Ground wire enters box on frame that can't be opened? - Fiberglass RV
Old 05-22-2015, 01:10 PM   #1
Trailer: Jayco
Iowa
Hi, I'm hoping someone can help me. I have an 1981 Jayco travel trailer and my battery ground wire is heating up, which I'm assuming means it is not attached to the frame?
I followed the ground from the negative battery terminal to the frame and it appears to eater a 2x3" plastic box with a brand name on it that I can't remember that appears that I can't open in any way.
Any idea how to deal with this? Also, would lack of a ground on the battery cause nothing in the trailer to work when running on the battery? I'm assuming so.
Another unrelated question -- My trailer routinely blows the 30 amp fuse. Any idea why?
lynneg is offline   Reply With Quote
Old 05-22-2015, 02:04 PM   #2
Trailer: 1999 Casita 17' SD
Ohio
No wire in your trailer should get warm/hot and blowing a 30 amp fuse repeatably both indicate you have something shorted out.
First how about a picture of that "Box" you can't open?
Old 05-22-2015, 02:14 PM   #3
2 x 3 inch plastic box? Does it say Bargman Breakaway Switch?
Old 05-22-2015, 02:15 PM   #4
While your electrical problems might be "similar" to what is found in molded fiberglass trailers, we have a bit of a different requirement about maintaining grounds, we need a lot more of them.
At the bottom of this window is a listing of our sister RV groups, (click on the RV & Travel Trailer tab) including one specifically for Jayco owners, that may have a better knowledge of the specific problems you are having.
Hole in roof where solar wire enters body Kbreeding Problem Solving | Owners Helping Owners 5 07-28-2014 08:17 PM
Ground wire help Filbert V. Towing, Hitching, Axles and Running Gear 25 03-16-2014 05:43 PM
Frame Ground/Chassis Wire multi-task Electrical | Charging, Systems, Solar and Generators 35 04-28-2013 04:44 PM
Will this work? Ground wire Bobbie Mayer Electrical | Charging, Systems, Solar and Generators 21 09-25-2012 12:23 PM
Burro enters solar system rabbit Modifications, Alterations and Updates 4 07-04-2011 05:49 AM
