Get rid of the 110v cord - Fiberglass RV
Old 12-09-2015, 06:13 AM   #1
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
I'd like to get rid of the cord mess under the dinette in our Scamp. I've considered the obvious solution of a cord reel but lately I've thought it might be possible to completely eliminate the cord by switching to a external cord with a female plug in the side of the trailer. Has anyone done this?
"Not all those who wander are lost." J.R.R. Tolkien
TheWanderers is online now   Reply With Quote
Old 12-09-2015, 06:24 AM   #2
I did it and have been happy with the separate cord. I bought a kit off of amazon or somewhere that had all the parts. The only change to the kit was that I replaced a few screws with bolts since we have thin walled fiberglass trailers, but it worked out great.
FYI, with the size of the cord you are dealing with, I am not sure a cord reel would work well.
ericw is offline   Reply With Quote
Old 12-09-2015, 06:29 AM   #3
Kentucky
Eric, thanks for your reply. I agree with you regarding the cord reel in the space available. That's why I started having this idea. Glad it's been done already. I am not averse to charging into uncharted territory but since you've already led the way, I'll be changing this and salvaging the extra space under the dinette seat.
I just found this adapter on Amazon and have added it to my wish list for trailer parts. Excellent. Thanx again.
Old 12-09-2015, 06:38 AM   #4
It's actually a very common mod. Of course, you still have to store the cord somewhere. Another reason a lot of people do it is to eliminate the cord port, which is vulnerable to rodent entry.
Old 12-09-2015, 06:39 AM   #5
Lots of folks have (including moi), but more because of the mouse hole I think.
Here is one thread for your review:
Mouse Hole Conversion Plastic or Stainless ? | Scamp Owners International
Old 12-09-2015, 06:48 AM   #6
It is quite common. Escape even offers it as an option on new trailers. Like most of "my" ideas, they were stolen liberally (or at least adapted) from the good people on this website who were generous enough to share with all of us. Enjoy!
Old 12-09-2015, 07:28 AM   #7
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
I just kept the cord really short, it pulls out of the trailer about 10 inches.
No tangled mess under the counter and the 14ga extension cord can be stored
in a myriad of places.
Fred
FRED SMAILES is offline   Reply With Quote
Old 12-09-2015, 08:00 AM   #8
Trailer: Casita 17 ft DLX SD
Male plug (Inlet) on side of trailer .
steve dunham is online now   Reply With Quote
Old 12-09-2015, 08:45 AM   #9
Trailer: 2008 Casita 17 SD
I recently installed a new integrated internally mounted 30 Amp Progressive Industries Surge Protector. I didn't want an external one, (read: Steal Me!) so I opted for a hard wired mount. It required a bit of modification to the electrical hatch area. That little all-but-useless dinky hatch had to go bye bye. It wasn't big enough to even get the surge protector in, much less room to do any wiring. I now have a wonderful new hatch which is more than twice as big. Installation was easy with a Roto-Zip to expand the existing cutout. Now I have surge protection and theft protection both. I installed the MARINCO 120V 30A 3-wire twist-lock male pronged shore power outlet to a spot over the wheel well. I mounted the remote readout for the surge protector under the side dinette on the toe board. Plenty visible when I need to see it, but not something that is going to annoy me while I'm trying to sleep, because it continuously flashes through its cycle of reading Voltage, Amperage Draw, Cycles (Hertz), and Error Code, which is normally "0".
Progressive Industries RV Surge and Electrical Protection industry lea
JR Products ZE102-A Polar White Access Hatch Keylock Large RV Parts
Marinco 30 Amp Standard Shore Power Inlet | Shorepower
Old 12-09-2015, 08:56 AM   #10
Originally Posted by Casita Greg View Post
I recently installed a new integrated internally mounted 30 Amp Progressive Industries Surge Protector..[/url]
Thats a very similar install that I documented in the thread on the other forum that I listed above (which is on a Scamp and not Casita).
One thing we have found however is that the internal Progressive Industries Surge Protector has a hum. its not loud and can really only be heard in the dead of night, but when I am sleeping with my head right over it, it is a little annoying. I tried to mount in different ways but no improvement.
Old 12-09-2015, 09:04 AM   #11
I'm not sure why you are experiencing any humming noise. I don't have any noise at all coming from mine, and my head is also right over it when I'm sleeping. You may want to give them a call and talk to one of their techs about it. It's not normal for them to hum.
Old 12-09-2015, 09:31 AM   #12
Trailer: 1993 CASITA 16SD
I, too, didn't like the "pull the cord out a hole" setup. At least 10 years ago I went with a marine shore power sealed inlet and 30' cord. The cord rotates a tenth of a turn onto the male side the plug and and then there's a larger threaded ring which screws down and seals the whole plug to the inlet. No more cold drafts or varmint worries. Of course, it's so sturdy now that I might pull the utility post out of the ground if I forgot to unhook. Being a marine duty cord, it's had been outside 124/7/365 for about 8 years with out deteriorating. I cut the cord, so to speak, last year by going completely solar but I still use it when I need AC.
CASITA BANANA is offline   Reply With Quote
Old 12-09-2015, 10:11 AM   #13
OK, I just did that.
Bottom line is a little 60 cycle hum from the windings in the contactor (relay) is not unusual. Furthermore, the mounting surface can act as a sounding board, which I think, in the case of the Scamp's floor, is the case.
Some suggested solutions include mounting on rubber washers, which I tried, and / or mounting the contactor (inside the box) on rubber washers.
They did offer to send a new contactor, but I declined as it seems to be normal.
It is a very slight hum and no doubt some people are more susceptible to it than others. I'll bet if you take a stethoscope to the box you will hear it.
Old 12-09-2015, 11:07 AM   #14
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Everyone’s different, a fact that I’m almost always grateful for. I want it all onboard all the time. If I could sort through how to do it to my satisfaction, I’d probably put the water hose in a cubby somewhere too.
Quando omni flunkus, moritati
blecch - any way to get rid of plastic hose taste?? bcomnes Plumbing | Systems and Fixtures 5 04-14-2010 10:45 PM
110v Extension Cord...Is it worth buying. Pat C Problem Solving | Owners Helping Owners 19 06-23-2008 09:21 AM
How do YOU get rid of Spam Chester Taje General Chat 30 10-26-2007 08:58 PM
How do you get rid of ANTS? Linda&Dale General Chat 19 10-16-2007 10:25 PM
?how to get rid of insecticide smell under sink potteralice Problem Solving | Owners Helping Owners 10 06-26-2006 09:36 PM
