How bad did I screw up my trailer electrical? - Fiberglass RV
Old 01-06-2014, 05:28 PM   #1
Georgia
Being new owner of used Casita, I decided to remove the battery since the temps are dropping tonight.
While I was using my socket wrench in the small compartment, I successfully removed the positive bolt and lead from it's post. While I reached over to get the neg lead sparks started flying so I must have touched the socket wrench to both terminals . I quickly removed it and then reconnected the positive lead back up.
Well, nothing electrical works in the casita now!
What did I do and how bad (expensive) is it going to be for repairs?
By, the way. I did finally get the battery out of the compartment and see that the positive lead has a small kind of like weld spot on it now.
outdoorman is offline   Reply With Quote
Old 01-06-2014, 05:30 PM   #2
Jim Bennett's Avatar
You likely just blew a fuse. I would check that first.
If you keep your battery fully charged, there is no reason to remove it from the trailer. Mine have always been kept in the trailer, and have never had any trouble, and lordy knows it has got cold around here.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 01-06-2014, 05:42 PM   #3
Georgia
Whew! I feel better already
Ok, rather basic question: which fuse is it likely to be?
Should I just go inside to the fuse box and start searching for what looks like a blown auto type fuse?
I know this sounds rudimentary but I only saw the fuse box once about 2 months ago when I bought the trailer.
Old 01-06-2014, 05:54 PM   #4
Trailer: 1984 Dolphin
Wisconsin
Ya it should just be a fuse. If you remove battery cables as a rule always remove the neg first and when installing the battery hook up neg last.
Ace57 is offline   Reply With Quote
Old 01-06-2014, 05:59 PM   #5
Georgia
I just looked in the fuse box and all the fuses looked fine to me. Could it be something else or is there another location?
Old 01-06-2014, 07:02 PM   #6
Massachusetts
Hi Outdoorsman,
What happens when you go onto shore power? Are you sure the battery is ok? Do you have a multi-meter?
Rick
kb1flr is offline   Reply With Quote
Old 01-06-2014, 08:21 PM   #7
Georgia
I didnt try shore power; guess I'll try tomorrow it's dark and COLD tonight.
Old 01-06-2014, 08:56 PM   #8
It's possible that by causing a dead short across the battery terminals it is completely discharged or damaged. I had one battery melt the post right off it due to a short in a cable.
Old 01-06-2014, 11:56 PM   #9
Trailer: 2010 Scamp 16
With the short being a tool bridging between battery terminals rather than current going through the camper electrical system I tend to be thinking the same way as Bob and Richard, look to the battery that is what took the dead short.
Especially if none of your fuses blew.
Old 01-07-2014, 03:59 AM   #10
Trailer: Escape 5.0 TA
W. Mass
Do FG trailers use a breaker between the battery and the converter like stick builts do? I've heard of them being damaged and needing replacement.
Not sure but I think it's inline on the negative lead.
Old 01-07-2014, 09:25 AM   #11
Trailer: Scamp 13
You might try asking on the Casita forum they will know where the fuses are located and how the trailer is wired. Let them know what year your trailer is.
Casita Travel Trailer Forum
Old 01-08-2014, 07:11 PM   #12
Georgia
Ive gotten home to late the last couple of nights to go out and look at the trailer.
I will try your suggestions either later this week or weekend when home during daylight.
Old 01-13-2014, 09:03 PM   #13
Georgia
thanks to all, it's fixed!
I took out the battery, checked the voltage at local autozone then brought home to charge. Now all is working. Thanks again.
Old 01-14-2014, 12:18 PM   #14
Larry C Hanson's Avatar
Trailer: 78 Trillium 13 ft / 2003 F150
Battery Technique
Hello All,
Whew, you got lucky! You probably know this,
but others might not. ALWAYS disconnect the (-)
negative side of the battery FIRST. That way,
it you happen to ground the (+) positive terminal
anywhere except to the other (-) battery post
no sparks should fly. Same goes for the tow vehicle.
Take Care,
Larry H
Larry C Hanson is offline   Reply With Quote
electrical
I did it, I REALLY DID IT!!!!! Monica M General Chat 16 04-17-2016 10:29 PM
Dress up Ugly Screw Heads Highway68 Care and Feeding of Molded Fiberglass Trailers 13 11-16-2009 06:38 AM
LED replacement for a medium screw type bulb. Bonnie Problem Solving | Owners Helping Owners 4 03-31-2008 06:00 AM
Replacing white plastic rivet/screw covers WayneJ Care and Feeding of Molded Fiberglass Trailers 8 03-06-2006 03:47 PM
Bad bad news Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
