Exterior light won't turn off - Fiberglass RV
Old 01-20-2013, 02:14 PM   #1
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
I travel with the vehicle lights on so the burro exterior lights are also on. When I got home from this trip, I detached from the car - but the side lights and brake lights are all still on. I guess they must be somehow attached to the battery, but this has never happened before and I've changed nothing. Any ideas out there?
Sue and Henry is offline   Reply With Quote
Old 01-20-2013, 02:34 PM   #2
Raz
Raz's Avatar
Vermont
Sounds like a short in your umbilical. Best disconnect the battery to avoid discharging too much. Raz
Old 01-20-2013, 02:42 PM   #3
If you are set up to charge the trailer battery from the tow vehicle, then I would guess that there was a problem in the plug on the trailer, such as a loose wire making contact with another.
Old 01-20-2013, 02:43 PM   #4
Name: Sue and Greg
Thanks Raz. I'm on my way to do it. I didn't even realize those lights to draw from the battery!
Old 01-20-2013, 02:47 PM   #5
Raz
Raz's Avatar
Vermont
That's the issue. They shouldn't. Lights are powered by the tow vehicle so if they stay on after you unplug there must be an unwanted connection between the two systems. Raz
Old 01-20-2013, 02:51 PM   #6
Name: Sue and Greg
Okay. Disconnected and lights are off. Thank you again.
Old 01-20-2013, 02:57 PM   #7
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
If you have electric brakes, a bad connection in that cord can cause a bunch of problems, so it worth finding out where it is shorting.
Old 01-20-2013, 03:05 PM   #8
Name: Sue and Greg
No electric brakes but I just realized the refrigerator probably isn't working today either even though the burro is plugged into shore power. It has that battery connect that switches it between shore and propane. Guess I'd probably clean out the fridge today instead of tomorrow!
Old 01-20-2013, 04:11 PM   #9
Raz
Raz's Avatar
Vermont
Old 01-20-2013, 06:16 PM   #10
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Most definitely a short from the hot to the trailer lights, an most likely in the cord as Raz alluded to. Could possibly be a loose wire in the plug like Bob said too. These are is pretty much the only place they are right close together, and a place most likely prone to damage as it is not tucked out of the way, and open to being bruised. I had this happen to me before, and it happened to someone else here last year.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Would the last one behind next weekend, turn out the light? CindyL General Chat 11 09-24-2010 09:43 AM
Fridge won't light Tom VZ Problem Solving | Owners Helping Owners 9 09-08-2010 09:23 AM
13' Scamp - Left turn signal and brake light Kate Carney Problem Solving | Owners Helping Owners 7 07-23-2007 08:55 AM
brake/ turn light/ AC stan s. Problem Solving | Owners Helping Owners 17 07-01-2006 07:03 AM
Pilot light won't light (Casita) SW6P Legacy Posts Problem Solving | Owners Helping Owners 5 08-06-2003 09:12 PM
