Help with wiring P4045 - Fiberglass RV
Old 05-08-2014, 04:13 PM   #1
Trailer: starcraft
Ohio
Help with wiring Progressive Dynamics PD4045
I am kind of stumped on only 1 aspect of the install. The AC black wire(hot) from the shore power line into my box... Does that go directly on the breaker or on the screw holding the metal strip directly behind the fuse(or somewhere else)? My only breaker is a dual one 15/20 (see pic of my old PC)
Questions:
1.) Where do I attach the shore power Black/hot AC wire? Looks like it goes to a 30amp breaker in the second pic
2.) Where do you attach the lights/appliance white wires? I have seen them grouped and attached to the a wire from the neg on the battery.
3.) What breakers should I use? I only have 2 outlets AC and a future Airconditioner(and most likely a 30 main).
4.) Do you run the ground wire from the chasis to the PD4045 ac side or do you rely on the shore power to act as the ground?
5.) Finally, in the second pic on the right lower side, it shows 120v hot but doesn't have anything attached. Mine has the a wire going from the converter side to it, but the pic has that wire going to a breaker. What is the correct way?
New PD4045(not mine, but a pic I found)
Oh, I installed a 400w dc to ac converter for my TV. should I connect that directly to my battery or use one of the 2 30amp red dc wired fuses?
Thanks, MP.
MPohio is offline   Reply With Quote
Old 05-08-2014, 05:10 PM   #2
Trailer: starcraft
Ohio
I think I am going to have to get some new breaker. My old one is a single contact breaker and the PD4045 looks like a dual contact breaker.
Old 05-08-2014, 05:11 PM   #3
David Tilston's Avatar
30 A wont work for your 400 W inverter.
400 W / 12 VDC = 33.3 A
You should get a 40 A fuse, and wire to match. I'd go with #6 to the inverter.
Old 05-08-2014, 05:24 PM   #4
Trailer: starcraft
Ohio
Thanks Dave. Could I just wire it to the batter? It came with to batter clips, but since I have a new power panel, I was just going to make use of as much as I can.
PS> any idea on the main power cord? Does it go into a breaker or on the box itself?
thanks< Mark>
Old 05-08-2014, 05:32 PM   #5
BOB MILLER WHERE ARE YOU?
Bob just loves the PD4045. He can tell you everything you want to know about it. I'm sure he will be along shortly. If not, send him a PM.
The inverter can come straight off the battery. Probably best that way. They draw lots of current and the less connections between the inverter and the battery, the better. But please don't forget the fuse.
Old 05-08-2014, 05:50 PM   #6
Trailer: starcraft
Ohio
Yeah, I hope bob chimes in here. I have been doing a bunch of reading and am more confused about the DC side which I will add to the OP.
Old 05-08-2014, 07:16 PM   #7
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Direct to breaker goes the black shore wire
summer scamp is offline   Reply With Quote
Old 05-08-2014, 07:18 PM   #8
Click on his name Send him a PM - if he is around that will get his attention.
Old 05-08-2014, 07:40 PM   #9
Trailer: starcraft
Ohio
Thanks Carol. I sent him one. I am pretty well getting things under control after watching quite a few videos on the subject. I just want to make sure I do it correctly.
Old 05-08-2014, 10:01 PM   #10
Okey-Dokey
First, you need a minimum of three breakers + one more for the future A/C if you want.
Breaker #1 is the Main, connect the hot lead from the line cord to the bottom of the first breaker. That way the first breaker feeds the buss bar at the top that the additional breakers are attached to.
The next one is the small breaker for the Converter power wire, it connects to the bottom of the 2nd breaker. Connect the ac outlets to the bottom of the third breaker and the 4th breaker will be reserved for the future a/c.
The battery connects to the terminals provided and is automatically linked to the charger and the DC Buss/fuses. The wires on the back are numbered by fuse position, connect your dc loads to each wire and install appropriate sized fuses. It's better to use more fuses than less, that way you don't loose more than one thing if you blow a fuse.
I run a separate ground wire for the DC circuits from the battery to a terminal strip of some sort to use for the DC loads.
More questions????
Old 05-09-2014, 05:46 AM   #11
Trailer: starcraft
Ohio
Awesome Bob and much Thanks!!
I did Figure out some of it, but was fuzzy on the the breaker setup. The previous box must have been wired by monkeys They had everything running to a two stage breaker and 3 fuses.
I used my volt meter resistance mode to find the 3 lights and vent fan lead(Amazing what you can learn through youtube). They are all wired together and will all be on one fuse. The only other ones I need to isolate are the Fridge & Furnace wires.
Last questions (for now).
1.) How do/where do I hook up Tow vehicle's wires coming in from the harness(Being a TC I only have 2) They both worked fine before my new project
A.) First charges the 12v system
B.) Second activates the running lights on the camper
2.) what are/where the blue fuse holders used for(fuse was labeled 1 (see pic below)
3.) is there a chart somewhere to show what size fuses should go to what?
A.) fuses for furnace, lights/fan, 12volt outlet,
B.) size breaker for outlet, future Air cod hookup, Main(30amp?)
Old 05-09-2014, 06:25 AM   #12
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
If you want the space, you can also install dual breakers. That gets you the 30 amp main, plus 6 circuits.
Old 05-09-2014, 06:28 AM   #13
Jared J's Avatar
Kansas
Name:	ImageUploadedByFiberglass RV1399638514.144129.jpg
Old 05-09-2014, 07:05 AM   #14
Trailer: starcraft
Ohio
I really only need 1 main and at most 3 other breakers. What type of breakers do you have(they are printed on the front of the breaker(hom,homt,br,brd, tb,tbbd, ...) ? I need to buy some but not sure of the type. I have seen 30 HOM as the main and HOMT as the branch breakers in the picture I posted of another unit. I am not sure what requires 15 or 20 amp breakers.
What I have:
1.) fridge
2.) 2 110v outlets
3.) future Airconditoner hookup
DC:fuse sizes?
1.) furnace
2.) 3 lights and fantastic fan(all wired together
3.) 12v outlet
4.)
HELP- - Re-wiring a 74 Trillium 13' Barry Konkin Electrical | Charging, Systems, Solar and Generators 20 10-05-2015 08:35 AM
Scamp to Subaru trailer wiring - help needed Mikeny Problem Solving | Owners Helping Owners 7 07-27-2007 05:16 AM
Brake Control Wiring Help Needed Gail Shook Problem Solving | Owners Helping Owners 8 06-07-2007 06:02 AM
Need help on wiring new side lights, old scamp Drew Bogner Problem Solving | Owners Helping Owners 6 07-18-2006 06:44 AM
Fuse Box Wiring HELP PLEASE!! shawnswan Problem Solving | Owners Helping Owners 10 02-07-2006 04:06 PM
