Electrical Problem - Fiberglass RV
Old 10-23-2012, 05:59 PM   #1
Trailer: Bigfoot 1981 Trailer
Electrical Problem
I am about to install a propane detector as well as a 12 V receptacle for charging my toys, but when I disconnect the battery, there is still power, something with 27 volts. It reads 12.6 when the AC power is disconnected and the battery is connected, which is normal. The propane detector works ok with DC power only, but when I connect shore power it does not work. I went back to the water pump switch and got power there even when the battery is disconnected and the shore power connected, thinking I could use that as a feed for my propane detector and 12V receptacle. Help, please. Thanks, Jim
Old 10-23-2012, 06:09 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I'm not sure I'm following. Are you saying that when you disconnect the battery, but are plugged into shore power, you are getting 27 volts to the water pump switch?
Thomas G. is online now   Reply With Quote
Old 10-23-2012, 06:19 PM   #3
Yes, Tom, When I disconnect the battery froim shore power, I am still getting 27 volts at the water pump, as well as at two other 12 volt light fixtures.....Jeeezzzz.
Old 10-23-2012, 06:23 PM   #4
You have something wrong with the converter. It is putting out to much DC voltage.
Old 10-23-2012, 06:24 PM   #5
Thomas G.'s Avatar
Yea, that's what I'm thinking, too. That high a voltage may damage devices in the trailer.
Old 10-23-2012, 06:28 PM   #6
Trailer: Casita 17 ft DLX SD
Are you using an auto ranging meter such as a Fluke? You may be reading 27 milli volts and not 27 volts . The fluke meter often will pick up stray voltage and display a number
Old 10-23-2012, 07:16 PM   #7
Tom, Yes, I believe it is the converter that is at fault, and after 31 years, it will probably be time to upgrade. The trailer is 15 amp. Would it be costly to upgrade to 30 amp converter and would I have to upgrade anything else? Thanks, Jim
Old 10-23-2012, 09:33 PM   #8
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by steve dunham View Post
are you using an auto ranging meter such as a fluke? You may be reading 27 milli volts and not 27 volts . The fluke meter often will pick up stray voltage and display a number
^^^^^^x2....^^^^^
Old 10-23-2012, 09:45 PM   #9
Jim, if you haven't already seen it there is a really good resource to read called The 12 Volt Side of Life with some great info in it and it might help you out with some of your decisions.
Old 10-23-2012, 09:54 PM   #10
David Tilston's Avatar
Jim, The death of an old 12VDC converter is more of an opportunity then a problem. If it is like the converters I have seen, it is no good as a battery charger. Just boils the battery dry. Take a look at this thread. It probably applies to a big foot as much as a Trillium. Having a converter, that is a good multistage charger as well, would rock.
Trillium 4500 replacement converter?
Old 10-23-2012, 10:51 PM   #11
A 31 year old converter probably uses 31 year old battery charging technology. The charging current was controlled with a dropping resister. The idea was that when the battery got sufficiently charged the current would drop to near zero with just a trickle charge. Today's batteries have improved to the point this technology no longer works properly.
There's a couple things you can do to make it work better.
The easiest is to disconnect the converter and rely on something like a Battery Tender to keep the battery charged while plugged in. Another non-converter option is get a 50 to 80 Watt solar panel and rely on the sun to keep the battery charged.
You could remove the converter, but you might have some problems with fuse and breaker panels since they're often integrated into the converter.
If you really feel the need to have a converter, then replace it.
What would I do? Probably just simply disconnect power to the converter and use a Battery Tender. I've pretty much done that now, which works just fine.
Old 10-24-2012, 07:18 AM   #12
David, I agree that a 31 year old converter needs to be replaced. Thanks for the link. I tried removing the converter but could not move it out. Will try again, or take it to my RV dealer as I am not handy with electrical work. It seems like a very complicated job to re and re and of course the shore power cord has to be changed to 30 amps as well as the wiring to the battery, which seems to be only 16 gauge. I have some good prices on converter/chargers on line so will see what my dealer can do for me. Thanks, Jim
Old 10-24-2012, 07:32 AM   #13
Voltage
Darwin . The older converters transform 120 VAC to approx 14 VAC (secondary transformer voltage) The 14 VAC is then fed to a bridge rectifier to get DC voltage , Multiplying the 14 VAC x 1.41 to get P to P voltage you get about 19.5 VAC imput to the bridge rectifier and subtracting for the drop across the bridge diodes you get about a 17 VDC unregulated output . That is why the 27 VDC output had me puzzled its 10 VDC higher than the output voltage of 17VDC .What am I missing?
Old 10-24-2012, 10:30 AM   #14
Raz
Raz's Avatar
Vermont
My best guess, no loading. The schematics I have seen of old converters were pretty simple, transformer, rectifiers, no filter or regulation. When plugged in the rectifier output supplies pulsating DC to the trailer and charges the battery. They use an SCR crow bar circuit to prevent over charging the battery. Since there is either a large current charging the battery or flowing through the crowbar, the transformer output is chosen with that current in mind. Disconnect the battery and there is no longer a large current hence no loading and a higher output. The circuit was designed to always have a battery. Raz
electrical
Electrical light problem Ralph Schwerin Problem Solving | Owners Helping Owners 3 11-11-2011 04:58 PM
Electrical problem jaye580 Problem Solving | Owners Helping Owners 8 07-28-2008 08:52 PM
Electrical problem - Help! scott fraser Problem Solving | Owners Helping Owners 2 08-07-2007 06:03 PM
Scamp Electrical Problem gheicher Problem Solving | Owners Helping Owners 0 06-08-2006 04:03 AM
Trillium Electrical Problem Legacy Posts Problem Solving | Owners Helping Owners 4 07-19-2003 12:44 AM
