electrical gremlins! - Page 2 - Fiberglass RV
Old 12-09-2012, 04:56 PM   #15
Does the name Murphy come to mind?
Old 12-09-2012, 09:11 PM   #16
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Originally Posted by SilverGhost View Post
Are you guys using a different 7 way plug??? The one I use has a large square lug so it can only be plugged in one way.
Jason
Same here, it would take a sledge hammer to get it together wrong on my trailers. If they go together backwards that easy, it's time to replace them. The vehicle side should take a couple minutes, the trailer side might take 20.
Old 12-10-2012, 05:23 PM   #17
Con
Trailer: 1977 Boler 1300/2003 17' Bigfoot
Wiring
Bad, dirty, corroded, moldy, or left some pasta sauce on it or what ever.
99 % of wiring problems usually end up being a ground problem.
1% are likely a wire hooked up to the wrong terminal.
Always check that first.
Con is offline   Reply With Quote
Old 12-10-2012, 06:23 PM   #18
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Mine has a rectangular key, plugs in exactly one way, and the spring-loaded door latches. You and the bear. The bear and you.
jack
Old 12-10-2012, 10:53 PM   #19
Myth
electrical
All new electrical system kyle minor Modifications, Alterations and Updates 4 06-04-2010 11:02 AM
Electrical help needed Pam Garlow Problem Solving | Owners Helping Owners 6 11-20-2007 12:35 PM
electrical question stan s. Problem Solving | Owners Helping Owners 2 08-10-2006 10:25 AM
Electrical bdiscount Electrical | Charging, Systems, Solar and Generators 6 06-27-2006 08:21 PM
Gremlins open the door? John & Sandy M Problem Solving | Owners Helping Owners 25 12-24-2005 04:38 PM
