Fuse bank melted - Page 4 - Fiberglass RV
Old 08-22-2013, 09:07 AM   #43
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Ice-breaker View Post
I have had some success making water tight wire connections using a cable gland such as this (Electrical Installation Accessories). Could even use Thomas' FG resin filled hole with one of these installed in the centre.
This is what I'd do if I was rich, like you.
Old 08-22-2013, 10:14 PM   #44
Trailer: '07 Scamp 16' SD
Wisconsin
So it sounds like a few of you have went through the floor to run wiring.
Us this the generally accepted method for running new wire?
glennco is offline   Reply With Quote
Old 08-23-2013, 12:08 AM   #45
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
No idea. It was really the only way I could run 4 gauge wire. The 45 amps of converter output, and length of wire run dictated 4 gauge.
Old 08-23-2013, 12:23 AM   #46
Trailer: 77 Scamp 13
Any special measures to protect wire under the trailer? Conduit, padded clamps, that sort of thing. Or does the wire hold up pretty well underneath?
Old 08-23-2013, 07:21 AM   #47
Thomas G.'s Avatar
I used plastic accordion wrap over the wires and padded clamps, trying to tuck the wire up high so it is protected by the frame in case it is dragged in a low ground clearance situation.
Old 08-23-2013, 07:41 AM   #48
Jared J's Avatar
Kansas
I used plastic clamps, and put hose over it anywhere it might rub on the edge of metal.
The 4 gauge cable I used was marine rated so I didn't worry too much about it being exposed.
Old 08-23-2013, 01:03 PM   #49
Trailer: Fiber Stream
Maryland
We follow the DOT trailer wiring standard for sizing conductors and enclose multi single conductors and cables in split wire loom or in blue tube conduit.
All floor penetration s are in pvc to blue tube compatible boxes or end fittings or run in the trailer frame when possible. All tubing is fastened every 18" using metal straps.
Only metal tie wraps are used if used at all. Terminations are onto insulated ring terminals to a screw or suitable capture terminals never open wire ends under screws.
We crimp all connections and use die lectric grease on all finished terminations and in the rear of all crimped wire ends.
We solder wire connections and certain terminals dePending on situation.
Please check out this approach on our site www.flyingtigertransport.com hope this is helpful. The attachment shows what can happen to plastic inline connectors under stress.
JD1994 is offline   Reply With Quote
Old 08-23-2013, 01:43 PM   #50
Trailer: 17 ft Casita.
Danbury Wisconsin
Protecting Conductors
I agree with Thomas : Accordion wrap protects the conductors plus does not trap moisture or road salt like other raceway systems .Moisture is not a large enemy to most types of wire insulation , but UV , heat and physical damage are .
Old 08-24-2013, 11:24 AM   #51
Maryland
plastic inline burnout
Thought this got attached yesterday, sorry. This was carrying the full neutral/negative circuit to the converter- and not well.
Old 08-25-2013, 07:37 PM   #52
IM(not so)HO: Scotch-Loc connectors are the tell-tale sign of cheesy work.
I am amazed to open up all different brands of campers and motorhomes and find these things in place. To some builders it's only important that stuff works when delivered.
Old 08-25-2013, 09:40 PM   #53
Jared J's Avatar
Kansas
Scotch locks should be outlawed.
Bank of America honda03842 General Chat 11 04-14-2012 09:37 PM
Need some help, please Canadian Bank Cards at US Gas Sations Doug Mager Problem Solving | Owners Helping Owners 1 02-08-2011 12:06 AM
Battery Charging: what limits the amperage to the house bank? Evergreen Modifications, Alterations and Updates 3 01-19-2011 11:47 AM
Trailer Piggy Bank Andrew Gibbens General Chat 3 07-10-2006 04:30 PM
A link to a data bank of egg pictures. Yves Pelchat Forum Admin, News & Announcements 2 01-31-2006 04:23 PM
» Virginia Campgrounds
