Fantastic fan and flickering of interior lights - Page 2 - Fiberglass RV
Old 09-20-2011, 12:20 PM   #21
Do you have the old glass tube type fuses? My Burro had that and the clips that hold the fuses in place are riveted on which don't make for good connections. I replaced that fuse block with a more common ATC blade type fuse block. Symptoms were that my lights flickered whenever my furnace turned on.
ThomasE is offline   Reply With Quote
Old 09-20-2011, 03:34 PM   #22
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Yes, the trailer has tube fuses but only 5 were in use. I hadn't considered loose fuse clips . When I got the trailer, the bakelite base of the fuse block installed had suffered melting from arcing of the DC feed. While exploring I found a new one which PO apparently purchased but didn't install. I labeled all the leads to match the paper label on the chasis, switched out the block, and replaced the leads. The end clips did tend to rotate on the old one; quite tight on the replacement; nonetheless, I would prefer a defect in the electrical bonding of the fuse clips of one empty circuit to finding a wizard to check out the converter.
jack
lights
Leaking fantastic fan Chris Z Care and Feeding of Molded Fiberglass Trailers 21 12-11-2011 04:18 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Fantastic Fan Roger Harshaw Problem Solving | Owners Helping Owners 4 03-15-2008 12:47 AM
Cold Cathode and flickering lights al gilliland Problem Solving | Owners Helping Owners 7 05-10-2007 04:09 PM
Not prewired for Fantastic Fan... MikeAg Problem Solving | Owners Helping Owners 8 12-02-2005 08:18 PM
