Help! Trailer Brake/Electrical Problem - Page 2 - Fiberglass RV
Old 07-05-2013, 06:28 PM   #15
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Whew!
I hope to shout it was "no cost to you"- since it sounds like they made the mistake to begin with.
Good reminder for folks to check routing of such work- I had something similar happen, though no malfunction as a result. In my case, a few days after I had the tow wiring done I happened to notice a big ol' wire hanging down almost to the ground under the car.
Turns out one of the lines went from back to front without any support or effort to conceal/protect it. You may be sure I'm much more vigilant about checking such work now...
Francesca
Old 07-05-2013, 06:35 PM   #16
Trailer: 1980Trillium 1300
Originally Posted by Roy in TO View Post
Did a quick search for Tekonsha wiring diagrams. Came up with this one from etrailer for the Voyager controller. Interesting enough that it shows two circuit breakers and no fuses. It appears to want a 20A breaker between the battery and controller, with the 40A breaker between the battery and 12V positive.
...An auto-reset breaker in a circuit plays roles of both breaker and fuse and it is reset-able, as my understanding...
Old 07-05-2013, 06:50 PM   #17
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Great thread.
Jack
Old 07-05-2013, 07:08 PM   #18
Roy in TO's Avatar
Fuses are only good for one bad event and have to be replaced.
Breakers are good for more.
Some you have to manually reset.
Auto-reset, keep resetting themselves. So fast, you can hear them "buzz".
Old 07-05-2013, 08:29 PM   #19
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Originally Posted by Lin in NC View Post
I have a new FGRV, lightweight only 2100 pounds. Have pulled it twice and used trailer brakes with no issues.
Today I hooked it up and drove approximately 1/2 mile...smoke began to fill the passenger compartment of my truck. Immediately turned off engine and popped the hood. Wiring had melted in the engine compartment as well as wiring at the harness/7 prong connector at rear of truck.
I had the truck towed to dealer...they will be looking at tomorrow.
Any ideas of what may have caused this. I'm at a loss. Any help will be appreciated.
I'm glad the cause was found, and I enjoyed the brainstorming of causes to look for if this happens to us. Here in the desert of Arizona we have trouble with rodents chewing wires and causing all kinds of electrical problems.
Happy Trails
Dave & Paula
Old 07-05-2013, 08:37 PM   #20
Roy in TO's Avatar
We've got the same thing up here in Canada. Just this week, I had a squirel strip the insulation off clean to about 8" of wire to a light under the eaves where she was building a nest. I lost 3 rooms inside, when I unknowingly flicked the switch. Hope she had a shocking experience.
Electrical Problem jimmied Electrical | Charging, Systems, Solar and Generators 55 11-06-2012 07:33 PM
Electrical problem jaye580 Problem Solving | Owners Helping Owners 8 07-28-2008 08:52 PM
Electrical problem - Help! scott fraser Problem Solving | Owners Helping Owners 2 08-07-2007 06:03 PM
Trillium Electrical Problem Legacy Posts Problem Solving | Owners Helping Owners 4 07-19-2003 12:44 AM
Tow to Trailer Electrical Problem Legacy Posts Problem Solving | Owners Helping Owners 12 07-14-2003 08:30 PM
