2009 05:09 PM
What gauge wire should I use? Kevin K Electrical | Charging, Systems, Solar and Generators 14 10-15-2007 01:13 PM
What gauge wire should I use? Kevin K General Chat 0 12-31-1969 07:00 PM
