Generator to camper 30amp adapter - Fiberglass RV
Old 07-31-2019, 11:29 AM   #1
Kip in Ga.'s Avatar
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
The 30 amp reciprocal on the Yamaha 6300 inverter is the 3 blade type as used in residential applications.
HOWEVER, the Casita power cord is the typical 2 blade and 1 pin.
Is there an adaptor that will make this work?
Thanks,
Kip
Kip in Ga. is offline   Reply With Quote
Old 07-31-2019, 11:46 AM   #2
sokhapkin's Avatar
SW Florida
This one? https://www.amazon.com/LeisureCords-...mp+twist+plug&
Sergey
www.callwithus.com
Old 07-31-2019, 12:33 PM   #3
Kip in Ga.'s Avatar
Wow , all shapes and discriptions!
Thanks,
kip
Old 07-31-2019, 01:00 PM   #4
Raspy's Avatar
Trailer: Black Series HQ19, Oliver LE2
Smith Valley, Nevada
Kip,
For a residential style plug, as you mentioned, here is the typical one, and the one I use. The typical "residential" style plug is rated for 15 amps and will work fine as long as you don't try to run two large loads at the same time. Battery charging and microwave should be fine, lights and coffee pot should be fine. Electric heater and microwave will be too much. AC and anything else will be too much. In fact the AC can overload a 15 amp plug by itself, but is probably OK.
This style of plug is called a 15 amp plug, but in homes is connected to a 20 amp circuit breaker, uses #12 home wiring in the wall and is a 20 amp circuit. It is safe for low loads in the trailer.
This is a nice one with a screw on ring to hold it. You'd use a #12 extension cord to the generator, or a house plug at home, after plugging this into the trailer.
https://www.amazon.com/PinShang-12in...tronics&sr=1-5
This is a very simple one, and just fine too. You plug this into the generator and run the trailer shore tie cord to this adapter. Or you plug it onto the trailer and use an extension cord to a household plug.
https://www.amazon.com/Adapter-Femal...tronics&sr=1-4
Old 08-01-2019, 04:39 AM   #5
Kip in Ga.'s Avatar
Thanks Raspy.
My post was somewhat confusing when I said "residential". Because we don't see many 30 amp residential applications.
The Generator Inverter has a 30 amp 3 BLADE reciprocal that allows the male to twist lock into place. I should have said "30 Amp TWIST LOCK".
Your post would have still taken me where I needed to be.
Thanks,
Kip
Old 08-01-2019, 04:50 AM   #6
Kip in Ga.'s Avatar
Thanks Raspy.
Thanks to both you and Sergey for your help!
Kip
Old 08-01-2019, 11:00 AM   #7
John in Santa Cruz's Avatar
CA
your generator has a NEMA 5-30R (straight blade) or a L5-30R (twist-lock), and takes a 5-30P or L5-30P plug. your trailer has a TT30 cord. a variety of 'dogbones' are available to adapt these, such as ... https://www.amazon.com/Camco-Recepta.../dp/B0011FJXOM
they also make this adapter as a solid one piece plug, but I prefer 'dog bones' for these applications as they are less likely to apply excess torque to the outlet
another potential issue... generators have a floating ground thats not bonded to neutral. if your trailer has a EMS (power monitoring system) it may trigger on the lack of ground bonding and throw a fault and not turn on the juice in the trailer (I have this in my Escape 21). you have two choices, turn the EMS off or get a ground bonding connector that ties the ground and neutral pins together at the generator outlet. When you use a ground bonding connector, you are also supposed to put a copper stake into the ground, and wire it to the ground screw on the generator. not many people I know bother to do this.
Old 08-02-2019, 10:52 AM   #8
Kip in Ga.'s Avatar
Thanks John! Good info.
generator
30amp Scamp at 50amp park TheWanderers Electrical | Charging, Systems, Solar and Generators 17 06-29-2019 08:26 AM
Best way to monitor battery-Centurian 3000 30amp converter jefflarsen Electrical | Charging, Systems, Solar and Generators 24 09-02-2016 07:03 PM
Question About 15amp & 30amp Hookups Seth and Desiree Electrical | Charging, Systems, Solar and Generators 22 07-12-2014 02:51 AM
50amp to 30amp adapter scamprookie Problem Solving | Owners Helping Owners 7 05-07-2013 08:16 AM
Wiring Diagram for 120v 30amp Burro entrance panel needed megatrack Problem Solving | Owners Helping Owners 1 03-27-2012 07:14 PM
