Help for a newbie? - Fiberglass RV
Old 07-29-2016, 12:28 PM   #1
Lorie Q's Avatar
Wisconsin
Help for a newbie?
I'm on my second trip in my 2004 Scamp and have suddenly lost power to my 12-Volt electrical items (dome lights and water pumps). It doesn't look like I've lost any fuses or tripped any circuits. Can anyone help me troubleshoot?
Thanks very much!
Lorie Q is offline   Reply With Quote
Old 07-29-2016, 12:35 PM   #2
Are you running them off a battery or shore power through a converter?
Old 07-29-2016, 12:45 PM   #3
Lorie Q's Avatar
Wisconsin
I'm plugged into a 30Amp, so I should be charging the battery, right?
Old 07-30-2016, 09:37 AM   #4
Mark P49's Avatar
Name: Kate & Mark
Trailer: 16' Scamp
Wisconsin
finding the lost 12 volts
Did the 12 volt power suddenly go out? Check the connections at the battery, ours suddenly went out a few road trips ago, the problem was a broken wire connection at the battery. And yes if you are on shore power the battery should be charging.
Mark P49 is offline   Reply With Quote
Old 07-30-2016, 09:48 AM   #5
Thanks very much!
Look for a fuse inside the front closet, or under the gaucho, where the wires from the battery enter the shell. Also, check for bad connectors in that area.
Old 07-30-2016, 10:07 AM   #6
Carl Pa's Avatar
Check to see if your converter is plugged in
Carl Pa is offline   Reply With Quote
Old 07-30-2016, 10:12 AM   #7
Trailer: 2000 16ft Scamp
another thing to check.
I had a similar issue this spring and the trouble was disconnected wires under the front bunk. I had overstuffed the space and lost a connector.
My friends at Backus found it.
John:
The earth without art is just eh....
crowwing is offline   Reply With Quote
Old 07-30-2016, 03:43 PM   #8
Paul O.'s Avatar
Another place: inside the battery box on the tongue. That is where my main fuse is for the 12V system.
Old 07-30-2016, 06:26 PM   #9
Originally Posted by Mark P49 View Post
Did the 12 volt power suddenly go out? Check the connections at the battery, ...
Look for a fuse inside the front closet, or under the gaucho, where the wires from the battery enter the shell....
OK.. the three quoted comments above do not apply because OP said they were on shore power. With a properly operating converter on shore power, the 12 volt stuff will still work if the battery connections or battery protection fuse(s) (not other fuses) are bad. In fact they will work if you have no battery at all.
This is very likely the problem. It has been know to happen. It would cause the battery to discharge but not suddenly cut out (although it could seem like it).
You could also have more than one problem, such as an unplugged or faulty converter or one that is over heating and shutting down, AND a blown battery protection fuse.
Not sure how the OP's is wired but in my 2015 Scamp 16 the converter has a 120 VAC cord plugged into a single outlet that is part of the power distribution panel. Its a pain to find because I have to remove four screws and pull the panel out as far as the wiring will allow to check the plug. Therefore, even though I have not had a failure, I wire-tied the plug in place. The plug is in the lower left in this photo and it is inside the cabinet when the panel is in place.
Old 07-31-2016, 06:35 AM   #10
Paul O.'s Avatar
Gordon, I find it interesting that Scamp used a converter that is plugged in, rather than hard wired (mine is) to the 110VAC. Is it original? All travel trailers present a high vibration environment and all equipment inside should be designed for it. The wire-ties are so handy for something like this and many other things. Every camper needs to have a bundle of those.
Old 07-31-2016, 07:10 AM   #11
Gordon, I find it interesting that Scamp used a converter that is plugged in, rather than hard wired (mine is) to the 110VAC. Is it original?..
Yes, just as it came from Backus - brand new. And yes, it is a poor design. Reading this forum everyday I found out about it and got proactive.
With wire ties and duct tape I could rule the world. lol
Old 07-31-2016, 11:45 AM   #12
the cord falling out is a common annoyance.It is a very simple matter to hardwire the cord by removing the plug and the outlet and using the hole for cord access.
Old 08-18-2016, 06:02 AM   #13
Borden's Avatar
Name: Borden and Carole
On the boler we have a switch from 110v to 12v on the converter when on shore pwr we do not need a battery expected scamp to be the same but sounds like it is not. Also no fuzzes, just the breakers buttons on the converter. Will add one at the battery though have a 30 amp unit i want to add.
Our postage stamp in heaven.
Old 08-29-2016, 02:34 PM   #14
Lorie Q's Avatar
Wisconsin
Apologies for being offline for awhile. I was able to jump the battery and get everything running again. However, this makes me think my converter isn't working properly since while connected to shore power my battery drained. Where will I find the converter? My wiring diagram in the manual doesn't specify where on the camper it would be located, just how the wires are connected to each other.
Thanks for all of the information. So glad to have this forum!!
Old 08-31-2016, 01:47 PM   #15
Lorie Q's Avatar
Wisconsin
And...after about 48 hours battery is dead again. Can't find the converter. Can't find any wires disconnected. Anyone else have any ideas?
Old 08-31-2016, 03:47 PM   #16
And here's another case where the best advice is take it to an RV Shop and let the professionals trouble shoot and repair. 12 VDC is just as dangerous as 120 VAC. (fires are common when wiring systems are messed with, without knowledge)
Old 08-31-2016, 04:17 PM   #17
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
Lorie,
I would suspect the converter is under the driver's side dinette bench in close proximity to where the shore power cord enters the trailer.
What a long strange trip it’s been!
Old 08-31-2016, 04:46 PM   #18
It will be inside one our your hatches - depends on what layout you have- either under one at the very rear (thats where the one on mine was) or under one of the side dinette seats. Its either not plugged in or you have blown some fuses that are inside of its case.
Question to forum members. The convertor on my 92 Scamp was hard wired - no plug in. What year did Scamp stop hard wiring them in?
Old 08-31-2016, 04:54 PM   #19
While based on the OP's knowledge of the trailers system, simple based on questions asked, I would say thats a good suggestion should there is in fact something wrong with the wiring/converter.
But lets be frank do you really think someone needs to pay an RV shop to find and possible do nothing more than plug in their converter or replace a fuse? a little over kill don't you think
We all have to start somewhere and figuring out what your convertor looks like and its location is something every new owner should do.
Old 08-31-2016, 08:37 PM   #20
Lorie raise your cushions up at the table area and you should see a wooden cover. Mine is on the sink/drivers side. You can easily look down in the hole and find the square bright metal box that is about roughly 8" square maybe 5-6" thick. That is your converter and it will plug into your power panel. Most likely the plug has came out and is NOT charging your battery.
This has been suggested several times and that's why I tried to include a location AND somewhat simple description of it. For safety purposes, unplug your Scamp from shore power while doing this. I'm saying that JUST in case something else should go awry. Then plug your Scamp in and if you see/hear anything out of the way....unless your pump comes on or something, unplug it immediately and take it to a shop!
My vote is 99% that the converter is unplugged or bad.
Newbie to fiberglass campers - Minit to redo - HELP llco87 Modifications, Alterations and Updates 40 06-08-2013 02:15 PM
Newbie- needs help Rosemarie K. Care and Feeding of Molded Fiberglass Trailers 23 03-09-2012 09:20 PM
newbie need help in vehicle purchase Judy Towing, Hitching, Axles and Running Gear 12 02-15-2012 12:28 PM
Newbie needs help FredericL General Chat 5 05-13-2008 07:49 AM
Help me pleez! Newbie... Janelle Problem Solving | Owners Helping Owners 15 09-15-2007 05:33 PM
