HELP- - Re-wiring a 74 Trillium 13' - Page 2 - Fiberglass RV
Old 04-10-2009, 10:59 PM   #15
Trailer: 76 Trillium 13 ft
Will the trailer be grounded through my tow vehicle in that case? Or do the wires need to be grounded in the trailer as well?
Thanks guys
T
Tim Bas is offline   Reply With Quote
Old 04-11-2009, 02:06 AM   #16
Roger C H's Avatar
Unhappy
For all the Vintage Trillium owners, this may be helpful:
All Trilliums were made to the standard 'Bargman' color code.
Green- Running lights
Red - Left turn
Brown - Right turn
Black - Interior, Battery
White - Ground
Blue - Brakes
Yellow - Optional 'Foreign car wiring'
We modified many early Trilliums with an extra bulb in each tail light to perform the function of a stop lamp. This extra bulb was connected to the yellow wire. This was only done to customer's units as per request. Since these trailers change many hands now, have a look at the tail light assembly to see what's back there.
If anyone is having difficulty figuring out their Trillium, I'll be happy to help.
Please email me at Projects[at]TrilliumRV.com
Tom
Trillium RV
TOM
Does this apply to NEW Trilliums as well?
Old 04-13-2009, 06:47 PM   #17
Trailer: 1974 Trillium 13 ft
thanks everyone. i took the trailer to the local rv guy here in Delta (AL's RV0 and he cleaned up the wiring and got it all working for $145. Pretty good price and I was totally lost with the mess the cursed previous owner had left me with.
Barry
Barry Konkin is offline   Reply With Quote
Old 04-16-2009, 11:20 AM   #18
Trailer: Trillium Manufacturing
Roger: Yes, I should have stated that this is for all Trilliums - old & new.
Pete: You are correct - the top 3 reasons for electrical wiring issues is Grounding. - Usually in the tow vehicle. Grounding through the hitch ball is a not a reliable method.
Tom
TomA is offline   Reply With Quote
Old 08-21-2013, 12:17 PM   #19
Trailer: 76 trillium
Massachusetts
Have a 76 trillium .need to rewire lighting .need a wiring guide ...could you help me ? Jay allcomplus@ gmail.com
Jaywaker421 is offline   Reply With Quote
Old 08-21-2013, 06:00 PM   #20
Like Pete says GROUND.I have a 1978 4500 and after 2 days of work found ground WIRES not wire was the problem.RUST in tail light bulb,rust on every ground wire in every light.
stone89 is offline   Reply With Quote
Old 10-05-2015, 08:35 AM   #21
MoDZuKi's Avatar
Trailer: Trillium 13'
I just rewired for a travel trailer and there are differences in the colour codes of the wiring on a 4 way flat between REGULAR trailers and an RV. The 7 way I purchased was wired for a regular trailer NOT an RV. The colours of the 4 way flat were totally different and I had to swap a few wires around to get everything working the way it should (left signal, right signal and running)
MoDZuKi is offline   Reply With Quote
trillium
Vehicle wiring to tow Trillium 13 francene Towing, Hitching, Axles and Running Gear 9 03-19-2009 09:14 PM
Trillium 1300 wiring diagram needed. William Neufeld Problem Solving | Owners Helping Owners 1 07-08-2008 12:07 PM
Wanted:Trillium wiring diagram Mikey Problem Solving | Owners Helping Owners 1 09-01-2007 05:07 PM
RV Wiring Darwin Maring Problem Solving | Owners Helping Owners 8 01-27-2007 03:45 PM
Wiring Gauge D Shubel Problem Solving | Owners Helping Owners 9 05-09-2006 05:44 PM
