Help Needed - installing a disconnect switch and a battery charger - Page 2 - Fiberglass RV
Old 03-11-2016, 01:22 PM   #15
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Joe, I agree that the cutoff switch should accomplish the same goal as the SPDT.
The reason to isolate the battery with a switch?
(1) That's the best way to ensure it gets fully and properly charged.
(2) As others have mentioned, you can also use the cutoff switch to prevent the battery from being discharged when the camper is not being used.
Old 03-11-2016, 01:38 PM   #16
Joe & Cherie's Avatar
Trailer: 2013 EggCamper & 2011 Silverado Reg Cab 4x4
Ohio
Thanks John! I just needed to understand. I dont want to do it wrong. But you do have me thinking about the SPDT because Im starting to 2nd guess the idea of the Ctek hooked up and plugged in while boondocking - even tho the 110v outlet is dead. As was mentioned earlier, and your reasons too - gremlins. The SPDT kills that gremlin path and does seem like a solid approach.
I sincerely appreciate it John, and all who helped me! I think I have a plan!
2013 EggCamper #120
Joe's EggCamper Journal
Joe & Cherie is offline   Reply With Quote
Old 03-11-2016, 02:35 PM   #17
Trailer: Casita 17 ft DLX SD
The charging portion on my Scamp converter failed . I cut the leads from the converter's charger (line side) in half and taped off the half coming from the converter's charger. I then took the 12 VDC leads from my new smart charger and hooked them up to the half of the wires going to the battery / converter (Load ). Everything will work as it normally does . You could also put a SPDT switch in line as mentioned above so you could run either charger to charge your battery.
Old 03-11-2016, 03:44 PM   #18
Joe, in boondock mode, the CTEK charger would still be attached to the battery. You could simply disconnect the CTEK charger from the battery. It comes with a quick disconnect charging cord. Even if you don't, according to the CTEK charger manual, this charger has only 1 amp hour per month back current drain. "Back current drain is the current that drains the battery if the charger is not connected to the mains. CTEK chargers have very low back current."
Old 04-03-2016, 07:44 PM   #19
Ohio
Well I have her finished! I installed a battery cutoff switch inside the Casita which is cutting off the positive side. Then I installed a new switched 110AC recepticle outlet off of the spare breaker and plugged the ctek into it. Then ran the +/- leads on the ctek to 2 more dc switches. Then from those switches to the battery +/- hooked up the the battery side of the cutoff switch.
Now I can switch the battery off and on, I can power the charger off and on, and I can switch off the leads going from the charger to the battery to prevent any back current. Now I never enter the battery compartment!
I charge battery while its plugged into shore power and switched off from the Casita. I turn off the charger and I switch off the ctek +/- leads while battery is on for boondocking!
All switches and outlet are under the side dinette seat so no visible stuff.
Thanks EVERYBODY for your help in this topic!!
2013 EggCamper #120
Old 04-03-2016, 08:05 PM   #20
Joe, that's a great setup. Let us know how it works out.
-John
Old 04-09-2016, 03:55 PM   #21
Trailer: 1999 Casita 17' SD
Ohio
Originally Posted by JWScarab View Post
Guys, I have a '05 Casita SD17.
CTEK Multi US 4.3 - CTEK Battery ChargersCTEK Battery Chargers
1st - I have 2 wires going to my battery + now and one of them tests 12+V when plugged in.
You may have the battery connected backwards!
Your Casita when new had only had one wire, a BLACK one, on the POSITIVE battery terminal.
And a GREEN wire and a WHITE wire on the NEGATIVE terminal
The green goes to frame ground on the trailer.
The charger in the converter connects to battery voltage in the converter.
Joe
Old 04-09-2016, 07:59 PM   #22
Ohio
I had it typed backwards. I do have it hooked up correctly! All seems to be good. Thanks!
2013 EggCamper #120
battery
Battery disconnect and volt meter Terry M Problem Solving | Owners Helping Owners 2 05-28-2015 05:39 PM
Heavy Duty Battery Disconnect FTTRV Commercial Posts and Products 2 11-26-2013 08:36 AM
Installing a new battery charger vs converter? cpaharley2008 Electrical | Charging, Systems, Solar and Generators 9 03-28-2011 09:13 AM
Battery Charger Needed Patrick M. Electrical | Charging, Systems, Solar and Generators 30 07-24-2006 07:00 AM
Battery Disconnect Switch Victor Benz Electrical | Charging, Systems, Solar and Generators 18 07-06-2006 04:33 AM
