Electric disconnect when tack welding frame? - Fiberglass RV
Old 06-10-2018, 12:59 PM   #1
jon carpenter's Avatar
Trailer: 2012 Casita 17' SD
Illinois
I need to have several small steel clips tack welded onto the steel frame of our Casita. Does the battery, any of the 12 volt, the convertor or any other electric devices need to be disconnected before welding? Don't want to fry any of the electric system. I tried a search and came up empty handed.
thanks....jon
jon carpenter is offline   Reply With Quote
Old 06-10-2018, 01:02 PM   #2
Trailer: 2008 Casita 17 SD
I do a lot of welding on my trailer frame and I never disconnect anything electrical, either 120 volt or 12 volt. Never had any problems. Your circuit path is from your welding electrode back through your welder's ground clamp. A few pics of my welded rear bumper, cross brace, and 2" receiver just for examples.
Old 06-10-2018, 01:24 PM   #3
Illinois
Thank you Greg for the speedy reply. That's what I assumed but just wanted to double check because I'd hate to fry a convertor or anything electrical. I want to run a quick disconnect from the gas line and need some way to mount the clips for the copper tubing.
Nice welding job. If you were closer I'd pay you to weld on the clips.
jon
Old 06-10-2018, 04:11 PM   #4
Dennis mn's Avatar
The biggest risk when welding on a vehicle is damaging wheel bearings if you ground clamp is not securely fastened to the frame. If it,is; no problem.
2019 Airstream 19 Foot, pulled by a 2014 Nissan Frontier Pro4-X Crew Cab.
Dennis mn is offline   Reply With Quote
Old 06-11-2018, 09:45 AM   #5
CA
There are two issues. One is that the electrical spikes from welding can damage sensitive electronics. The second is if something is in the current return path to the ground clip. Like wheel bearings, as one poster mentioned.
When welding on cars, I disconnect the battery negative and have never had a problem. I also keep my welding ground clip near the work, something that makes sense anyway.
That inverter.... I would tend to disconnect your electrical ground just because it might, one time in a hundred, make a difference. And it only takes a moment.
TomE11 is offline   Reply With Quote
Old 06-11-2018, 10:36 AM   #6
Trailer: 1977 Trillium 4500 (previously a 1978 Trillium 4500, Rpod 171 and Surveyor SV251)
Nova Scotia
My 3 way fridge hasnít worked on 110 ( it still works on propane and 12v) since I welded up some holes on my trailer frame last year.. I donít know if itís related or not.
Phil 4500 is offline   Reply With Quote
Old 06-11-2018, 11:04 AM   #7
Illinois
Dennis, just curious.....how what can happen to wheel bearings if the ground clamp isn't securely fastened?
jon
Old 06-11-2018, 12:08 PM   #8
Trailer: Lite House
I imagine the current will seek the actual ground (via the wheels) if it cannot return to the welder because the circuit is not complete.
Steve Carlson is online now   Reply With Quote
Old 06-12-2018, 09:07 AM   #9
Through the rubber tires? Sorry, I'm just not seeing that happening to the wheel bearings.
And especially if your trailer is plugged into your shore power outlet, you already have the chassis grounded when you are hooked up to the incoming power service, (aka path of least resistance.)
Not that it would have any effect on any welding done to the trailer. There has to be a complete circuit, which has to come from and return back to the welder in order to weld. Like all electrical wiring, if you don't have a complete circuit you don't have electrical flow, so if your welder's ground clamp isn't making good contact, you won't be doing any welding.
Old 06-12-2018, 11:53 AM   #10
CA
Right. I can see the bearings having trouble if you put the welder ground clip on the wheel hub and weld elsewhere on the trailer. That's really the only case.
Old 06-13-2018, 11:03 AM   #11
Doug Arthurs's Avatar
I wouldn't bother disconnecting. I have welded on many a car and trailers and never had a problem with voltage damaging anything.
Doug Arthurs is offline   Reply With Quote
Old 06-13-2018, 06:25 PM   #12
Dennis mn's Avatar
Absolutely correct. The current will damage either the bearing rollers or races.
I worked for a company that built rail cars. Weldors grounded to the rails. The company built the cars on junk trucks then changed them before shipping.
Old 06-13-2018, 06:37 PM   #13
Sure, if you are grounding through the rails and then welding on the frame you're routing your welding current path from the rails and up through the wheels to the frame. I agree that setting up your welding ground in this manner will result in running the current through the bearings, but if you are welding on your trailer's frame and have your ground clamp attached to the frame, there is no way that the current will run through the wheels and the bearings. And, just my opinion, but any welder that grounds his work in that manner should go back to school and learn the basics of proper welding and grounding of their work.
Old 06-13-2018, 06:46 PM   #14
And just how does that happen when it is sitting on rubber tires? Electricity will take the path of least resistance, and since the welder isn't grounded to earth, this statement makes no sense.
Welding to a Scamp frame Martin B. General Chat 9 03-07-2016 07:06 PM
Welding up a new frame for Trillium superartgirl Modifications, Alterations and Updates 7 10-06-2015 12:17 PM
Tack for Sale Kurt in BC Jokes, Stories & Tall Tales 30 02-11-2009 10:38 AM
Welding Frame back together Eve V. Care and Feeding of Molded Fiberglass Trailers 18 10-01-2008 03:54 AM
Welding on the Road Pete Dumbleton Problem Solving | Owners Helping Owners 2 09-02-2007 08:01 AM
