Electric pass throughs - Fiberglass RV
Old 10-31-2018, 07:53 PM   #1
Trailer: 83 Burro
Illinois
I just bought an 83 burro. I'm replacing the floor right now, and I also want to eliminate all leaks so my new floor doesn't rot away. I've been looking for good sealed electrical connectors, pass throughs, outlets, etc. Does anybody know of a good source of these for fiberglass RVs? Or can you recommend specific products?
GWMattson is offline   Reply With Quote
Old 11-01-2018, 04:34 AM   #2
I used marine products for all of my outlets and inlets. Partly because we have a great marine store nearby and I get a substantial discount there. Also because the nearest RV store to me is around a hours drive round trip and the quality of those fittings for the same functions is no where near as good as the marine ones. Marinco and Furrion are good for the electrical, Sea-Dog is both affordable and also good quality for other types of fittings. Easy to get both of those brands on Amazon.
Old 11-01-2018, 04:54 AM   #3
Amazon. Figure out the shape you need, then buy the one you like the best. No idea what the "mouse door" looks like on a Burro. There are prior threads on this here. Do a search for detachable power cord.
Important to note what amperage you need. On my Trillium, the system is just 15 amps. That limits choices. Our Escape is 30 amp. To maintain the original style on the Trillium, I am customizing a 15 amp connector to fit inside the original Trillium hatch, copying the design of another forum member.
On Amazon, I searched for RV power inlet.
Old 11-01-2018, 10:12 AM   #4
Trailer: 83 Burro
Illinois
Thanks for the information.
Old 11-01-2018, 10:14 AM   #5
Trailer: 83 Burro
Illinois
Thanks for the reply. I've got a neighbor who said the same thing about using Marine parts. I'll definitely look into Marinco and Furrion.
Old 11-01-2018, 10:57 AM   #6
Trailer: 2017 Escape 19
New Hampshire
Marinco makes an inexpensive 15A male receptacle
MPP-150BBIW.RV for the outside of the “hull” that you can just plug the female end of an extension cord into. Comes in white, is sealed (no mice) and you can get it for $20-25.
BruceW is offline   Reply With Quote
Old 11-01-2018, 11:47 AM   #7
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Per any outside hatches etc:
Those parts have changed little if at all over the years and still go on many trailers of all types of construction. I replaced the electric cord hatch on my '78 with an off the rack exact match I found at Camping World. It was even good old "colonial white" to match my trailer, big surprise to me since the color's little used any more. The only defect in the original was that the hinge on the "door" was broken; the replacement was so exact that I didn't even remove the base, instead just attaching the new on top of the old.
Just an FYI since you're unlikely to find such components at a marine store. And even if you could, my experience with boats has been that anything labeled as for marine use is typically more expensive than the same parts "designed" for RVs.
Old 11-01-2018, 12:22 PM   #8
New Hampshire
The part that I suggested is not just a cord hatch like that which comes on trailers where you pull out a 30A cord from inside the trailer. This part 150BBIW actually contains an AC receptacle (with male contacts) into which you plug a std outdoor extension cord. More than just a plastic door and is only $21 from Amazon including shipping.
Old 11-01-2018, 01:07 PM   #9
Just offering my own experience- yours is a good alternative if the OP wants to go that route. I didn't since I like the use of that space for cord storage as well.
And of course the cheapskate in me didn't like the extra expense of putting a female end on the old cord or-heaven forbid- replacing it altogether
Old 11-01-2018, 01:21 PM   #10
Trailer: '82 Burro 13'
Northern VA
I just got a Burro myself. I'm working on a sailboat and been thinking to use a 30A SmartPlug for the camper too.
But like mentioned, marine products is a good way to go.
https://smartplug.com
1982 13' Burro
Burro Renovation
Dan-NS27 is offline   Reply With Quote
Old 11-01-2018, 07:08 PM   #11
Trailer: 83 Burro
Illinois
I've always been a tent camper (non-electric). But I heard that most campgrounds have 30A or 50A service. Would a 15A power inlet work at campgrounds? I don't have AC now. But it might be an option in the future. I'd want 30A for that.
Old 11-01-2018, 08:23 PM   #12
New Hampshire
Typically a campsite with 30A or 50A service also has a separate 15A outlet as well.
Old 11-01-2018, 08:50 PM   #13
The connection needs to match the capacity of your electrical system, in particular your converter. So if your converter is 30 AMP, go with a 30 amp connection. Mine's 15 amp, so I am going with a 15 AMP connection.
Old 11-02-2018, 03:17 AM   #14
You will want to invest in an adapter plug. One end of the adapter will fit into the RV park supply box, the other fits into your 15amp plug that comes out from your trailer.
I traveled with one of those adapters when I was car camping so I could hook up an extension cord for powering up 120 stuff I took with me.
They are a very common item in RV stores and marine stores too.
I think I got mine at a local hardware store.
Propane & Electric vs Just Electric Wallo Care and Feeding of Molded Fiberglass Trailers 75 03-06-2014 06:24 PM
All electric, or gas and electric? Homer Teitsma Electrical | Charging, Systems, Solar and Generators 24 10-07-2007 11:10 AM
Sherman Pass, Sequoia National Forest Mike Taylor Camping, Campout Reports 7 10-02-2006 07:15 PM
Water heater by-pass Legacy Posts Plumbing | Systems and Fixtures 27 05-25-2003 07:19 PM
