dumb question about volt meter - Fiberglass RV
Old 04-09-2014, 08:43 PM   #1
Trailer: Scamp 13, 2015 Nissan Frontier SE
Connecticut
Hi all,
New to trailer ownership and trying like mad to figure out the whole 12v thing, among many other things. I did a search but could not find the info I need. I have been to 6 or 7 different auto parts stores, and Sears, looking for a portable digital volt meter for my battery. They have things that plug into cigarette lighters, and things that plug into wall sockets, but isn't there something that I can just clamp onto the battery to test the voltage (without permanently installing it)? If so, none of them had it. I want to be able to monitor the voltage so I know when to charge it when it isn't being used.
I realize there is probably a simple answer to this question, but I can't find it.
VicCT is offline   Reply With Quote
Old 04-09-2014, 08:58 PM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Try Harbor Freight
Search results for: 'volt meter'
Dave & Paula
Old 04-09-2014, 09:00 PM   #3
The VoltMinder was a great solution, but I believe that they may not longer be available. But there is a sorta smart battery box available that has an LED monitor for battery condition and some other useful features.. Fairly inexpensive as well. Here's a link:
And you can leave a plug-in digital meter in one of it's outlets.
Marine Smart Box Battery Case
There may be others like in in the Marine catalogs, but expect to pay $$$
Old 04-09-2014, 09:12 PM   #4
blodn1's Avatar
Trailer: Prius camping - want an Oliver
Virginia
This might be of use:
Amazon.com: Save A Battery 3751-S 12 Volt 6' SMART Alligator Clip-On Cable with LED Voltage Meter: Automotive
I don't get lost, I go on interesting side trips.
blodn1 is offline   Reply With Quote
Old 04-09-2014, 10:17 PM   #5
Dudley's Avatar
Trailer: 1998 Casita 17 SD
a cheap multimeter would work well or a simple panel mount voltmeter from ebay
ebay voltmeter
Mount it in the trailer and run wires to battery or tie it in to the power in the inside of the trailer so you can easily monitor it
Old 04-09-2014, 10:47 PM   #6
I personally really like the simple LED ones that plug into the 12 volt socket (looks like the cigarette lighter) in the trailer. The one I has also has an alarm on it that will sound if the battery gets down to 60%. I like it as I can plug it in only when needed and don't have to take the top of the battery cover off as I do when I use the full sized Mastercraft voltage meter I have. I tend to only use the large one when trouble shooting 12v issues.
Old 04-10-2014, 03:54 AM   #7
Raz
Raz's Avatar
Vermont
A digital multimeter that has it's own power source.( 9 volt battery ). Avoid anything with an analog meter ( needle) or anything that draws it's power from the circuit being tested. All you really need is DC volts scales 2v, 20v 200v, AC volts scales 200v, 600v., and resistance which will include a continuity tester. Don't pay extra for transistor testers, frequency, capacitance etc. Less than $20 anywhere. I wanted one for my tool box in the trailer so I just bought this one.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Raz
Old 04-10-2014, 05:30 AM   #8
Connecticut
Thanks all! This is where I ask, there is a 12 volt socket in the trailer? I haven't seen one . . . but that doesn't mean it isn't there! If it is there, then there is something to plug it into, which solves my problem, at least when the battery is on the trailer.
Old 04-10-2014, 05:36 AM   #9
Trailer: Escape 5.0 TA
W. Mass
I've not seen one that clamps on to the battery, those that have clips on the leads are too small for battery terminals. With the one that Raz shows, you hold the leads on the battery terminals after setting the switch to the right setting. You get a multipurpose tool with these that you can use for troubleshooting, if you figure out how.
The ones that plug in to the lighter sockets can stay there giving you continuous readings till you need the socket for something else. They are quick and simple.
If you are not aware, you do not have to check battery voltage at the battery, you can check it anywhere the 12 volts is present. As in a light if you have access to the contacts, or a lighter socket.
You could also install a 12 volt meter permanently, as in this article.
SOLAR FOR EMERGENCIES: 12 Volt Meter a must for RV's and Small Solar
Depends how easy you want things. I use a DMV like Raz bought but can get a rough idea from the trailers status panel that shows full, 3/4, 1/2, etc. If I didn't have that I'd add either the permanent meter of the lighter one.
Bob & Deb
padlin00 is offline   Reply With Quote
Old 04-10-2014, 06:15 AM   #10
As it seems that everything was optional in the Scamps you may well not have a 12 volt power outlet. But, if not, it is something you will want to add I am sure. They aren't that difficult to install, but I suggest that you have at least two installed as there are more and more uses & needs for them. Everything from small inverters for 120 VAC to cell phone chargers need 12 volts to keep going.
In 13' Scamps, the easiest place to install them is in the front of the left dinette seat and/or the side or front of the sink cabinet, as both are near the power chassis/DC fuses.
Old 04-10-2014, 07:41 AM   #11
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I agree that having 12v outlets is pretty handy. There are any number of cigarette lighter USB devices that expand their usefullness. They're cheap enough but they do tend to be low amp devices so larger items like tablets can take a long time to recharge. But that's not the point of the original post so this is an extra-credit answer.
Old 04-10-2014, 07:49 AM   #12
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
It seems cigarette lighters have been replaced with 2 dollar Chinese voltmeters. I guess that's progress; perhaps not quite on the scale one might hope. Get the probe type multimeter which Raz recommends. They pay for themselves the first time you need to check voltage on small AA or AAA or 9V household batteries. Save the instructions so you can learn new applications AC and DC as they arise.
jack
Old 04-10-2014, 07:59 AM   #13
Timber Wolf's Avatar
North Florida
I just this morning saw a clip out coupon in a magazine for a "free" multi-meter from Harbor Frieght. I have a bunch of them already ($3-$4 on sale) or I would go get another.
Old 04-10-2014, 08:06 AM   #14
That's a good point, most 12 volt to USB adapters are limited to about 2 amps
The work-around for devices like tablets is to plug in a small inverter and use the original tablet charger for charging. At 10 amps x 12 volts, you should have well over 100 watts to work with.
As I have mentioned earlier, some inverters can interfere with computer and/or tablet operation, but they will usually still charge batteries with the device turned off.
Two 6 volt vs. 12 volt deep cycle kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
Volt - Amp Meter Darwin Maring Electrical | Charging, Systems, Solar and Generators 2 07-12-2013 11:36 AM
110 volt and 12 volt on the same switch? Chris Jones Modifications, Alterations and Updates 46 04-04-2013 01:36 PM
Panel Mount Voltage Meter efawcett Modifications, Alterations and Updates 8 07-19-2009 11:54 PM
Looking for a Good Volt/Amp Meter curtis c Problem Solving | Owners Helping Owners 4 05-13-2009 08:09 PM
