Electrical System Questions - Page 2 - Fiberglass RV
Old 08-15-2016, 10:37 AM   #15
Trailer: None
None
When I was working as an electrician ,when we rewired homes we were required to repair / replace any wiring that was obviously hazardous , illegal or unsafe. This led to a lot of problems
Many times it meant tearing out the wiring done by the homeowner and reinstalling it properly . The further you dug into the wiring the more you found things that were wrong.. I once filled a 2 yard dumpster with homeowner wiring I had to rip out. This led to arguments over the bill and on several occasions ended up in court.
If I was an electrical contractor , I would avoid working on your trailer because there is no way to estimate the cost or how much of the wiring needs to be replaced. In many instances , it is cheaper to rip it all out and start from scratch. A licensed contractor does not want to stick his neck out and face future liabilities.
We often got calls where people did their own wiring and wanted us to hook it up in the panel and certify that the wiring was safe and to code. We would refuse to comply with their request .
steve dunham is online now   Reply With Quote
Old 08-15-2016, 11:01 PM   #16
Steve makes sense contractors would not want to get into amateur wiring, and that's what mine is looking like.
I believe I've found a boat electrician who has worked on trailers before and is willing to take a look.
Thanks all for the advice and input. I am looking forward to cleaning up my trailer wiring and learning more about it in the process.
I take safety pretty seriously and share Joe's opinion about the relative dangers of propane and electricity. I've lived with/around propane with few troubles, but have seen enough electrical fires and other mishaps to give me a healthy respect.
Lise in WA
LiseKen is offline   Reply With Quote
electrical
Scamp electrical system Barbara Dill Problem Solving | Owners Helping Owners 4 09-02-2011 07:17 PM
RV Electrical system by GoodSam Club Darwin Maring Care and Feeding of Molded Fiberglass Trailers 0 09-06-2010 06:04 PM
All new electrical system kyle minor Modifications, Alterations and Updates 4 06-04-2010 12:02 PM
12 Volt Electrical System From Scratch Al POGUE Problem Solving | Owners Helping Owners 2 09-17-2007 09:20 PM
Electrical System Barbara Gardin Electrical | Charging, Systems, Solar and Generators 2 04-18-2006 04:37 PM
» Virginia Campgrounds
