Fuses in Lil Bigfoot? - Fiberglass RV
Old 06-15-2016, 03:42 PM   #1
EllPea in CA's Avatar
CA
I've been all through my owner's manual and don't find anything about the location of fuses. There is a "breaker box" under the sink that has two switches! both are "on." The 120 plug under the upper cabinet in the front of the trailer, the light over the sink, and the plug on the front of the sink cabinet all work. But the plug under the rear upper cabinet does not.
Any ideas about where I'd look for the problem?
Best,
EllPea in CA
EllPea in CA is offline   Reply With Quote
Old 06-15-2016, 05:24 PM   #2
not....
not familiar with Lil BFs...but am familiar (sort of) with the thinking at the factory.....pictures would help BTW
when you say " But the plug under the rear upper cabinet does not." I take it that is a twelve volt cigarette plug...guessing here...
in larger BFs the factory was fond of installing a cigarette plug and TV signal amplifier / gizmo in that particular location....this circuit was fed directly from the batteries (three possible fuse locations in larger BF fuse panels...the three at far right in pic below...red wire runs to that rear upper location mentioned) this was done because 12V from the converter would cause "noise" in electronics like TVs)
sorry can't be more help...good luck
Old 06-15-2016, 05:39 PM   #3
CA
Franswa, If it weren't raining right now (yay!) I'd dash out and take a photo, but the plug under the rear upper is a 120, just like in the house. The trailer has 3 total (inside), and the one in the back doesn't work. There's another one outside in the fridge access door -- haven't tried it but something from inside is plugged in there.
There were no 12V sockets until I had them installed (and they all work great).
Best,
EllPea in CA
bigfoot
Blowing fuses and receptacle question.. Bluebamboo Electrical | Charging, Systems, Solar and Generators 19 05-29-2013 03:52 PM
Fuses in a Town and Country Tow Vehicle GingerB Towing, Hitching, Axles and Running Gear 21 12-28-2012 01:18 PM
HONDA TV Accessory Outlet Blows Fuses Bob Miller Problem Solving | Owners Helping Owners 0 09-24-2012 10:13 AM
Atwood furnace new on Trillium..won't kick on...fuses fine.... lloyd cicetti General Chat 15 04-12-2010 08:21 PM
The fastest fuses blower Legacy Posts General Chat 8 07-04-2003 02:36 PM
