Electrical shut down - Page 4 - Fiberglass RV
Old 01-18-2013, 11:05 AM   #61
Raz
Raz's Avatar
Thanks Raz.
Which model do you have?
Old 01-18-2013, 11:36 AM   #62
RM2201 which I had assumed didnt draw anything on propane until some well hidden specs where published here when the topic of the OP of this thread, needed a replacement fridge came up awhile ago. Cant recall off the top of my head what the amount was - it was *very* small though. I did after that info was posted put my fridge on propane in the driveway for a day on a fully charged & rested battery. I plugged in the meter again and checked it after about 8 hours - sure enough something is pulling DC - again not a lot but some - had unplugged everything else (including the meter) that pulled DC prior to staring the fridge so assumed the DC drain was the fridge. Sorry I didnt make a note of how much but it wasn't a big amount and not an amount that even my tiny solar has a problem keeping up with it. Sorry cant be more specific but electrical is something I need to read the Electrical for Dummies book before even changing out a connection I only asked about the newer fridge as my fridge is creeping up in age and may need to be replaced in the not to distant future and I do tend to camp off the grid a fair bit.
Old 01-18-2013, 12:07 PM   #63
Steve L.'s Avatar
I wonder if anyone has put a meter on a Dometic 2193 to confirm it doesnt pull any DC on propane. I know it is the replacement for my old fridge which I had always assumed didnt pull any DC while on propane as the documentation/manual doesnt give any info on it, that was until someone here pulled up some documentation that it actually did - all be it a small amount.
I have the 2193. I've measured every DC device on board (Jeez, you buy one clamp meter you've got to justify it somehow)
I also wired up a box (just noodlin' around) to put in line with the trailer plug. (It's not hard wired into the line.) I verified no current draw with the DC switch off. I also verified to my satisfaction that at least a Ford with the tow package provides no more current than is demanded and will not charge the trailer battery appreciably. But that's an over-argued topic for yet another time
Old 01-18-2013, 12:09 PM   #64
Steve L.'s Avatar
Under normal circumstances I use a Link 10 to monitor the DC load on the trailer battery. It will show DC amps as well. Same answer wrt to the reefer.
Old 01-18-2013, 12:47 PM   #65
Raz
Raz's Avatar
Carol, I reviewed the service manual and schematic and the only functional difference I see between a 2193 and a 2201 is that the 2201 has a thermostat that functions in the DC setting where the 2193 does not. This unit actually has one thermostat for gas operation and a second shared by both forms of electric operation. My Norcold had the same arrangement but it was not obvious to the user as both thermostats shared the same adjust shaft. Based on what I see you should not need DC to operate on gas. The easiest way to verify that is simply to disconnect the battery and fire up the fridge. Raz
Old 01-18-2013, 02:20 PM   #66
Thanks Raz thats what I had thought for about 5 years until someone here sent me a PM link that suggested otherwise. I cleared out my PM's so I cant find it again to see the link to the site the info came from. I may one of these days when I have another reason for disconnecting the battery test it out to see if it will run without the DC. As I said it was such a small drain I didnt really worry about it after and just want to avoid getting a new fridge if possible that draws more power. It may well be the trailer has another fathom load happening just not sure what it would be though. I have 2 great meters that I use and thought I know how to use them but there is also the possibility I don't!
Old 01-18-2013, 02:39 PM   #67
Raz
Raz's Avatar
I get about 40 mA (.04A) drain due to the propane gas detector. Takes about 3 weeks to drop my battery down to 12.3 volts so I try to remember to disconnect things. Take care, Raz
Old 01-18-2013, 05:43 PM   #68
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
Bonehead me! So standard site means a level spot and picnic table. Thank goodness I have the propane tank and two battery lights. I wonder what the basic site is if this is standard. Anyhow, thank you again for all the help. At least I now know the propane will last the two days! -- and for you chilly northern folks, a little eye candy. It has warmed up into the 70s.
Sue and Henry is offline   Reply With Quote
Shut off valve no shut off!! Tamid Plumbing | Systems and Fixtures 11 06-06-2012 02:55 AM
Toilet doesn't shut off completely ThomasE Plumbing | Systems and Fixtures 4 05-14-2011 09:47 PM
Windows that don't shut all the way tight?? Kathy Provost Problem Solving | Owners Helping Owners 4 06-02-2010 10:05 AM
Stove pilot light - no shut off Kevin H. Problem Solving | Owners Helping Owners 5 04-26-2009 09:38 PM
Keeping the ![at]#[at]$ door shut Coach George Jessup Modifications, Alterations and Updates 8 09-24-2008 04:59 PM
