Fully Charged Battery? - Fiberglass RV
Old 07-21-2006, 09:09 PM   #1
steveh's Avatar
Trailer: Amerigo 16 ft 1972
Hello,
I bought a new deep cycle battery and Schumacher 1.5A maintainer/charger (model SE-1-12S) about a month ago. I've had it connected to shore power repeatedly for periods of 4+ hours and it never indicates that battery is fully charged (red LED vs green). I checked the voltage on the charger (while on) and the battery and both read 13V.
I'm taking my first trip with the Amerigo next weekend (state campground with electric/H2O) - anything to check/worry about?
Thanks in advance,
Steve
steveh is offline   Reply With Quote
Old 07-21-2006, 10:16 PM   #2
ERIC B.'s Avatar
Trailer: 1988 Perris Pacer 13 ft / 2005 Honda Element
If it's a true maintainer with a float cycle, just leave it hooked up 24/7. In my experience, it takes far more than 4 hours to charge a battery especially with a 1.5 amp model. They are usually made only for slightly topping off or maintaining, not charging a deeply discharged battery. Hope that helps.
ERIC B. is offline   Reply With Quote
Old 07-21-2006, 10:53 PM   #3
Trailer: Fiber Stream
Unhappy
The way I read the info on the Googled Webpage:
1.5A Trickle Charge Rate, Charges In 2 To [b]12 Hours,
It would take 12 continuous hours to "fully charge" your battery.
Old 07-21-2006, 11:18 PM   #4
I don't think that number is quite correct. It would be 12 hours if the battery had been discharged by 18 amp hours. If the battery is an 100 amp hour battery at 50% discharge, it would take a bit over 33 hours to get back to a full charge with a 1.5 amp charger. Take a gallon out of the water tank, to refill the out you gotta put a gallon back in. Take an amp hour out, you gotta put an amp hour back in.
Old 07-22-2006, 08:23 AM   #5
steveh's Avatar
Thanks much for the help - I'll leave it plugged up today (all day) and see what happens - I'll let you know.
Steve
Old 07-22-2006, 09:05 AM   #6
Hate to add a fly to the ointment, but believe that the charger that you bought should have had higher amp settings for charging also....I bought a resonably cheap charger/maintainer with float and it has 2, 6, 10, 12, 15 amp positions.....Benny
Old 07-22-2006, 11:00 AM   #7
I just checked the Shumacher web site. That charger is a trickle charger meant to mount near the battery and "maintain" a full charge. It's charge rate state is 1.5 amp and will take a long time to charge a low battery. They say 2 to 12 hours, but I think it could take a lot longer than 12 hours, depending on the charge state of the battery.
Old 07-22-2006, 11:59 AM   #8
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
Steve,
This doesn’t sound like your problem, but My trickle charger requires the battery have at least 11 volts or the trickle charger will not charge.
Old 07-22-2006, 12:10 PM   #9
Gina D.'s Avatar
West Coast USA
I have the same model charger as you and have never had the charged led go on. Maybe it's just a quirk of that model, and it wants to see that magic 13.2 or 13.5 voltage before the LED goes on. (IE: 13.15 isn't enuff to kick in the LED)
It has been plugged into the charger for days on end before.. nada for the green LED, even tho I am up at 13 volts.
I don't worry about it. The battery performs OK. With my charge controller for my solar, it will never charge past 13 volts either. Also, I don't worry about it. The charge controller, in theory, can allow up to a 14 volt level.
Oddly tho (Lets thro a cog in the wheel) I can get up to 13.8 when charging with my car when driving for long periods .. up to 4 hours or so.
Old 07-22-2006, 03:50 PM   #10
Not really odd. Vehicle systems even though everybody thinks 12volts are acutally 13.8 Volts. At least for now. Look out it'll change in few years.
Old 07-22-2006, 04:45 PM   #11
Gina D.'s Avatar
West Coast USA
I am sure my alternator has a bigger better charging current. (I know nuttin' of auto lectrickity)
Solar charger is capable of 7a, but with a 45 watts panel, Sometimes 60 when I get the WHOLE system on it, I doubt I am anywhere near that. I also could pull that much if I had everything in the trailer on!
Schumacher is 1.5.
dribble...
Old 07-22-2006, 11:40 PM   #12
I guess my post kinda didn`t seem to mean what I meant it to be....I meant that instead of the 1.5 amp, Steve should have gotten a charger with more amperage settings on it, which would bring his battery up quicker than a 1.5 A does......even just parked in hot weather, especially in a black case, the battery will lose a lot of power just sitting there doing nothing......Benny
Old 07-23-2006, 12:11 AM   #13
Gina D.'s Avatar
West Coast USA
thats funny. So do I.
Old 07-23-2006, 12:19 AM   #14
Ya, and I sure lost a lot of power these last two days. We're not used to that trippple digit temperatures.
On topic. That little charger is meant to keep it from loosing power when just sitting and doing nothing. I agree that a bigger charger might be in order to bring it up to full charge first.
battery
1972 Compact Jr. Fully Restored Spanaway WA. jessejames Classified Archives 0 09-24-2009 11:27 PM
2007 16' Scamp for sale - $11,000-fully loaded KarenD Classified Archives 3 06-23-2009 08:52 PM
13' 1980 Scamp fully self-contained Dana T Classified Archives 6 05-04-2009 08:14 PM
1975 13' Boler For Sale - Mint, Fully Restored Laun Saunders Classified Archives 0 04-11-2009 09:39 AM
Ronald MacDonald charged in Wendy's theft Benita Jokes, Stories & Tall Tales 0 11-29-2005 02:57 PM
