Originally Posted by lisantica
I use mineral ice 3 - 4 times a day.
Since your working againt Dr orders. I will send you my next novel. If I am not helping just let me know.
Looking at your
scamp wiring diagram. On the lower left of the drawing you see 7 colors of straight horizontal lines going through a vertical heavy black line. Those horizontal colored lines are your new 7 wire trailer cord. The heavy black verticle line is the front
fiberglass wall of the trailer. If you follow the horizontal black and white lines as they go through the verticle heavy black line representing the trailer wall you will see round black dot and white dot on the lines. These dots represent junction points ( connections ) .
This black line is your trailer 12 volt dc positive wire. The black line from the black dot connection goes up to the
battery needs a fuse holder with a 20 amp fuse and a terminal ring to hook up to the
battery. You want the fuse holder very close to the battery. This is your battery supply and battery charge wire.
From the black dot is another black wire with a 20 amp fuse in it. You want this fuse close to the black dot. This is your main 12 volt dc battery power for your trailer use. This wire carries the power to and from your trailer converter. See your converter wiring picture ( from page 6 post 43 of this thread ) the black 12 volt dc wire ends up connected to post C in the converter panel.
Now the white wire comming from your 7 pin trailer cord ( horizontal white wire going through the vertical heavy black line of the trailer ) this is your trailer 12 volt dc negative white wire. At the white dot ( connections ) one white wire goes up to your trailer battery. This connection compleats the negative side of your battery charge, connects the 12 volt dc battery negative to the car and trailer negative circuts. The other white wire connected at the white dot goes to the converter panel ( from page 6 post 43 of this thread ) the white 12 volt dc negative ends up connected to post D in your converter panel. And on to the frame under your trailer.
Now for the other colors in your trailer cord. Follow the horizontal colored lines through the heavy black line representing the trailer wall. Where you see the first black dot with the white dot under it i want you to put a brown dot on the brown line, a red dot on the red line, a yellow dot on the yellow line, a green dot on the green line, a blue dot on the blue line. All these dots on a straight verticle placement with the black and white dots on the wiring diagram page.
Once you pencil in the dots draw a long narrow box around the 7 colored dots. This box represents your new junction box. The dots are the posts in the box where the wires are connected together. You connect your black trailer cord wire to the black wire in your trailer. White to white, brown to brown and so on. See picture on page 9 post 124 of this thread.
Just remember where you see 2 wires of the same color cross and there is a round dot that is a connection. In most cases Scamp used a square plastic Scotch loc connector or wire nut to connect the wire joint. See picture page 7 post 92
I hope this helps.
